We've put our first 100 hours on our Aztec since buying it mid-August and
this weekend we had the 50hr and 100hour AD's complied with. Fuel leak inspection (50hrs, pilot can do this one), Fuel valve/cable inspection, Engine mount inspection, Exhaust system inspection. Everything looked good. Since we bought it, we've upgraded the KLN 89B to a KLN 94 and had it IFR certified, replaced one vacuum pump and installed vacuum pump cooling shrouds via a FAA field approval, braced the oil coolers and fixed the leaky baffles, re-insulated the nose and heater compartments, installed the Piper elevator bungee kit, replaced the occasional old vent or drain hose, replaced a bad pitot heat switch, replaced the cabin door lock, and bought a set of new 8 ply main gear tires. We had to pull the pitch control computer from our STec 60-2 due to run away trim in altitude hold mode, it's still out for repairs. The next project on our list is a new one piece windshield, maybe a vertical card compass and electric OAT. On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So far we're pretty happy with our bird. Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.799 / Virus Database: 543 - Release Date: 11/19/2004 |
Congrats, Jim. Sounds like a great plane! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 22-Nov-2004, "Jim Burns" wrote:
On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So, at the high end of the power/fuel consumption curve you are gaining 20 kts TAS for only 3 gph? That's incredible! In my relatively efficient Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75% power. How do you do it? -- -Elliott Drucker |
![]() wrote in message news:nfKod.2604$6m2.1574@trnddc04... On 22-Nov-2004, "Jim Burns" wrote: On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So, at the high end of the power/fuel consumption curve you are gaining 20 kts TAS for only 3 gph? That's incredible! In my relatively efficient Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75% power. How do you do it? -- -Elliott Drucker 27GPH-20GPH=7GPH |
Mike Rapoport wrote:
wrote in message news:nfKod.2604$6m2.1574@trnddc04... On 22-Nov-2004, "Jim Burns" wrote: On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So, at the high end of the power/fuel consumption curve you are gaining 20 kts TAS for only 3 gph? That's incredible! In my relatively efficient Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75% power. How do you do it? -- -Elliott Drucker 27GPH-20GPH=7GPH Huh!?! Are my eyes funny, or doesn't his original post reference *24* GPH at 155 kts vs. 27 GPH at 175 kts? inquiring minds... Scott Skylane |
![]() "Scott Skylane" wrote in message ... Mike Rapoport wrote: wrote in message news:nfKod.2604$6m2.1574@trnddc04... On 22-Nov-2004, "Jim Burns" wrote: On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So, at the high end of the power/fuel consumption curve you are gaining 20 kts TAS for only 3 gph? That's incredible! In my relatively efficient Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75% power. How do you do it? -- -Elliott Drucker 27GPH-20GPH=7GPH Huh!?! Are my eyes funny, or doesn't his original post reference *24* GPH at 155 kts vs. 27 GPH at 175 kts? inquiring minds... Scott Skylane You're right. I guess it is my eyes which are out of whack. They saw 20GPH which is the "short hop" number. Now the numbers make even less sense since I would normally expect to see "short hop" fuel flow higher than the "longer trip" fuel flow and he is also claiming a 13% increase in speed with a 13% increase in fuel flow. I suspect that he uses the mxture lever on some flights but not others Mike MU-2 |
![]() You're right. I guess it is my eyes which are out of whack. You're right. I guess my numbers are out of whack! ![]() I ran though them from memory, which is normally good, but sometimes very short. They saw 20GPH which is the "short hop" number. This is what we are seeing on 1 hour flights with only one take off and landing. Multiple take offs and landings, then numbers get lower due to more time at reduced power. We've actually seen numbers down around 16 for pattern only work. I looked up a round robin flight of 2.1 hours each way, power settings I recorded were 24/24 and fuel tickets showed 90 gallons, so I had one too many 24's in my head, that figures out to 21.4 gallons at 155 True. Longer trips we've been flight planning at 25gph and it's hardly ever that high at normal cruise settings. Speed runs at 175 kts burns 27. So, I believe that we are getting a 13% increase in speed for a 26% increase in fuel burn. Thanks for makeing me look that up and correcting it. One problem we have is the old fuel flow meters are wayyyyyyyy off towards the high side, which I guess may be on the safe side. --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.799 / Virus Database: 543 - Release Date: 11/19/2004 |
wrote in message news:nfKod.2604$6m2.1574@trnddc04... On 22-Nov-2004, "Jim Burns" wrote: On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So, at the high end of the power/fuel consumption curve you are gaining 20 kts TAS for only 3 gph? That's incredible! In my relatively efficient Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75% power. How do you do it? -- -Elliott Drucker 27GPH-20GPH=7GPH No, the 20 GPH was on short hops and no speed is given. 24 GPH is listed along with the 155 speed vs. 27 for 175. I'm with Elliott, this defies physics. This is almost exactly a linear increase, but we all know that drag is not linear with airspeed. Matt |
Matt Whiting wrote in message ...
......... No, the 20 GPH was on short hops and no speed is given. 24 GPH is listed along with the 155 speed vs. 27 for 175. I'm with Elliott, this defies physics. This is almost exactly a linear increase, but we all know that drag is not linear with airspeed. Matt My guess is that the 24/155 was at a lower altitude and the 27/175 is the "true" speed at the higher 6000ft altitude where the air is thinner and less drag per "true" speed. If you could shoot yourself into space you could turn off the engines and get zillion knots for 0 gph. The basic problem is engine aspiration at higher alt. With turbos that is less of a problem. |
![]() Jim Burns wrote: We've put our first 100 hours on our Aztec since buying it mid-August and this weekend we had the 50hr and 100hour AD's complied with. Fuel leak inspection (50hrs, pilot can do this one), Fuel valve/cable inspection, Engine mount inspection, Exhaust system inspection. Everything looked good. Since we bought it, we've upgraded the KLN 89B to a KLN 94 and had it IFR certified, replaced one vacuum pump and installed vacuum pump cooling shrouds via a FAA field approval, braced the oil coolers and fixed the leaky baffles, re-insulated the nose and heater compartments, installed the Piper elevator bungee kit, replaced the occasional old vent or drain hose, replaced a bad pitot heat switch, replaced the cabin door lock, and bought a set of new 8 ply main gear tires. We had to pull the pitch control computer from our STec 60-2 due to run away trim in altitude hold mode, it's still out for repairs. The next project on our list is a new one piece windshield, maybe a vertical card compass and electric OAT. On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push everything forward and we see 175 knots true at around 6000 ft and fuel burns of 27 gallons per hour. Surprisingly close to book numbers for a 38 year old airplane. So far we're pretty happy with our bird. I have a friend who until a month ago had a turbo Aztec. Biggest toilet I have ever seen. Numerous engine failures in icing conditions, turbos that break down with regularity, heaters that don't work, gear that won't go down, or up; the list is endless. I asked him why he didn't buy a Baron in the first place and he said he couldn't afford it. I told him you've already bought a new Baron that came in the shape of an Aztec. He finally did the math and came home with an Aerostar the other day. Now some poor sap has this Aztec to deal with. |
fighter pilot hours? | Cub Driver | Military Aviation | 26 | September 15th 05 02:39 AM |
D-DAY: START ENGINES 0412 HOURS | ArtKramr | Military Aviation | 5 | June 7th 04 05:08 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
