Don't waste your energy flying over the lake. It will only take a few
extra minutes to fly around it and the scenery is great (if the haze isn't too bad). Fly direct Gary and then up the lake shore. Maybe we'll end up doing just that; at this moment I'm just considering what's available. Chances are we'll be on an IFR plan (esp. in case of MVFR vis.) In this case, we don't want to accept long overwater routing w/o the survival gear aboard. My understanding is that, due to the area airspace congestion during Oshkosh, the more options you have available to accept safely, the better. I don't think I could survive 2 hours in that water. The water is cold even in the summer. Hypothermia is not fun. A number of years ago the army lost a few soldiers in Florida due to hypothermia. They were wet, but not in the water. It was 50 degrees out. They died of hypothermia. Cold and wet is very bad. I agree. My personal tried limits in a swimsuit are 22*C for 2 hours, after which I was standing about 1/2hour in a warm shower in order to stop shivering. I understand that it can easily be colder than 20* in the lake, I doubt I'll survive that on my own (maybe with some immediate hypothermia treatment right after that?) I don't think my clothes will add a lot of protection. (Lower than 13* means I can't breathe in the water...) |
![]() "Tom Fleischman" wrote in message rthlink.net... Why fly over the lake at all. Now that Meigs is gone you can fly along the shoreline under the Class B shelf between Gary, IN and Kenosha, WI. Even when Meigs was there, it wasn't a problem to fly the shoreline. The tower dealt with as many transits as they did with landing operations. None of the towers along the lake gave us any problems. We have extended conversations with the Gary controller (we seem to get the same one most times). We even stopped in at Gary for a bathroom stop one year. |
![]() Tom Fleischman wrote: Coming up from Philly that would seem the most direct route in any event. The most direct route cuts over two of the lakes and part of Ontario. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
Be sure you read the NOTAMs on IFR flights into OSH. You must have a slot
reservation and hit the arrival window within 15 minutes of your projected time. This reservation must be filed days in advance since there are only so many slots per day. "Vassilii Khachaturov" wrote in message om... Chances are we'll be on an IFR plan (esp. in case of MVFR vis.) In this case, we don't want to accept long overwater routing w/o the survival gear aboard. My understanding is that, due to the area airspace congestion during Oshkosh, the more options you have available to accept safely, the better. |
![]() "JerryK" wrote in message ... Be sure you read the NOTAMs on IFR flights into OSH. You must have a slot reservation and hit the arrival window within 15 minutes of your projected time. This reservation must be filed days in advance since there are only so many slots per day. You can always just cancel once you get over land and go to Ripon with the VFR arrivals. We had a running battle with MKE approach about when we were going to cancel IFR (we were a little reticent to do so until we got over land). I'm told that they're a bit more lenient with your arrival time (provided you have a reservation at all) than the NOTAM would have you believe. |
Thanks for your reminder. In preparation I've read some interesting NTSB entries from the last several years, and they convinced me to learn the NOTAM, and think about CRM on arrival. We'll try flying in a less busy place first to see if the duties split we think of right now will safely work. As for the NOTAM, I'm reading it every other day for the last couple of weeks already, along with my chair-flying evening sessions ![]() reservation and hit the arrival window within 15 minutes of your projected time. This reservation must be filed days in advance since there are only so many slots per day. The slot is there waiting for the arrival last 2 months already ![]() We'll cancel it if we know it is going to be very good & sure VFR. |
![]() "Vassilii Khachaturov" wrote in message m... Be sure you read the NOTAMs on IFR flights into OSH. You must have a slot Thanks for your reminder. In preparation I've read some interesting NTSB entries from the last several years, and they convinced me to learn the NOTAM, and think about CRM on arrival. We'll try flying in a less busy place first to see if the duties split we think of right now will safely work. IFR arrivals usually are dumped out over Lake Winnebago for a straight in for 27. You will be merging in with the VFR arrivals that are flying downwind-base-final on the north side of the runway. |
P.P.S. Responses along the lines "you folks are paranoid, you'll only be 15-25 minutes overwater without a shore you can glide to, so don't take any flotation gear aboard" will be ignored. Why? That would seem to be the most obvious solution to this dilemma you are trying to put yourself in. Not being a smartass, I really wanna know what your reasoning is. -- Jim Fisher |
![]() Jim Fisher wrote: Not being a smartass, I really wanna know what your reasoning is. Seems to me that he regards any risk of going down in that water without PFDs as being unacceptable. He's PIC, he's completely responsible for deciding what's an acceptable risk. Me, I accept the fact that, if I go down in Lake Michigan, I'm going to die. That's a risk I have taken. I will not criticise someone else for being unwilling to do so. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
"G.R. Patterson III" wrote in message
Seems to me that he regards any risk of going down in that water without PFDs as being unacceptable. He's PIC, he's completely responsible for deciding what's an acceptable risk. I mis-spoke. I was really asking why we would not simply avoid flying out of gliding distance of a shoreline. Many other posters in this thread seem to think this option is so easily done that I would not hesitate choosing a waterless route. -- Jim Fisher |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Life Vests - Buy or Rent | Victor J. Osborne, Jr. | Owning | 9 | October 18th 04 11:23 AM |
hi-speed ejections | Bill McClain | Military Aviation | 37 | February 6th 04 09:43 AM |
