Well, I met with the mechanics yesterday and we went through the
complete squawk sheet. I've been dropping by almost everyday just to get updates and looks at things while it's all opened up, so there weren't any last-minute surprises. One of the primary things to get through were the logs, which were in a bit of disarray. The airplane has spent quite a bit of time in Canada, so a large portion of the logs are in French. Thankfully the AD numbers and such are still the same so one can muddle through on most things. The shop that I'm using puts everything into a computerized AD list if they've not seen the airplane before so they can track everything easier in the future, it also cleans things up a bit. I now have a list of all applicable ADs, how they were complied with, when the next inspection, etc. is due, which is nice. Should make things straightforward next annual. I also appreciate that they just did this as part of an annual, they didn't charge extra labor, even though I know it took quite a bit of time for them to do this. Compressions on the engines were LHE 1-77,2-73,3-70,4-75,5-76,6-76 and RHE 1-76,2-76,3-73,4-74,5-76,6-74 The batteries won't hold a charge for very long so I'll be replacing those. The bolt for the Right alternator was found in the bottom of the cowl (this was one of the things that had been replaced while the plane sat, so that one was just weird, and I think that the bolt is safety wired, but I guess it hadn't been). We needed to reposition the fuel injector lines on the right engine to comply with an AD, redid the clamps as well since they weren't the correct type. There was a missing rivet for one of the camlocks on the lower cowl. The nose cargo door seal is just old and cracked, so I'll be replacing that to keep it from leaking. The intake manifold gaskets on #4 cylinder had separated and cracked, and in fact had been previously repaired in such a way that I'll have to pull the jug and replace it (If I ever find someone putting JB weld on an aircraft engine I swear I'll do something unpleasant!). We couldn't find any log entries on the Vacuum pumps, so they're probably the same ones as when the engines were installed. There is a Service Bulletin that says they should be replaced every 500 hours, but since I've two on this aircraft I'm not going to immediately replace them, they both work fine and I'm pulling enough vacuum even at 1000 RPM to keep things in the green arc. Just something I'll need to watch closely. The oil return lines are loose on the right engine, so they'll need to be tightened up (I'm told this is something to check every time I change the oil as they shake loose, that and taking a screwdriver to the valve covers to make sure they're tight, something inherent to Lycomings?) Most other things are items that need to be tightened or have new O-rings installed to stop leaks. A couple of major things though, and these are the things that have me a bit bummed, but I guess it could've been worse. There is illegal repair on the right-hand engine mount. It's a repair that should have been sleeved, but all they did was put a bead around it. They brought in a welder and he said it's too tight for him to get his gear in there to weld while the engine is there, so I'll have to remove the engine to get fixed. Since the engine will be off the aircraft, I'll replace the engine mounts, since they're slipping just a bit and it's not going to cost me any extra labor to have it done. One of the brake calipers on the right side was broken where one of the bolts attach it. Some of the brake pads are worn almost to the rivets. They all leak a bit. To repair/replace some of the components would cost $2300 while getting a whole new brake kit would cost $2500. It took some time to source the old parts because the part number have changed a number of times. I decided to just get the whole kit and bring everything current, the cost difference was marginal and now I'll have part numbers someone can actually look up. The brakes also had a bit of play in them, so they were rubbing on the inner sidewall of the tire, so I will be replacing those as well. The last big thing is the flap torque tube AD. I figured it costs just as much labor wise to pull it out to inspect as it would to do the replacement, so I ordered the new part and will have that installed as well. Since there are alot of little things, adjustments, rebuilding components with new O-rings, etc. The labor will be a significant part of the cost of correcting the squawks post-annual (since in my mind the annual is just the inspection portion), and I didn't get away with as little cost as I'd like, but it will be put back together and everything will be done, so next years annual should be pretty straightforward. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
Thanks Louis.
