Well folks, I hope I'm not opening up a can of worms on this. I searched
the usenet archives on google about this, and nothing quite answered my question, so... I emailed Skystar, but want to ask here too. The kit manufacturer claims a 150mph cruise and 160mph top speed. This seems a little optimistic. This is a side-by-side 2 seater, 100-115hp engine (turbo maintains output to 16,000 feet), approx 1500lbs gross weight (about 750 empty). The 100hp normally aspirated engines list 120 and 125mph for cruise and max respectively. So it doesn't quite add up... Has anyone backed this up in practice? I did some rough calculations on scratch paper. The short answer is it _might_ be possible. Taking into account the turbo engine's higher output at high altitude, and that the non-turbo aircraft probably max out TAS at about 5,000ft compared to over 10,000 for the turbo, air density's effect on profile drag vs induced drag, air density effect on the normally aspirated engines... Again, my best answer is... maybe. Thanks for any help. |
That's about what the Wittman Tailwind does with 100 hp.
It too is a side by side high wing - with a wing strut. Jim Carriere wrote: Well folks, I hope I'm not opening up a can of worms on this. I searched the usenet archives on google about this, and nothing quite answered my question, so... I emailed Skystar, but want to ask here too. The kit manufacturer claims a 150mph cruise and 160mph top speed. This seems a little optimistic. This is a side-by-side 2 seater, 100-115hp engine (turbo maintains output to 16,000 feet), approx 1500lbs gross weight (about 750 empty). The 100hp normally aspirated engines list 120 and 125mph for cruise and max respectively. So it doesn't quite add up... Has anyone backed this up in practice? I did some rough calculations on scratch paper. The short answer is it _might_ be possible. Taking into account the turbo engine's higher output at high altitude, and that the non-turbo aircraft probably max out TAS at about 5,000ft compared to over 10,000 for the turbo, air density's effect on profile drag vs induced drag, air density effect on the normally aspirated engines... Again, my best answer is... maybe. Thanks for any help. |
Jim Carriere wrote:
Well folks, I hope I'm not opening up a can of worms on this. I searched the usenet archives on google about this, and nothing quite answered my question, so... I emailed Skystar, but want to ask here too. The kit manufacturer claims a 150mph cruise and 160mph top speed. This seems a little optimistic. This is a side-by-side 2 seater, 100-115hp engine (turbo maintains output to 16,000 feet), approx 1500lbs gross weight (about 750 empty). The 100hp normally aspirated engines list 120 and 125mph for cruise and max respectively. So it doesn't quite add up... Has anyone backed this up in practice? I did some rough calculations on scratch paper. The short answer is it _might_ be possible. Taking into account the turbo engine's higher output at high altitude, and that the non-turbo aircraft probably max out TAS at about 5,000ft compared to over 10,000 for the turbo, air density's effect on profile drag vs induced drag, air density effect on the normally aspirated engines... Again, my best answer is... maybe. Thanks for any help. Yep, 150mph is possible in a KitFox. I've got one. You've gotta' go high to get the TAS up there, but with the turbo is doable. (I've got a turbo, but not flying yet). The SkyStar demo ship put up those numbers on the way to Sun N Fun. Other turbo drivers report about the same thing. Down low though, you're TAS will be in the 130+ mph range. Hope this helps, Ron KitFox Series 6, NSI turbo, CAP 140 -- ************************************************** ******** Ronald K. Stevens The MITRE Corporation Center For Advanced Aviation System Development (CAASD) Air-Ground Simulation Development 7515 Colshire Drive M/S N420 McLean, VA 22102-7508 http://www.caasd.org Voice: 703-883-6629 Fax: 703-883-1917 ************************************************** ******** |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
Hair on the palm of my hand; was Jets: Takeoff performance questions | pac plyer | Home Built | 1 | July 2nd 03 02:14 PM |
