Folks, I'm hoping you can help me diagnose an odd EGT gage behavior.
Background: 1965 Aircoupe with Continental C90-16F engine (has vacuum pump). Plane based in N. California so freezing temps not a factor (pre-heat not needed nor used). Has both a CHT and EGT on different cylinders, with the two-needle combined gage in the cockpit. The CHT works fine, the EGT was working fine until 2-3 months ago. Now, the EGT fairly consistently acts like this: it reads "normal" on cold start, taxi, runup and takeoff. Climbout it reads around 1200 deg F. like it always did. Then, after a few minutes, it starts to fall, and within maybe a minute or two, the needle quivers at the bottom of the scale. It never recovers from that; but at next flight a week or two later the same behavior happens. I never notice any change in engine performance or sound. Would a stuck exhaust value cause this? But wouldn't I notice something from the engine? What else could cause this repeating strange behavior? Maybe it's something heat related? Thanks, Bob |
Bob Fry wrote: Now, the EGT fairly consistently acts like this: it reads "normal" on cold start, taxi, runup and takeoff. Climbout it reads around 1200 deg F. like it always did. Then, after a few minutes, it starts to fall, and within maybe a minute or two, the needle quivers at the bottom of the scale. It never recovers from that; but at next flight a week or two later the same behavior happens. I never notice any change in engine performance or sound. Would a stuck exhaust value cause this? But wouldn't I notice something from the engine? What else could cause this repeating strange behavior? Maybe it's something heat related? seems to be a failed probed, or wire from the probe. Can you get another probe and see if it still behaves this way? Also, check the wire from the probe to the gage. -- Bob Noel looking for a sig the lawyers will like |
Bob Fry wrote: Folks, I'm hoping you can help me diagnose an odd EGT gage behavior. Background: 1965 Aircoupe with Continental C90-16F engine (has vacuum pump). Plane based in N. California so freezing temps not a factor (pre-heat not needed nor used). Has both a CHT and EGT on different cylinders, with the two-needle combined gage in the cockpit. The CHT works fine, the EGT was working fine until 2-3 months ago. Now, the EGT fairly consistently acts like this: it reads "normal" on cold start, taxi, runup and takeoff. Climbout it reads around 1200 deg F. like it always did. Then, after a few minutes, it starts to fall, and within maybe a minute or two, the needle quivers at the bottom of the scale. It never recovers from that; but at next flight a week or two later the same behavior happens. I never notice any change in engine performance or sound. Would a stuck exhaust value cause this? But wouldn't I notice something from the engine? What else could cause this repeating strange behavior? Maybe it's something heat related? Thanks, Bob A bad EGT probe. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Make sure the probe wire isn't shorting out to anything.
You have an electrical problem with the probe, wire to the probe or
the gauge. When something gets hot the resistance goes up and the gage reading falls. Most likely a bad crimp somewhere on one of the electrical connections but could be on any of the connectors or even the gauge itself. On 10 Jan 2005 06:56:36 -0800, Bob Fry wrote: Folks, I'm hoping you can help me diagnose an odd EGT gage behavior. Background: 1965 Aircoupe with Continental C90-16F engine (has vacuum pump). Plane based in N. California so freezing temps not a factor (pre-heat not needed nor used). Has both a CHT and EGT on different cylinders, with the two-needle combined gage in the cockpit. The CHT works fine, the EGT was working fine until 2-3 months ago. Now, the EGT fairly consistently acts like this: it reads "normal" on cold start, taxi, runup and takeoff. Climbout it reads around 1200 deg F. like it always did. Then, after a few minutes, it starts to fall, and within maybe a minute or two, the needle quivers at the bottom of the scale. It never recovers from that; but at next flight a week or two later the same behavior happens. I never notice any change in engine performance or sound. Would a stuck exhaust value cause this? But wouldn't I notice something from the engine? What else could cause this repeating strange behavior? Maybe it's something heat related? Thanks, Bob |
On 10-Jan-2005, Bob Fry wrote: Would a stuck exhaust value cause this? But wouldn't I notice something from the engine? What else could cause this repeating strange behavior? Maybe it's something heat related? It's certainly not a problem with the cylinder. If there were any ignition at all the EGT would be well off of the peg, and if not you would certainly know if from vibration and loss of power. Check he EGT probe, the gauge, and the connections between the two. -- -Elliott Drucker |
| Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 11:20 PM |
| EGT gage oddity; stuck valve, other?? | Bob Fry | General Aviation | 8 | January 11th 05 05:42 AM |
| PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 04:36 AM |
| Stuck valve versus plugged injector | Viperdoc | Owning | 6 | April 13th 04 01:15 AM |
| Q: Disecting a cut-off valve? | Michael Horowitz | Home Built | 0 | March 6th 04 02:47 PM |
