Hey folks, I am going to ferrying an airplane from Florida to Virginia next
week. This airplane has a Lycoming O-360 and is now using 100 weight oil. The airplane is going to stay in Virginia for several months. Question 1: To the pilots that fly in this, or similar areas, would you recommend switching to a multiweight oil? I've asked two mechanics, one said that I should definitely switch the oil and the other said that 100 weight would be fine and that I would have to just let the engine warm up longer. Question 2: If the answer to the above question is to change the oil, should I have it changed before the trip up from Florida, or wait until I'm here in Virginia? Question 3: Where is a good place to buy oil online or somewhere in Virginia? I can't seem to locate an oil distributor in Virginia that will sell aviation oil by the case to individuals. I've looked into the usual on-line culprits, Aircraft Spruce, Chief, etc. They seem to be about the same price. Question 4: Okay, this one is only sorta oil related. Should I look into a preheater? The airplane will be housed in a non-heated hangar. If you think pre-heating is necessary for the Virginia winter weather, should it be just a sump heater or should I get the core heater too? Thank you for your informative inputs. |
On Wed, 12 Jan 2005 23:39:54 GMT, "
wrote: Hey folks, I am going to ferrying an airplane from Florida to Virginia next week. This airplane has a Lycoming O-360 and is now using 100 weight oil. The airplane is going to stay in Virginia for several months. Question 1: To the pilots that fly in this, or similar areas, would you recommend switching to a multiweight oil? I've asked two mechanics, one said that I should definitely switch the oil and the other said that 100 weight would be fine and that I would have to just let the engine warm up longer. I'd switch to 80. 100 will be a little heavy for most normal winters. This winter has been exceptionally mild, so 100 will probably be fine for the coming months. Question 2: If the answer to the above question is to change the oil, should I have it changed before the trip up from Florida, or wait until I'm here in Virginia? If you change it, I'd change it before you leave. It's warmer in FL and therefore won't be as much of a pain as trying to do it in the cold. Question 3: Where is a good place to buy oil online or somewhere in Virginia? I can't seem to locate an oil distributor in Virginia that will sell aviation oil by the case to individuals. I've looked into the usual on-line culprits, Aircraft Spruce, Chief, etc. They seem to be about the same price. No help on this one, sorry. Question 4: Okay, this one is only sorta oil related. Should I look into a preheater? The airplane will be housed in a non-heated hangar. If you think pre-heating is necessary for the Virginia winter weather, should it be just a sump heater or should I get the core heater too? If you're plane is hangared I'd think a sump heater should be enough to do the trick. Thank you for your informative inputs. HTH. z |
![]() Under questioning a Lycoming service rep once admitted that too thin oil is probably much less damaging than too thick oil. There was a Texas twin many years ago at Aspen that left with a cylinder preheat and start with 50 weight oil on a cold morning. Both engines shelled out on takeoff & all were killed (or so the story went). Don't plan on ever starting it with 50 weight oil under about 50 deg F oil temp. The problem isn't starting. It's getting an adequate fog or spray of lubrication going inside the crankcase. A lot of things go against you with thicker oil. On top of that, oil that blows over the oil pump relief valve doesn't really have access to the hot areas of the engine. At least that's my take on flying to colder areas. |
![]() " wrote in message ink.net... Question 3: Where is a good place to buy oil online or somewhere in Virginia? I can't seem to locate an oil distributor in Virginia that will sell aviation oil by the case to individuals. I've looked into the usual on-line culprits, Aircraft Spruce, Chief, etc. They seem to be about the same price. Believe it or not, some Sam's Club stores have aviation oil. The one I used to go to in North Richland Hills, TX had it by the case. |
I'll try that one. The Lewisville store hasn't had it, nor could they
seem to get it for me. On Wed, 12 Jan 2005 21:14:59 -0400, "Juan Jimenez" wrote: " wrote in message link.net... Question 3: Where is a good place to buy oil online or somewhere in Virginia? I can't seem to locate an oil distributor in Virginia that will sell aviation oil by the case to individuals. I've looked into the usual on-line culprits, Aircraft Spruce, Chief, etc. They seem to be about the same price. Believe it or not, some Sam's Club stores have aviation oil. The one I used to go to in North Richland Hills, TX had it by the case. |
![]() Believe it or not, some Sam's Club stores have aviation oil. The one I used to go to in North Richland Hills, TX had it by the case. Find the SKU's or similar that they use; that will help others get same... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"Juan Jimenez" wrote: " wrote in message ink.net... Question 3: Where is a good place to buy oil online or somewhere in Virginia? I can't seem to locate an oil distributor in Virginia that will sell aviation oil by the case to individuals. I've looked into the usual on-line culprits, Aircraft Spruce, Chief, etc. They seem to be about the same price. Believe it or not, some Sam's Club stores have aviation oil. The one I used to go to in North Richland Hills, TX had it by the case. The price has gone up at Sam's Club. Here in Daytona Beach, 100W used to be $24/case; now it is $32; 15W50 used to be $36, now it is $50/case. Yep -- Sam's Club has Aeroshell here -- even available in 55-gallon drums. |
Aeroshell W100 oil is not 100 weight oil. It is 50 weight. Aeroshell
W80 is 40 weight. The website for shell oil: http://www.shell.com/home/Framework?..._10081019.html Very confusing on Shell's part to name the oil the way they did. Personally, I am a fan of multiweight oil unless you are running in a climate where it never gets below 50 degrees for starting the airplane. Multiweight oil gives better lubrication on cold startups. Even if you live in a warm climate, what if you travel to a colder one, park on the ramp and cold start? |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Diesel aircraft engines and are the light jets pushing out the twins? | [email protected] | Owning | 84 | October 4th 04 06:09 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
