http://www.alexisparkinn.com/skycraf...ing_lights.htm
The pictures don't capture all the nitty gritty details of the installation. A couple of things to note: 1. The wiring does NOT go inside the wings, but is rather routed inside a flexible conduit that gets attached to the wing ahead of the ailerons and flaps. This makes the installation much easier, but take note: If you have gap seals, removing the aileron makes the install much easier. 2. Running the wires up to the panel means taking the right side panels out of your interior. 3. Installing the split "L/R" switch into the "bank" of switches (near the existing landing light switch) is a real sonuvabitch. Removing that "bank" of switches is done by removing two screws in the face of the panel, and removing more screws that are accessible only by removing your bottom-most radio. Once the "bank" of switches is removed, you can more easily remove the individual switches from the "bank". 4. We opted to relocate our seldom-used pitot heat switch out of the "bank" and off on its own, about four inches to the right. This was a real "Dremel-tool" special job, and requires a skilled sheet-metal guy -- which my A&P luckily is. We then put the landing light switch where the pitot heat switch was. 5. As with so many installations, our headphone jacks were installed using two vacant circuit breaker holes. These needed to be relocated so that the new landing light circuit breakers could be added. I moved these jacks to the right of the new pitot heat switch, just to the left of the heater controls. 6. Because of the extensive nature of this installation, we opted to do our annual inspection at the same time, which turned out to be a good idea. I don't have the final bill yet, and I'll be taking some more pix to add to the webpage later today, but hopefully this will help you guys who are "sitting on the fence" with regards to these lights. -- Jay Honeck Iowa City, IA Pathfinder N56993 http://www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I don't have the final bill yet, and I'll be taking some more pix to add to the webpage later today, but hopefully this will help you guys who are "sitting on the fence" with regards to these lights. Wow, those lights are nice. If you think of it, post a picture of the panel switches to your website, too. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
On 2005-02-05, Jay Honeck wrote:
http://www.alexisparkinn.com/skycraf...ing_lights.htm On that page you mention: One major deficiency of the Piper Cherokee is the single, nose-mounted landing light. [...] Really the only choice for tip tank-equipped Cherokee owners is the Skycraft landing light kit, which cuts the landing lights right into the leading edge of both wings, similar to the Piper Comanche's lights. The funny thing is that Comanche owners complain about the black hole directly in front of the airplane, and there have been several efforts (with varying success) to add a nose light. I think there's an active STC for the twin but the guy working on an STC for the single gave up. BTW, now that you have multiple lights, you might look into the different styles of 4509 bulbs. Many Comanche owners use a Q4509 (which is more of a spot) on the landing light. -- Ben Jackson http://www.ben.com/ |
![]() BTW, now that you have multiple lights, you might look into the different styles of 4509 bulbs. Many Comanche owners use a Q4509 (which is more of a spot) on the landing light. Yeah, I've got the Q4509 in the nose, but Skycraft recommends using the regular 4509s in the wings, because they provide a broader spread of light. I've still got to play with aiming the lights, so we'll see if I stick with the standard 4509 over time. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Nice pics Jay.. You always do a great job of documentsinig things with
pictures. It looks like your prop is chrome in some of the pictures... Is that just an optical illusion? Jon Kraus PP-ASEL-IA '79 Mooney 201 4443H Jay Honeck wrote: http://www.alexisparkinn.com/skycraf...ing_lights.htm The pictures don't capture all the nitty gritty details of the installation. A couple of things to note: 1. The wiring does NOT go inside the wings, but is rather routed inside a flexible conduit that gets attached to the wing ahead of the ailerons and flaps. This makes the installation much easier, but take note: If you have gap seals, removing the aileron makes the install much easier. 2. Running the wires up to the panel means taking the right side panels out of your interior. 3. Installing the split "L/R" switch into the "bank" of switches (near the existing landing light switch) is a real sonuvabitch. Removing that "bank" of switches is done by removing two screws in the face of the panel, and removing more screws that are accessible only by removing your bottom-most radio. Once the "bank" of switches is removed, you can more easily remove the individual switches from the "bank". 4. We opted to relocate our seldom-used pitot heat switch out of the "bank" and off on its own, about four inches to the right. This was a real "Dremel-tool" special job, and requires a skilled sheet-metal guy -- which my A&P luckily is. We then put the landing light switch where the pitot heat switch was. 5. As with so many installations, our headphone jacks were installed using two vacant circuit breaker holes. These needed to be relocated so that the new landing light circuit breakers could be added. I moved these jacks to the right of the new pitot heat switch, just to the left of the heater controls. 6. Because of the extensive nature of this installation, we opted to do our annual inspection at the same time, which turned out to be a good idea. I don't have the final bill yet, and I'll be taking some more pix to add to the webpage later today, but hopefully this will help you guys who are "sitting on the fence" with regards to these lights. -- Jay Honeck Iowa City, IA Pathfinder N56993 http://www.AlexisParkInn.com "Your Aviation Destination" |
pictures. It looks like your prop is chrome in some of the pictures... Is that just an optical illusion? Nah, it's polished aluminum. We stripped and polished it a couple of years ago, and I think it's one of the nicest cosmetic mods we've done. Pleasantly, we've found that we can polish it maybe once a month, and it retains that nice shine. Of course, it's got about 30 layers of polish on it by now... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
Landing Light CB | Hankal | Owning | 25 | August 25th 04 02:22 AM |
C-172 landing light switch | JFLEISC | Owning | 10 | May 5th 04 11:05 PM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
