Received this in the post today.
.............. New 747-800 Escape Slides Here is a very interesting picture of the new 747-8I with the new Air Cruisers door 1 and upper deck escape slides deployed. We are currently doing FAA repeatability testing on this airplane, which requires five deployments from each door using the same slide. We are about half-way through the tests but have to wait until late next week to finish up since the airplane is now being prepared for it's Paris Air Show fly-in on June 20th. The upper deck slides are a new and unique patented design that features the arch tubes. Traditional slides use many large cross tubes and tension straps on the bottom of the slide to give it beam strength. Beam strength prevents the slide from buckling under the load of evacuating passengers. In this case the slide needs to hold several thousand pounds and not buckle. This slide is over 45-feet long. The typical arch bridge type construction provides the necessary beam strength for a large slide at less weight and reduced pack volume. Good view of the racked wing tips too. |
Sorry, I should have added. Photographer unknown.
"Diesel" wrote in message u... Received this in the post today. ............. New 747-800 Escape Slides Here is a very interesting picture of the new 747-8I with the new Air Cruisers door 1 and upper deck escape slides deployed. We are currently doing FAA repeatability testing on this airplane, which requires five deployments from each door using the same slide. We are about half-way through the tests but have to wait until late next week to finish up since the airplane is now being prepared for it's Paris Air Show fly-in on June 20th. The upper deck slides are a new and unique patented design that features the arch tubes. Traditional slides use many large cross tubes and tension straps on the bottom of the slide to give it beam strength. Beam strength prevents the slide from buckling under the load of evacuating passengers. In this case the slide needs to hold several thousand pounds and not buckle. This slide is over 45-feet long. The typical arch bridge type construction provides the necessary beam strength for a large slide at less weight and reduced pack volume. Good view of the racked wing tips too. |
On 3/07/2011 6:38 PM, Diesel wrote:
Received this in the post today. ............. New 747-800 Escape Slides Here is a very interesting picture of the new 747-8I with the new Air Cruisers door 1 and upper deck escape slides deployed. We are currently doing FAA repeatability testing on this airplane, which requires five deployments from each door using the same slide. We are about half-way through the tests but have to wait until late next week to finish up since the airplane is now being prepared for it's Paris Air Show fly-in on June 20th. The upper deck slides are a new and unique patented design that features the arch tubes. Traditional slides use many large cross tubes and tension straps on the bottom of the slide to give it beam strength. Beam strength prevents the slide from buckling under the load of evacuating passengers. In this case the slide needs to hold several thousand pounds and not buckle. This slide is over 45-feet long. The typical arch bridge type construction provides the necessary beam strength for a large slide at less weight and reduced pack volume. Good view of the racked wing tips too. WOW! Considering the length of the upper units, the curved sections are probably to keep the slides rigid. Still, looks like a walk bridge over a small stream. |
![]() "Alan Erskine" wrote in message ond.com... On 3/07/2011 6:38 PM, Diesel wrote: Received this in the post today. ............. New 747-800 Escape Slides Here is a very interesting picture of the new 747-8I with the new Air Cruisers door 1 and upper deck escape slides deployed. We are currently doing FAA repeatability testing on this airplane, which requires five deployments from each door using the same slide. We are about half-way through the tests but have to wait until late next week to finish up since the airplane is now being prepared for it's Paris Air Show fly-in on June 20th. The upper deck slides are a new and unique patented design that features the arch tubes. Traditional slides use many large cross tubes and tension straps on the bottom of the slide to give it beam strength. Beam strength prevents the slide from buckling under the load of evacuating passengers. In this case the slide needs to hold several thousand pounds and not buckle. This slide is over 45-feet long. The typical arch bridge type construction provides the necessary beam strength for a large slide at less weight and reduced pack volume. Good view of the racked wing tips too. WOW! Considering the length of the upper units, the curved sections are probably to keep the slides rigid. Still, looks like a walk bridge over a small stream. Remember seeing Qantas doing a test on B747 at the Mascot Jet Base a few years back and the LAMEies sticking different coloured tape on the apron. I asked what was that all about and was told they were laying bets as to where the slide would end up when deployed. More exciting than two flies on a wall. Avsec |
Gliding lecture slides | Richard Lancaster | Soaring | 22 | April 20th 10 02:30 AM |
USN & USAF 1940/50s glass slides | pkstore2 | Piloting | 0 | May 26th 05 10:10 AM |
FA: A-10 and F-14 slides | THE RIPPER | Aviation Marketplace | 0 | August 26th 04 06:37 AM |
Rod Machado PPL Slides For Sale | Curtis | Instrument Flight Rules | 0 | December 13th 03 05:48 AM |
Rod Machado PPL Slides For Sale | Curtis | Products | 0 | December 13th 03 05:48 AM |