I found the invoice from when our Aztec had it's torque tube replaced. It was sometime in 2003. The tube cost less than $600 and the labor was about $300. I then looked up the log book entry and found that they took the old tube out and sent it and the new tube to a machine shop to have the holes drilled, that way the new tube ended up exactly as the old one. This should prevent some of the problems others have posted about drilling the new tubes as per the drawings only to find that they don't line up where they need to be. Jim "Louis L. Perley III" wrote in message ... Well, I met with the mechanics yesterday and we went through the complete squawk sheet. I've been dropping by almost everyday just to get updates and looks at things while it's all opened up, so there weren't any last-minute surprises. One of the primary things to get through were the logs, which were in a bit of disarray. The airplane has spent quite a bit of time in Canada, so a large portion of the logs are in French. Thankfully the AD numbers and such are still the same so one can muddle through on most things. The shop that I'm using puts everything into a computerized AD list if they've not seen the airplane before so they can track everything easier in the future, it also cleans things up a bit. I now have a list of all applicable ADs, how they were complied with, when the next inspection, etc. is due, which is nice. Should make things straightforward next annual. I also appreciate that they just did this as part of an annual, they didn't charge extra labor, even though I know it took quite a bit of time for them to do this. Compressions on the engines were LHE 1-77,2-73,3-70,4-75,5-76,6-76 and RHE 1-76,2-76,3-73,4-74,5-76,6-74 The batteries won't hold a charge for very long so I'll be replacing those. The bolt for the Right alternator was found in the bottom of the cowl (this was one of the things that had been replaced while the plane sat, so that one was just weird, and I think that the bolt is safety wired, but I guess it hadn't been). We needed to reposition the fuel injector lines on the right engine to comply with an AD, redid the clamps as well since they weren't the correct type. There was a missing rivet for one of the camlocks on the lower cowl. The nose cargo door seal is just old and cracked, so I'll be replacing that to keep it from leaking. The intake manifold gaskets on #4 cylinder had separated and cracked, and in fact had been previously repaired in such a way that I'll have to pull the jug and replace it (If I ever find someone putting JB weld on an aircraft engine I swear I'll do something unpleasant!). We couldn't find any log entries on the Vacuum pumps, so they're probably the same ones as when the engines were installed. There is a Service Bulletin that says they should be replaced every 500 hours, but since I've two on this aircraft I'm not going to immediately replace them, they both work fine and I'm pulling enough vacuum even at 1000 RPM to keep things in the green arc. Just something I'll need to watch closely. The oil return lines are loose on the right engine, so they'll need to be tightened up (I'm told this is something to check every time I change the oil as they shake loose, that and taking a screwdriver to the valve covers to make sure they're tight, something inherent to Lycomings?) Most other things are items that need to be tightened or have new O-rings installed to stop leaks. A couple of major things though, and these are the things that have me a bit bummed, but I guess it could've been worse. There is illegal repair on the right-hand engine mount. It's a repair that should have been sleeved, but all they did was put a bead around it. They brought in a welder and he said it's too tight for him to get his gear in there to weld while the engine is there, so I'll have to remove the engine to get fixed. Since the engine will be off the aircraft, I'll replace the engine mounts, since they're slipping just a bit and it's not going to cost me any extra labor to have it done. One of the brake calipers on the right side was broken where one of the bolts attach it. Some of the brake pads are worn almost to the rivets. They all leak a bit. To repair/replace some of the components would cost $2300 while getting a whole new brake kit would cost $2500. It took some time to source the old parts because the part number have changed a number of times. I decided to just get the whole kit and bring everything current, the cost difference was marginal and now I'll have part numbers someone can actually look up. The brakes also had a bit of play in them, so they were rubbing on the inner sidewall of the tire, so I will be replacing those as well. The last big thing is the flap torque tube AD. I figured it costs just as much labor wise to pull it out to inspect as it would to do the replacement, so I ordered the new part and will have that installed as well. Since there are alot of little things, adjustments, rebuilding components with new O-rings, etc. The labor will be a significant part of the cost of correcting the squawks post-annual (since in my mind the annual is just the inspection portion), and I didn't get away with as little cost as I'd like, but it will be put back together and everything will be done, so next years annual should be pretty straightforward. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
On Wed, 10 Nov 2004 13:10:56 -0600, "Jim Burns"
wrote: I then looked up the log book entry and found that they took the old tube out and sent it and the new tube to a machine shop to have the holes drilled, that way the new tube ended up exactly as the old one. That's a good idea! Thanks. Also thanks to Louise for the post. z |
I wish I could claim credit for it!
