We had 5-6 inches of snow last Thursday followed with a mix of
rain/freezing rain on Saturday. We went to the airport on Sunday arming with shovels, snow brushes, isopropyl alcohol sprayer etc. Right after entering the gate, we glanced at the ramp and was alarmed to see the other Cardinal on the ramp in a tail-down, nose-up position. A quick survey of the tie-down area indicated that this was the same predicament for all high-winged planes with nose wheels. The heavy weight of the snow and ice pushed the tails down with the tailcone and horizontal stabilators glued down to the pavement by a heavy layer of ice. Of course, we found our poor bird in the same noseup position. All the tools which we brought along came handy for the rescue mission. After gingerly lifting up the heavy sheet of ice off the stabilators, I breathed a sign of relief to see the plane got back to the nosewheel-down position. A careful inspection of the stabilator, tailcone and tie-down ring did not reveal any damages. We had thought of this potential problem and had planned to put a tire around the tail tie-down ring but the winter snuck in before we remembered to do so. A careful survey of all tie-down planes in the ramp revealed one unaffected high-winged plane with nose wheel. Rick pointed out to me that this plane was pushed farther back to its tie-down spot such that the tie-down rings were located in front of the wings and tail. The tension of the ropes were what held the plane in the nose-down position inspite of the snow/ice weights. Rick told me that our intructor, Bud Struck, an experienced tailwheel pilot originally from B.C. had told him that it was the way to tie-down the plane during the winter! Our last flight was the one where we experienced icing condition due to an unexpected encounter with freezing rain. Needless to say, we were so relieved to get back to the ground all in one piece. Ensuring proper tie-down was the last thing in our mind!! This was another winter operation lesson for us. Luckily it was a cheap lesson. Except for a good 2 hours or so of careful and tedious work of removing ice and snow off the plane and tie-down area, nothing seemed to be damaged. Hope that the weather will clear up in the next few days for a check-out flight. You can bet that we will spend quite a bit of time in preflight inspection before a takeoff attempt. Hai Longworth |
Matt Whiting wrote: Having snow and ice on the tail dropping the tail to the ground is no big deal and doesn't hurt the airplane at all. Most of the time. The tiedown for my old 150 was made of angle iron embedded in concrete. One year I had apparently parked it with the tail directly over that iron just before a snowstorm. When the tail went down, the iron punched right through the bottom of the rudder. I installed one of those "illegal" fiberglass replacements from Stene (the subject of another recent thread) and piled a couple of old tires over the angle iron. Problem solved. George Patterson The desire for safety stands against every great and noble enterprise. |
Matt,
I did a search on snow damage and found this posting by C J Campbell http://groups-beta.google.com/group/...2?dmode=source in which he described broken tailwheel and damaged tailcones due to heavy snow. We always put wheel chocks to prevent our plane from rolling either way. In seeing the only cessna 172 on the ramp with nosewheel down having tiedown ropes sloping forward convinced us that we should tie down our plane the same way during winter months. |
Matt, No, CJ reported seeing damages due to heavy snow to both types of planes with tailwheel broken off from a C140 and several tricycle planes with tailcone damage. |
| Thread Tools | |
| Display Modes | |
| Winter flying ops | Viperdoc | Owning | 4 | December 24th 04 02:29 AM |
| Winter Cloud Tops | O. Sami Saydjari | Instrument Flight Rules | 5 | January 9th 04 09:11 PM |
| Cessna 172 winter fronts | Paul Young | Owning | 0 | July 30th 03 09:15 PM |
