Anyone got one of these units?
http://www.garmin.com/products/gnc250xl/ It seems to combine two very useful things (a VFR moving map GPS and a Com radio) into one compact unit. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
As a follow-up, can anyone figure out why the GNC 300XL (the IFR-certified version of this unit) is actually available for LESS money on Ebay and other sources? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
It may have something to do with the installation costs. If you're going to
install the 300XL as an IFR unit you'll need a CDI and an annunciator - not cheap. I *THINK* that you can probably install it as a VFR only unit which would seemingly make it a better deal than the 250XL. Just my $.02 -Brian N33431 Iowa City, IA "Jay Honeck" wrote in message news:X0qkd.321946$wV.199876@attbi_s54... http://www.garmin.com/products/gnc250xl/ As a follow-up, can anyone figure out why the GNC 300XL (the IFR-certified version of this unit) is actually available for LESS money on Ebay and other sources? |
![]() My guess is that people make a list of units in their head that they are going to look for, and they a priori exclude IFR units thinking they will be much more expensive. Therefore, the demand for the 250 is greater, and drives the prices higher. As for a VFR-only install, you could install a ham sandwich and call it a VFR GPS, for all the FAA cares. -cwk. "Brian Sponcil" wrote in message ... It may have something to do with the installation costs. If you're going to install the 300XL as an IFR unit you'll need a CDI and an annunciator - not cheap. I *THINK* that you can probably install it as a VFR only unit which would seemingly make it a better deal than the 250XL. Just my $.02 |
Brian Sponcil wrote:
It may have something to do with the installation costs. If you're going to install the 300XL as an IFR unit you'll need a CDI and an annunciator - not cheap. I *THINK* that you can probably install it as a VFR only unit which would seemingly make it a better deal than the 250XL. For an IFR install, you also need a means to interface it to your altitude encoder. This often means purchasing a serializer to convert from grey code (I think) to RS-232c. I know that on my GX-60, you can go into system setup mode and tell it to behave like a VFR-only GPS. If you're seriously thinking about these two units, I definitely think you should go with the 300XL, just in case you want to get it IFR certified at a later date. A used UPSAT GX-60 is probably a good buy, too. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
"Jay Honeck" writes:
Anyone got one of these units? http://www.garmin.com/products/gnc250xl/ It seems to combine two very useful things (a VFR moving map GPS and a Com radio) into one compact unit. A friend of mine has one in his homebuilt (a Kitfox). Works great. -jav |
radio) into one compact unit. Jay You are not about to ditch your AvMap? I am thinking about putting a GNS480 into my 172 Cessna. Will keep the AvMap as backup. Hank |
Ditch the Avmap? Heck, no! The panel mount Garmin's display and functionality is so vastly inferior to the AvMap, that I would certainly look at *it* as the back-up unit -- not the other way around. However, I've got an old Narco 120 Com that works fine but is getting pretty "long-in-the-tooth". I've also got an old Narco DME that works perfectly, but is utterly useless to me. I'd like to yank both those units, save about ten pounds, sell them on Ebay, and replace them with a new Garmin GPS/Com combo. I think that would be a great upgrade -- but I'd like to hear from folks who have one before making the leap! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message news:stqkd.321972$wV.301196@attbi_s54... I'd like to yank both those units, save about ten pounds, sell them on Ebay, and replace them with a new Garmin GPS/Com combo. I think that would be a great upgrade -- but I'd like to hear from folks who have one before making the leap! I used to have one in a previous plane. Worked great. In addition, it can be IFR certified, in case you decide to go that way. Can't remember the subscription price, which in any case, has probably gone down since you can probably renew through the Internet rather then sending data cards bck and forth. In fact, I don't even remember if it used data cards, although I assume it did... Michael |
Michael 182 wrote:
: "Jay Honeck" wrote in message : news:stqkd.321972$wV.301196@attbi_s54... : I'd like to yank both those units, save about ten pounds, sell them on : Ebay, and replace them with a new Garmin GPS/Com combo. I think that : would be a great upgrade -- but I'd like to hear from folks who have one : before making the leap! : I used to have one in a previous plane. Worked great. In addition, it can be : IFR certified, in case you decide to go that way. Can't remember the : subscription price, which in any case, has probably gone down since you can : probably renew through the Internet rather then sending data cards bck and : forth. In fact, I don't even remember if it used data cards, although I : assume it did... The subscription is about $360/year for internet based updates. That gets you an update every 28 days (13 a year). You may be able to get a subscription for a smaller geographic area for less $$$ (I can't with my GPS). The 250XL is not IFR upgradeable. The 300 XL is IFR upgradeable with apropriate additional equipment: CDI and annunciator/switch. The 300 XL can be installed as a VFR only unit. Why the 300Xl is cheaper than the 250XL is anyones guess, but I'd get the 300Xl over the 250Xl were it my choice. -- Aaron Coolidge |
Question on Garmin GNC 250XL | Ron | Home Built | 1 | October 24th 04 08:26 AM |
Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 09:03 AM |
Garmin 250XL Question | Carl Orton | Owning | 0 | April 28th 04 02:54 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