![]() Jim "zatatime" wrote in message ... On Wed, 10 Nov 2004 13:10:56 -0600, "Jim Burns" wrote: I then looked up the log book entry and found that they took the old tube out and sent it and the new tube to a machine shop to have the holes drilled, that way the new tube ended up exactly as the old one. That's a good idea! Thanks. Also thanks to Louise for the post. z --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
"Jim Burns" wrote in message
... I found the invoice from when our Aztec had it's torque tube replaced. It was sometime in 2003. The tube cost less than $600 and the labor was about $300. I then looked up the log book entry and found that they took the old tube out and sent it and the new tube to a machine shop to have the holes drilled, that way the new tube ended up exactly as the old one. This should prevent some of the problems others have posted about drilling the new tubes as per the drawings only to find that they don't line up where they need to be. Jim I was quoted $482 for the tube, so I wasn't too worried. I'll pass along the note about keeping the original to know where to drill the holes. Thanks for the tip! -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
Louis L. Perley III wrote:
: they're probably the same ones as when the engines were installed. There is : a Service Bulletin that says they should be replaced every 500 hours, but : since I've two on this aircraft I'm not going to immediately replace them, : they both work fine and I'm pulling enough vacuum even at 1000 RPM to keep : things in the green arc. Just something I'll need to watch closely. Dry vacuum pumps fail without catastrophically and without notice. If it's been awhile, I'd might replace at least one. I'd definately add the inline chunck-catching vacuum filter so if one goes it won't spew chunks into the system and kill the other stuff. I'm, of course, assuming this can be done/makes sense on a twin. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
it's been awhile, I'd might replace at least one. I'd definately add the inline chunck-catching vacuum filter so if one goes it won't spew chunks into the system and kill the other stuff. I'm, of course, assuming this can be done/makes sense on a twin. -Cory They are Parker Hannifin, I figured I'd just keep them in there so in the event of a failure/crash that has absolutely nothing to do with the vacuum pumps, my estate can collect a ton of money (I'm kidding!) The system as installed does have some sort of filter just before they go into the instrument cluster. I only noticed this because I'll be replacing the tube that goes from it to the instruments, as it's starting to look cracked, etc. It still works fine, I just figured for $5 or so, it's not worth it to keep it in there as a potential failure. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
"Louis L. Perley III" wrote in message ... Well, I met with the mechanics yesterday and we went through the complete squawk sheet. I've been dropping by almost everyday just to get updates and looks at things while it's all opened up, so there weren't any last-minute surprises. One of the primary things to get through were the logs, which were in a bit of disarray. You may want to sit down with you significant other for a day and work on getting your logs in order just incase you need to use another IA in the future. . The airplane has spent quite a bit of time in Canada, so a large portion of the logs are in French. Thankfully the AD numbers and such are still the same so one can muddle through on most things. Find a translator/interrupter to convert it in to English have then notarized so your A&P IA can actually read what it says may be good for the future value of your aircraft. If I was a buyer I would want to see English log's notarized from a translator/interrupter unless I know the language. The shop that I'm using puts everything into a computerized AD list if they've not seen the airplane before so they can track everything easier in the future, it also cleans things up a bit. I now have a list of all applicable ADs, how they were complied with, when the next inspection, etc. is due, which is nice. Should make things straightforward next annual. I also appreciate that they just did this as part of an annual, they didn't charge extra labor, even though I know it took quite a bit of time for them to do this. Compressions on the engines were LHE 1-77,2-73,3-70,4-75,5-76,6-76 and RHE 1-76,2-76,3-73,4-74,5-76,6-74 The batteries won't hold a charge for very long so I'll be replacing those. Wise Choice! The bolt for the Right alternator was found in the bottom of the cowl (this was one of the things that had been replaced while the plane sat, so that one was just weird, and I think that the bolt is safety wired, but I guess it hadn't been). Ok, now what the deal with people not safety tying bolts my starter bolts on my C-150 were not safety tied and discoverd not to be this annual We needed to reposition the fuel injector lines on the right engine to comply with an AD, redid the clamps as well since they weren't the correct type. There was a missing rivet for one of the camlocks on the lower cowl. The nose cargo door seal is just old and cracked, so I'll be replacing that to keep it