My aircraft radio doesn't go that high!
Jim Weir wrote: Just a friendly reminder... The airborne simplex national calling frequency is the same as the ground frequency...146.520. This frequency also works well on the ground at Oshkosh. Rarely is it busy for more than a couple of minutes at a time. For the repeater frequencies, pick up a copy of the Oshkosh Frequency List downloadable from the home page at www.rstengineering.com Listen for me and give me a shout...N 73 CQ BlueOnBlue 182. To Nebraska on Sunday, to St. Louis on Monday, to Oshkosh on Tuesday, weather gods willing. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
My radio does! However when you key up on 34-94 all you hear is
squeal from 50 repeaters at the same time. :-( 146.52 works VERY well into a 10,000 ft high antenna with 1db coax loss. John On Tue, 01 Jul 2003 13:22:26 -0400, Warren & Nancy wrote: My aircraft radio doesn't go that high! Jim Weir wrote: Just a friendly reminder... The airborne simplex national calling frequency is the same as the ground frequency...146.520. This frequency also works well on the ground at Oshkosh. Rarely is it busy for more than a couple of minutes at a time. For the repeater frequencies, pick up a copy of the Oshkosh Frequency List downloadable from the home page at www.rstengineering.com Listen for me and give me a shout...N 73 CQ BlueOnBlue 182. To Nebraska on Sunday, to St. Louis on Monday, to Oshkosh on Tuesday, weather gods willing. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
wrote in message ... My radio does! However when you key up on 34-94 all you hear is squeal from 50 repeaters at the same time. :-( 34-10-4 as we call it around here isn't much better on the ground :-) Repeater operation is going to be a problem in most parts of the country on 2 meters. Just far too congested. Simplex is the way to go in the air. |
This brings up a question I hadn't thought of.
Are there FCC/FAA rules regrarding operation HAM radios from experimental aircraft. Thanks |
Only FAR 91.3 and 91.21. Other than that, the FCC could give a rat's hiney less
where the radio is so long as the operator has the appropriate class of amateur license for the mode being used. Jim John Mireley shared these priceless pearls of wisdom: -This brings up a question I hadn't thought of. -Are there FCC/FAA rules regrarding operation -HAM radios from experimental aircraft. - -Thanks Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Oshkosh Pictures are up.. | Dennis | Home Built | 0 | August 8th 04 04:52 PM |
| Oshkosh Pictures are up.. | Dennis | Instrument Flight Rules | 0 | August 8th 04 04:52 PM |
| How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 01:05 AM |
| Oshkosh 2003 Redux | Montblack | Owning | 86 | August 14th 03 05:29 PM |
| CQ Oshkosh, CQ Oshkosh | Warren & Nancy | Home Built | 4 | July 3rd 03 07:42 PM |
