I just noticed today a tendency for my vacuum AI to vibrate a few
millimeters in its pitch axis occasionally, then the movement damps out. The roll and pitch indication seem to be OK, and the vacuum DG is working fine. The vacuum guage is at 5.0, right where it belongs. I'm wondering if this is an early failure indication. -- Regards, Mike http://mywebpage.netscape.com/amountainaero/fspic1.html |
millimeters in its pitch axis occasionally, then the movement damps out. snip I'm wondering if this is an early failure indication. An instrument shop owner told me once that it is. How long it will take to fail is the question. This tech also told me that if you put any gimbaled instrument down on a surface and could hear the case touch the surface you have damaged the bearings. John Dupre' |
On Sat, 27 Nov 2004 17:05:54 -0700, Mike Noel wrote:
I just noticed today a tendency for my vacuum AI to vibrate a few millimeters in its pitch axis occasionally, then the movement damps out. The roll and pitch indication seem to be OK, and the vacuum DG is working fine. The vacuum guage is at 5.0, right where it belongs. I'm wondering if this is an early failure indication. My AI has done this for as long as I have owned the aircraft (coming up on 4 years). Of course the gyro shop said, "Needs overhaul" so last year I sprung for the $200 overhaul. No difference whatsoever. Although it does spin up a lot faster now. Used to take several minutes, now it snaps to attention within 5-10 seconds of engine start. The needle on the vacuum gauge seems to vibrate in sync with the AI, The face of the gauge also seems to be loose, so my latest theory is a leaky gauge causing variations in vacuum level. If this is still the case at the next annual, I may try replacing the gauge. |
"Mike Noel" wrote in message ...
I just noticed today a tendency for my vacuum AI to vibrate a few millimeters in its pitch axis occasionally, then the movement damps out. The roll and pitch indication seem to be OK, and the vacuum DG is working fine. The vacuum guage is at 5.0, right where it belongs. I'm wondering if this is an early failure indication. It's caused by engine or prop vibration. The instrument panel shock mounts might be old and hard, or the prop may need balancing. Either way, the vibration is reaching the indicator. Next time you fly, play with RPM settings to see if you can make the indicator resonate with vibratory fequencies. Dan |
| IVO pireps wanted.. high performance/high speed... | Dave S | Home Built | 8 | June 2nd 04 05:12 PM |
| Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 04:22 AM |
| ram air pressure governed variable pitch prop | Bruce Meacham | Home Built | 4 | April 16th 04 09:42 PM |
| ALTRAK pitch system flight report | optics student | Home Built | 2 | September 22nd 03 12:49 AM |
| Propellor pitch ... | Bob Noel | Owning | 2 | July 29th 03 05:30 AM |