from leaking. The intake manifold gaskets on #4 cylinder had separated and cracked, and in fact had been previously repaired in such a way that I'll have to pull the jug and replace it (If I ever find someone putting JB weld on an aircraft engine I swear I'll do something unpleasant!). That really disturbing We couldn't find any log entries on the Vacuum pumps, so they're probably the same ones as when the engines were installed. There is a Service Bulletin that says they should be replaced every 500 hours, but since I've two on this aircraft I'm not going to immediately replace them, they both work fine and I'm pulling enough vacuum even at 1000 RPM to keep things in the green arc. Just something I'll need to watch closely. The oil return lines are loose on the right engine, so they'll need to be tightened up (I'm told this is something to check every time I change the oil as they shake loose, that and taking a screwdriver to the valve covers to make sure they're tight, something inherent to Lycomings?) Most other things are items that need to be tightened or have new O-rings installed to stop leaks. O-rings are a consumable part very inexpensive A couple of major things though, and these are the things that have me a bit bummed, but I guess it could've been worse. There is illegal repair on the right-hand engine mount. It's a repair that should have been sleeved, but all they did was put a bead around it. They brought in a welder and he said it's too tight for him to get his gear in there to weld while the engine is there, so I'll have to remove the engine to get fixed. Since the engine will be off the aircraft, I'll replace the engine mounts, since they're slipping just a bit and it's not going to cost me any extra labor to have it done. One of the brake calipers on the right side was broken where one of the bolts attach it. Some of the brake pads are worn almost to the rivets. They all leak a bit. To repair/replace some of the components would cost $2300 while getting a whole new brake kit would cost $2500. It took some time to source the old parts because the part number have changed a number of times. I decided to just get the whole kit and bring everything current, the cost difference was marginal and now I'll have part numbers someone can actually look up. Wise Choice The brakes also had a bit of play in them, so they were rubbing on the inner sidewall of the tire, so I will be replacing those as well. The last big thing is the flap torque tube AD. I figured it costs just as much labor wise to pull it out to inspect as it would to do the replacement, so I ordered the new part and will have that installed as well. Since there are alot of little things, adjustments, rebuilding components with new O-rings, etc. The labor will be a significant part of the cost of correcting the squawks post-annual (since in my mind the annual is just the inspection portion), and I didn't get away with as little cost as I'd like, but it will be put back together and everything will be done, so next years annual should be pretty straightforward. Have you thought of fixing the discrepancy's yourself while being supervised? can save you a bundle in labor costs! -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
complete squawk sheet. I've been dropping by almost everyday just to get updates and looks at things while it's all opened up, so there weren't any last-minute surprises. One of the primary things to get through were the logs, which were in a bit of disarray. You may want to sit down with you significant other for a day and work on getting your logs in order just incase you need to use another IA in the future. . I'm generally pretty good with this, I go through my logs on the 152 at least yearly myself to refresh my memory of what's in there, etc. Since I only recently bought out the other shareholders, I didn't have the logs in my control until a couple of weeks ago. The airplane has spent quite a bit of time in Canada, so a large portion of the logs are in French. Thankfully the AD numbers and such are still the same so one can muddle through on most things. Find a translator/interrupter to convert it in to English have then notarized so your A&P IA can actually read what it says may be good for the future value of your aircraft. If I was a buyer I would want to see English log's notarized from a translator/interrupter unless I know the language. Interesting thought. Never would have considered such a thing, but it makes sense. Too bad I'd not considered this a week ago, as one of my co-workers who is fluent in French just moved back to Nice, France. The batteries won't hold a charge for very long so I'll be replacing those. Wise Choice! I need Gill G-35 batteries, but they also list a G-35N and a G-35S, do the letters mean anything inportant? The prices are higher for the lettered parts. The bolt for the Right alternator was found in the bottom of the cowl (this was one of the things that had been replaced while the plane sat, so that one was just weird, and I think that the bolt is safety wired, but I guess it hadn't been). Ok, now what the deal with people not safety tying bolts my starter bolts on my C-150 were not safety tied and discoverd not to be this annual I don't know but it does make me wonder what other things might have been overlooked. I'm having them be very thorough on this inspection/annual. We're redoing some of the safety wire on some pieces because it just doesn't look like it's done right, like one some of the control turnbuckles. O-rings are a consumable part very inexpensive Never been happier when I was being told "It's just a leak" Have you thought of fixing the discrepancy's yourself while being supervised? can save you a bundle in labor costs! The main difficulty is time. I might take a crack at doing some of the basic things while they work on the more complex issues/repairs. I enjoy learning about how all this stuff is put together and how it works. Who knows, maybe knowing stuff like this will save my bacon one day if I get stranded somewhere. