Cowl plugs for an early 182?
Old January 7th 05, 12:17 AM
Brinks
Default Cowl plugs for an early 182?
I'm looking for a set of cowl plugs for an '57 182. Does anyone have any
suggestions? Thanks!
Chris
Old January 7th 05, 01:14 AM
G.R. Patterson III
Try "Covers by Bruce."
George Patterson
The desire for safety stands against every great and noble enterprise.
Old January 7th 05, 04:31 AM
Jim Burns
I had my wife go to the local fabric store and buy some 3" upholstery foam.
$8 worth of foam and $2 worth of nylon rope made 4 cowl plugs for our Aztec.
Not as fancy as Bruce's, but they work just as well.
"G.R. Patterson III" wrote in message
any
George Patterson
enterprise.
Old January 12th 05, 06:51 AM
rckchp
Make templates from cardboard....get some 1'1/2" to 2' thick closed
cell foam.....put templates on foam and cut with sharp knife (or single
edge razor) cutting slightly larger than templates so they will
compress when installed and make snug fit.....make small slit and push
poly rope thru.....make 2" square thin plywood (or metal) "backing
block with hole for rope....put rope thru backing block and
knot.....use long enough rope to connect both cowl plugs.....not fancy
but cheap and they will work.... not hard to do. Or you can buy set
from Sporty's.............
A tip.....make connecting rope long enough to wrap once around
prop....so that plugs will be pulled out if engine is started with
plugs in place.....don't laugh, several years ago I made set of above
described cowl plugs for club owned Champ. A major airline captain club
member missed the cowl plugs on preflight (if he even did
preflight?)....took off and flew for 1/2 hour with plugs in
place....enough to cook and ruin the cylinders....after
overhaul/rebuild of engine we made connecting ropes and policy to wrap
the rope around the prop
Modern Inventions early Science 1900s airships FA LindaBeynon Aviation Marketplace 0 February 7th 05 12:41 AM
Mooney M20 Preflight and Cowl Jon Kraus Owning 3 November 24th 04 10:21 PM
FS: 182 Cowl Plugs, Pitot Cover, Sunscreens Robert Bullock Aviation Marketplace 0 May 25th 04 05:05 PM
Cowl / Engine Plugs for 1964 C172 Skyhawk - Any Recommendations ??? Philip Aviation Marketplace 0 April 23rd 04 01:32 PM
Early morning hotel-to-airport Bob Fry General Aviation 21 July 25th 03 05:51 AM
