Blind 430
Old December 29th 04, 02:37 AM
Jim Burns
Default Blind 430
A friend of mine has a 12v Garmin 430 that simply does not pick up the
satellites. It worked fine about 3 weeks ago (the last time he flew) but
now it fails to find any satellite signals. One avionics tech said that it
had "lost it's almanac" and to pull it out and let it sit for a couple hours
and it should pick up the satellites and work fine. No such luck. All
power and antenna connections are good and nothing has happened to the
airplane or the equipment since it flew last. Any ideas? Anybody ever hear
of such a thing?
Thanks,
Old December 29th 04, 12:35 AM
john smith
Tell him to try it outside the hangar. ;-))
of such a thing?
Thanks,
Old December 29th 04, 01:24 AM
Helen Woods
Call Penn Avionics:
http://www.pennavionics.com/
Old December 29th 04, 10:04 AM
Nathan Young
On Tue, 28 Dec 2004 18:37:24 -0800, "Jim Burns"
of such a thing?
The almanac includes a list of parameters that allow the GPS receiver
to determine where to 'look' for each satellite.
Without an almanac (and a valid time reference), the GPS receiver is
forced to brute force search for the satellite PRNs. Older GPS
receivers did not have enough processing power to effectively perform
this brute force search. So they would take 15+ (sometimes much
longer) minutes to 'cold start'.
Newer GPSs have more powerful processing engines, and do much better
on cold starts. I do not know for sure, but would expect a 430 to
have a new enough engine to manage a cold start in ~15 minutes. So
anyway, that is a possibility.
If there is an option for setting the time on the receiver, start with
that. Be sure and set the clock as accurately as you can. Make sure
the plane is outdoors and has a good 'view' of the sky. Pulling it
into a tight row of T-hangars still leaves a lot of the horizon
blocked. It is probably best to take it for a flight.
If the plane is flown for 30 minutes and the 430 doesn't lock, there
is a problem, time to troubleshoot. I would pull the radio and have
an avionics shop bench test it. That way you know if you are dealing
with a radio problem or an antenna/cabling issue. (from your
paragraph above, I am wondering how the antenna and connections were
verified 'good' without getting the GPS to work).
-Nathan
Old December 29th 04, 02:00 PM
Jim Burns
I wouldn't say that the cableing and antenna connections were positively
verified 'good', just that the 430 worked when the airplane was last shut
down and hangered and that there are no visable problems with the cables or
antenna and the connections are snug. This is however the direction he is
checking next. He flew it over to an avionics shop yesterday, unfortunately
the owner was gone. He's had it sitting outside running for over an hour as
well as flown it for over an hour and it still doesn't pick up the
satellites. I'll see if he can set the date and time and try it again.
Thanks,
Old December 29th 04, 02:45 PM
Mike Rapoport
Borrow another 430 and see if it is the box or the installation.
Mike
MU-2
"Jim Burns" wrote in message
or
unfortunately
as
Thanks,
Old December 29th 04, 03:08 PM
Jim Burns
His is a 12v, only other ones around here are 24v. Avionics guy should be
back today.
"Mike Rapoport" wrote in message
ink.net...
Mike
MU-2
shut
or
is
unfortunately
as
Thanks,
Old December 29th 04, 03:31 PM
Mike Rapoport
I think all the recent ones work on either 14 or 28V.
Mike
MU-2
news
back today.
ink.net...
Mike
MU-2
shut
cables
or
is
unfortunately
hour
as
Thanks,
Old December 29th 04, 05:03 PM
Are your tax payments current?
Old January 1st 05, 01:51 AM
tony roberts
It happened to me with my 196.
Finally discovered the problem. The plane had been in the avionics shop
and while there they had dialed a new frequency into the VOR (don't
remember what it was now). After spending lots of time searching and
testing a friend told me to try switching off all of the avionics - and
the gps came back. Turn on the VOR - lose the GPS! After tuning the VOR
back to a local frequency the problem disappeared.
Worth a try before you start spending money!
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
of such a thing?
Thanks,
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
ACK Blind Encoders Henning Dammann-Emden Home Built 5 July 11th 04 04:44 AM
Bush on WMD: None so blind as those who would not see nobody Military Aviation 41 February 10th 04 03:32 AM
God Honest Naval Aviation 2 July 24th 03 04:45 AM
