Hello! I'd like to ask the help of the assembled exeprtise here about the
details of the standard two-sided Cessna masterswitch. I'm rewiring my Pitts to put a B&C alternator in it. I've got a two-sided switch and can't remember which side is the battery side and which is the alternator side. Also, there are two contacts on a couple of points on the switch and i'm not entirely sure what they're for. So, does anyone know where I could get a schematic of the workings of this type of switch? If not, how about just a good explanation of how it works. Failing that, I'd just be happy to be reminded of which is the battery and which is the alternator side. Basically, any info anyone can provide will be greatly appreciated! Cheers, Shawn Pitts S-1D, G-BKVP |
The side that can be switched on by itself is the battery; the side
that is physically interlocked to turn both sides on when activated is the alternator. The idea is that you can have the battery on without the alternator, but you can't have the alternator on without the battery. The battery side controls the coil of the master solenoid, and thereby connects the battery to the main power bus. The alternator side switches the power to the alternator field coils, typically via the voltage regulator and over-voltage relay, and thereby effectivly switches the alternator on or off. |
TACAIR Integration - any details, or speculations only? | [email protected] | Naval Aviation | 0 | November 22nd 04 12:46 PM |
Paint for interior details | Frode Berg | Owning | 1 | June 14th 04 01:19 AM |
BEN GELMAN: WWII BOOK DETAILS AIR CORPS VETERANS' POSTWAR LIVES | Otis Willie | Military Aviation | 0 | October 30th 03 08:08 PM |
Oshkosh Rec.Aviation Get-together details... | Jay Honeck | Home Built | 2 | August 3rd 03 04:31 PM |
Oshkosh Rec.Aviation Get-together details... | Jay Honeck | Owning | 2 | August 3rd 03 04:31 PM |
