Our Aztec's door seal needs replacing. I'm wondering how many people go the
inflatable route and what their experience has been. Would you do it again? Does it block noise and air better than the standard seal? Does it push the door away from the frame or cause too much pressure against the latch or the hinge? Electric or hand pump? Best make/model? STC/337/field approval or simple log book entry? Thanks! Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
"Jim Burns" wrote in message
... Our Aztec's door seal needs replacing. I'm wondering how many people go the inflatable route and what their experience has been. Would you do it again? Does it block noise and air better than the standard seal? Does it push the door away from the frame or cause too much pressure against the latch or the hinge? Electric or hand pump? Best make/model? STC/337/field approval or simple log book entry? Thanks! Jim Jim, I am considering installing the following, although I'll wait until after my annual is done and I get some time in the bird first: http://www.chiefaircraft.com/cgi-bin.../DoorSeal.html It's STC'd so one wouldn't need a 337, etc. I have flown in various aircraft that had them, Mooneys, Beech TravelAir, and a Baron. I've never been in an airplane that had the fully automatic one, just the ones that have the bulb you squeeze. It does seem to cut down on the noise noticeably when it's pumped up. Most people also feel they help keep the cabin warmer in the winter (but I think that's because they went from having a cracked/old door seal and hence anything new, inflatable or not, would have prevented air from coming in during the winter.) -- Louis L. Perley III N46000 - C152 N370 - PA-23-250 |
On Sat, 13 Nov 2004 07:33:45 -0600, "Jim Burns"
wrote: Our Aztec's door seal needs replacing. I'm wondering how many people go the inflatable route and what their experience has been. Would you do it again? Does it block noise and air better than the standard seal? Does it push the door away from the frame or cause too much pressure against the latch or the hinge? Electric or hand pump? Best make/model? STC/337/field approval or simple log book entry? Thanks! Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 What I can offer on the Aztec I'm familiar with is that the inflatable seal does make it more quiet in the cabin. Unfortunately they wear out over time, and currently the one I know about needs to be re-pumped every 20 minutes or so. When it deflates I think its louder than having a regular seal (although I don't have a multi engine reference to that observation, only lots of singles). The owner says he'd get an electrical pump if he had to do it again, why I'm not sure, just giving you his opinion. I don't know the model, but it did require an STC. HTH. z |
STC yes. Electric pump, yes. Pump burn out. only once in one year at my
total expense. Warmer in winter, yes. Less noise, yes. Worth it? YES. Advice? get it if you can afford it and you will not be disappointed. "Jim Burns" wrote in message ... Our Aztec's door seal needs replacing. I'm wondering how many people go the inflatable route and what their experience has been. Would you do it again? Does it block noise and air better than the standard seal? Does it push the door away from the frame or cause too much pressure against the latch or the hinge? Electric or hand pump? Best make/model? STC/337/field approval or simple log book entry? Thanks! Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
wrote: Our Aztec's door seal needs replacing. I'm wondering how many people go the inflatable route and what their experience has been. Would you do it again? Does it block noise and air better than the standard seal? Does it push the door away from the frame or cause too much pressure against the latch or the hinge? Electric or hand pump? Best make/model? STC/337/field approval or simple log book entry? Have installed (and flown inside of) both hand and electric versions. Most drastic change I ever noticed was on a 310. The hose blew off as I was giving it a couple of extra pumps and we thought the engine was coming apart. Perhaps the hand bulbs have changed, but the ones I useta put in were identical to a manual blood pressure cuff. Every 100 hr, I took the bulb/valve apart and cleaned off the internal check valve with alcohol. After about 4-5 years, the bulb and the hose had deteriorated and had to be replaced. Put one in a Seneca that had the hand pump clipped to the center console, and had an inflate/deflate "switch" mounted in the panel. The electric models are pretty choice, but you still need to keep an eye out for leaks in the system. Aztec's are prime candidates for being quieted down a bunch by an inflatable seal. BTW, the seals I'm familiar with were STC'd, and with any STC, a maintenance record entry and a 337 (should take yer local IA about 10 minutes to complete and file) are definitely required. On the Aztec's, I seem to remember an exposed aluminum skin edge on the door frame where the seal mates. This may have to be dealt with. Hope some of this helps; TC |
