Garmin 196 firmware updated to v3.0
Old July 24th 03, 11:37 PM
Aloft
Default Garmin 196 firmware updated to v3.0
http://www.garmin.com/support/download.jsp
Changes from version 2.07 to 3.00:
--Limited the number of aircraft types that can be saved on the 'Aircraft'
tab page to ten.
--Corrected intermittent aviation database read error.
--Corrected VNAV capture option.
--Improved takeoff detection to correct the landings count in the automatic
flight log.
--Added tide support for European and Australian tides version 5.0.
--Changed vertical speed display for better resolution when using
meters/second.
--Added the ability to display the next turn on the 'Turn Review' page by
using the UP and DOWN cursor keys during autoroute navigation.
--Added duplicate interstate name support for interstate exit searches.
--Added the ability for the user to change the style of a saved track on the
screen. Saved tracks may be displayed in one of 16 different line styles.
--Improved WAAS/EGNOS satellite selection algorithm to select the satellite
with the most beneficial corrections given the unit's current position.
Units will not use a WAAS/EGNOS satellite if the unit's current position is
outside of a given WAAS/EGNOS satellite's service volume.
--Corrected problem that caused large routes to be truncated when loading
from MapSource.
--Corrected problem drawing the next route leg on the map when the route leg
is sequenced.
--Corrected problem that caused excessive delays drawing the map when using
Atlantic BlueChart version 5.
Old August 4th 03, 09:41 AM
DeltaDeltaDelta
thanks for the info.
Triple Delta
"Aloft" wrote in message
tab page to ten.
automatic
flight log.
meters/second.
satellite
is
from MapSource.
leg
is sequenced.
using
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 09:03 AM
who moved SAV, forgot to tell Jepp? Dave Butler Instrument Flight Rules 15 November 9th 03 02:16 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
