Cherokee fuel tank sender unit "float" -- anybody know where to get these???
Old January 19th 05, 02:03 AM
Chuck
Default Cherokee fuel tank sender unit "float" -- anybody know where to get these???
Hi everyone,
Well, ran into another small problem that is balooning into a major
outlay of cash!
Somehow, the little plastic float in the right hand tank snapped in
two. And no, there haven't been any crash/hard landings lately.
Don't know what the cause was.
Well, after digging the pieces out -- I started calling around to find
a replacement. Of course, no luck. The local Piper dealer wanted to
sell me a whole new sending unit -- I didn't even ask the price on
that. I just couldn't see replacing the whole sender unit to get a
new plastic float (besides, I think my wallet would have a heart
attack at the quote!).
A couple of used parts dealers offered to sell me a used one for $125
plus shipping. Again, replacing the whole unit to get a new float.
Last thing I found -- Airparts of Lock Haven, Pa. They claim that the
FAA requires that the sender unit be sent to them. They will replace
the float, certify the unit, and ship it back -- all for $65. Well,
with no other better choice -- that's the option I took (after
verifying the sender unit really was working correctly).
But I am kinda irked! The FAA "requires" them to replace the float
and certify the unit -- that sound awfully convient !! Here we have a
plastic piece that should cost all of 50 cents. But to get a
replacement, I have to spend $65 for the repair and enough on shipping
to push the repair up to a hundred dollars. This is the kind of
stupidity that is killing GA!
I was wondering if anyone on the list knows about this FAA
"requirement". Or were they just using it as an excuse to get the
work (and not sell direct). And secondly, does anyone know a source
to get these little pieces of plastic???
You see, what irks me the most was the sticker on the back of the fuel
sender unit when it was pulled. A sticker showing Airparts of Lock
Haven, 5/30/02. That means that float came from the same company and
was only 2.5 years old. And when I called the company back about this
little item -- I was told that I'm lucky. The supervisor who talked
to me said that some floats only last a year while others last five
years. Either way, I don't hold out hope that these floats will last
long!
Thanks for any information you might share guys....
Chuck
N7398W
Old January 19th 05, 04:01 AM
Aaron Coolidge
Chuck wrote:
: Hi everyone,
snip
: You see, what irks me the most was the sticker on the back of the fuel
: sender unit when it was pulled. A sticker showing Airparts of Lock
: Haven, 5/30/02. That means that float came from the same company and
: was only 2.5 years old. And when I called the company back about this
: little item -- I was told that I'm lucky. The supervisor who talked
: to me said that some floats only last a year while others last five
: years. Either way, I don't hold out hope that these floats will last
: long!
Hmmm, according to the logs the floats on my fuel senders are 37 years
old with 6400 hours, and are still working great.
Aaron C. (N9376J)
Old January 19th 05, 12:54 PM
Denny
Gotcha beat! The fuel sender floats on Fat Albert the Apache are 1956
vintage, the stencils clearly visible when we inspected the tanks 2
years ago and replaced all the cork gaskets... And the rubber tanks
look like new on the inside with the yellow stencil looking like it was
put on five minutes ago... Amazing... The best hypothesis I can make is
that the plane was always hangared other than on trips, with the tanks
full, or nearly so, much of the time...
That the new floats are lasting as little as a year, is criminal, but I
don't know what you can do about it given FAA regs, etc. well, I do
know, but it means you would attach a non certified float on the end of
the sender arm, not put it on the log, not notify the FSDO, etc., and
we all know you can't do that, so don't even think about it
Denny
Old January 19th 05, 07:52 PM
Michael
"requirement".
Yes. The legal theory is that the float is an instrument. It takes a
certified instrument shop (not just any A&P) to repair an instrument.
Airparts of Lock Haven is a certified instrument shop, your A&P is not.
Not saying it's necessarily valid, but that's the theory they're going
on.
Of course the realistic solution would be to find a plastic float that
looks like the broken one, replace it yourself, not tell anyone, and
not log it. However, this would not be legal.
years.
The floats in my senders are 40 years old, and doing fine. It makes no
sense that a plastic ball should last only a year to five years. I
think it's because these guys are using inferior materials or
procedures. For an FAA certified repair station, that's the norm
rather than the exception.
Michael
Old January 26th 05, 04:35 PM
Since most of you have been having long life and Chuck is not, there
could be a difference in his fuel. I remember a fuel cap I had on a
chainsaw that would swell with gasoline/alcohol fuel blends. No
problems with straight gasoline. Could a similar mechanism be at work
here?
Bob
Old January 27th 05, 03:18 PM
Michelle P
it is not stupidity. it is liability. Have you pulled the tank yet? That
will make the cost of the float seem a little less painful.
New tank hose, new screws. new sender, new gasket, and about four hours
labor to get the tank out and back in.
Have fun.
Michelle
Chuck wrote:
Hi everyone,
outlay of cash!
long!
Chuck
N7398W
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
