Help Needed against proposed rules against gliders at Saratoga County Airport
Old December 16th 11, 12:44 AM posted to rec.aviation.soaring
Tim Hanke
Default Help Needed against proposed rules against gliders at Saratoga County Airport
Saratoga County Officials trying to push 100 glider pilots and two
soaring clubs out of the airport by using object free zones as
excuse.
Anyone run into this? Any ideas here on how to stop them from
finalizing rules?
http://www.saratogian.com/articles/2...0600762759.txt
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
Old December 16th 11, 01:47 AM posted to rec.aviation.soaring
ray conlon
Default Help Needed against proposed rules against gliders at SaratogaCounty Airport
excuse.
finalizing rules?
http://www.saratogian.com/articles/2...ee6b3d6cd5e060...
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
Make contact with your local FAA engineering office and find out who
the airport uses for an engineering firm, and attend all airport board/
commission meetings, check with the SSA and AOPA for input.
Old December 16th 11, 03:00 AM posted to rec.aviation.soaring
lanebush
excuse.
finalizing rules?
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
There is an advisory circular that allows gliders to be towed to and
from the active runway for launch and recovery. It sounds like the
county is allowing that activity. I guess the assembly, disassembly
and parking of trailers is the issue. The butterfly further
complicates a tough situation. I hope it works out OK.
Lane
XF
Old December 16th 11, 06:24 AM posted to rec.aviation.soaring
Frank Whiteley
excuse.
finalizing rules?
http://www.saratogian.com/articles/2...ee6b3d6cd5e060....
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
from the active runway for launch and recovery. *It sounds like the
county is allowing that activity. *I guess the assembly, disassembly
and parking of trailers is the issue. *The butterfly further
complicates a tough situation. *I hope it works out OK.
Lane
XF
The gliders could use the grass, but I'm told the airport only mows it
a couple times annually due to the butterfly habitat. The tall grass
provides additional cover for wild turkeys. The population of blue
butterflies has been dropping. There is speculation that the
increased number of turkeys are eating the blue butterflies. The
original mowing of the airfield grass areas is probably what improved
the survival of the blue butterflies in the first place.
As for wild turkeys, they numbered 30,000 in 1900 due to over
hunting. Today there are 7,000,000.
http://www.usatoday.com/news/nation/...d-turkey_N.htm
Frank Whiteley
Old December 16th 11, 06:23 AM posted to rec.aviation.soaring
Larry Suter
"They’ll then need to tow their aircraft out to the runways
individually using vehicles equipped with flashing yellow lights and
aeronautical radio."
We use golf carts to tow our gliders to the launch point at Byron, CA.
Can be as much as 2000', depending on the wind. Not so bad. At Minden
the tow is even longer and also done with golf carts with flashing
yellow lights and handheld radios.
Larry
excuse.
finalizing rules?
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
Lane
XF
Old December 16th 11, 06:35 AM posted to rec.aviation.soaring
Frank Whiteley
Larry
We had a flashing yellow light on our winch that operated when the
winch was in gear. It was not noticeable from 1500agl nor over 2000ft
laterally on a sunny day. Headlights work much better on ground
vehicles.
Frank Whiteley
Old December 16th 11, 10:40 PM posted to rec.aviation.soaring
John Scott[_3_]
There is an FAA memo that supports glider operations in the Obstacle Free
Area for stagin and launching as well as operations from the grass beside a
runway. However tow vehicles, trailers, and assembled gliders not staging
for launch or not being recovered after landing would need to be outside the
OFA. The memo is on the SSA website at
http://www.ssa.org/files/member/Parallel runway operations.pdf
At our airport, the officals requested all ground vehicles operating on the
runway towing gliders to be equipped with flashing lights. We looked into it
and determined the visiblity during our normal operating period (bright
daylight) of the vehicle with the flashing amber light was the same weather
the light was operating or not. Our proposal to use standard orange and
white ramp flags was accepted. We have several 2" and 1 1/4" hitch
extenders set up with flag poles and flags. This makes it easy to shift
between vehicles and does make the ground tow vehicle much more visible.
John Scott
"Tim Hanke" wrote in message
excuse.
finalizing rules?
Thanks,
Tim Hanke
Adirondack Soaring
e-mail:
Proposed US Competition Rules Changes for 2010 [email protected] Soaring 1 December 17th 09 05:20 PM
2009 Proposed US Contest Rules Changes [email protected] Soaring 70 January 14th 09 03:16 PM
2008 Proposed US Competition Rules Changes [email protected] Soaring 18 December 31st 07 07:21 PM
US Contest Rules Proposed Changes for 2006 Ken Sorenson Soaring 18 January 12th 06 04:30 PM
Proposed 2005 Rules On SRA Site Ken Kochanski (KK) Soaring 79 January 27th 05 06:51 PM