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
Louis,
you mentioned that your vacuum pumps seemed original. Our Aztec is in the shop right now having cooling shrouds installed on the vacuum pumps. Many of the "experts" or old time Aztec owners I've talked with advise this due to the high temps under our tight cowls. The shrouds really aren't much, $50 each, and not very complicated, basically a plastic 3/4 donut that fits over the vacuum pump and a scat tube runs ram air from the left/rear baffle to the shroud, similar to the blast tubes that cool the mags. The kits are made by RAPCO and available from Wag Aero. The STC that RAPCO has with the kit doesn't cover Aztecs so we had to get the FAA to do a field approval once we submitted a drawing. It didn't take much time for the install and combining the Aztec drawing with the RAPCO instructions made the field approval go smoothly. Because it's an alteration to the baffle or cooling system, it's considered a "major" alteration and needs a 337 and the FAA's blessing. Hopefully it will extend the life of our pumps. Jim "Louis L. Perley III" wrote in message ... Well, I met with the mechanics yesterday and we went through the complete squawk sheet. I've been dropping by almost everyday just to get updates and looks at things while it's all opened up, so there weren't any last-minute surprises. One of the primary things to get through were the logs, which were in a bit of disarray. You may want to sit down with you significant other for a day and work on getting your logs in order just incase you need to use another IA in the future. . I'm generally pretty good with this, I go through my logs on the 152 at least yearly myself to refresh my memory of what's in there, etc. Since I only recently bought out the other shareholders, I didn't have the logs in my control until a couple of weeks ago. The airplane has spent quite a bit of time in Canada, so a large portion of the logs are in French. Thankfully the AD numbers and such are still the same so one can muddle through on most things. Find a translator/interrupter to convert it in to English have then notarized so your A&P IA can actually read what it says may be good for the future value of your aircraft. If I was a buyer I would want to see English log's notarized from a translator/interrupter unless I know the language. Interesting thought. Never would have considered such a thing, but it makes sense. Too bad I'd not considered this a week ago, as one of my co-workers who is fluent in French just moved back to Nice, France. The batteries won't hold a charge for very long so I'll be replacing those. Wise Choice! I need Gill G-35 batteries, but they also list a G-35N and a G-35S, do the letters mean anything inportant? The prices are higher for the lettered parts. The bolt for the Right alternator was found in the bottom of the cowl (this was one of the things that had been replaced while the plane sat, so that one was just weird, and I think that the bolt is safety wired, but I guess it hadn't been). Ok, now what the deal with people not safety tying bolts my starter bolts on my C-150 were not safety tied and discoverd not to be this annual I don't know but it does make me wonder what other things might have been overlooked. I'm having them be very thorough on this inspection/annual. We're redoing some of the safety wire on some pieces because it just doesn't look like it's done right, like one some of the control turnbuckles. O-rings are a consumable part very inexpensive Never been happier when I was being told "It's just a leak" Have you thought of fixing the discrepancy's yourself while being supervised? can save you a bundle in labor costs! The main difficulty is time. I might take a crack at doing some of the basic things while they work on the more complex issues/repairs. I enjoy learning about how all this stuff is put together and how it works. Who knows, maybe knowing stuff like this will save my bacon one day if I get stranded somewhere. -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
| Annual Report Final. "Long" | NW_PILOT | Owning | 20 | October 28th 04 08:20 PM |
| Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 04:41 PM |
| Another Almost Annual Christmas Poem!!! | David Pincus | Home Built | 4 | December 28th 03 01:47 PM |
| Annual 2003 comes to a close... | Doug Vetter | Owning | 4 | December 25th 03 01:54 AM |
| Pre-Purchase Annual? | Paul Millner | Owning | 1 | July 4th 03 11:11 PM |
