Great circle formulae, True cource and actual heading
Old October 8th 03, 12:06 AM
Sims
Default Great circle formulae, True cource and actual heading
Hi,
I am trying to write a formula to compute flight headings.
If i use 2 lat/lon i can get a "true course" but due to magnetic variations
the true course is not really all that useful, (knowing that my true course
is 118deg will not tell me that i should fly 93 deg).
What i mean is if i go from A to B i can calculate the True course, ('tc')
but my actual heading varies a lot depending on my position along the
course.
Is there a reliable formula to calculate my actual heading at a certain
point along the course?
Many thanks in advance.
Sims
Old October 8th 03, 01:06 AM
Dave Patton
"Sims" wrote in
Hi,
variations the true course is not really all that useful, (knowing
that my true course is 118deg will not tell me that i should fly 93
deg).
('tc') but my actual heading varies a lot depending on my position
along the course.
certain point along the course?
Sims
At least in sci.geo.satellite-nav this sort of question about
formulae has been asked numerous times, including quite recent
threads, so a search via Google Groups would likely have already
found you your answer.
Take a look at Ed Williams page about Aviation Formulary:
http://williams.best.vwh.net/avform.htm
Dave Patton
Canadian Coordinator, the Degree Confluence Project
http://www.confluence.org dpatton at confluence dot org
My website: http://members.shaw.ca/davepatton/
Vancouver/Whistler - host of the 2010 Winter Olympics
Old October 8th 03, 01:20 AM
Dale DePriest
Sims wrote:
Hi,
course.
Sims
You mean your magnetic heading. You have your actual heading. You need
a table of magnetic variations and interprolate from the table based on
your location as there is no mathmatical model that will provide this
information reliably.
Dale
_ _ Dale DePriest
/`) _ // http://users.cwnet.com/dalede
o/_/ (_(_X_(` For GPS and GPS/PDAs
Old October 8th 03, 02:05 AM
Craig Prouse
Dale DePriest wrote:
You need
Given a table of magnetic variations at known locations, there are
statistical methods to derive a useful mathematical model. The web site
cited in a previous article provides such a model as a polynomial.
http://williams.best.vwh.net/avform.htm#Var
Old October 8th 03, 08:42 PM
Randolph J. Herber
You need
http://geomag.usgs.gov/chartsdo.html
http://geomag.usgs.gov/models.html
http://www.ngdc.noaa.gov/IAGA/wg8/igrf.html
http://www.ngdc.noaa.gov/IAGA/wg8/table1.txt
http://www.freewarepalm.com/calculator/magcalc.shtml
http://www.garmin.com/manuals/GPSIII...nersManual.pdf page 78 (in document)
(page 88 in pdf file) gives 4 heading adjustment choices: auto magnetic
(using a magnetic field model driven by the current location), true, grid
(driven the UTM locatin) or user magnetic (the user states the desired
adjustment). I suppose that you could use this to include a wind adjustment?!
Other than that; get your aviation weather report and your E6B.
Randolph J. Herber, , +1 630 840 2966, CD/CDFTF PK-149F,
Mail Stop 318, Fermilab, Kirk & Pine Rds., PO Box 500, Batavia, IL 60510-0500,
USA. (Speaking for myself and not for US, US DOE, FNAL nor URA.) (Product,
trade, or service marks herein belong to their respective owners.)
red rover
"Dale DePriest" wrote in message
I found the post a little confusing because it seemed to be mixing
the problem of the course heading changing due to the great circle
route (mentioned in the subject) with heading changes due to changing
declination mentioned in the body. Two very different issues.
Steve
Old October 8th 03, 02:37 AM
Dale DePriest
Steve
Yes, it was my mistake, I misread the original post by not comparing the
text to the subject line. I tried to cancel but too late, Sorry
Dale
_ _ Dale DePriest
Old October 8th 03, 04:08 AM
red rover
Dale
Well I actually meant the original post was confusing, not your
reply.
Old October 8th 03, 07:29 AM
Sims
"red rover" wrote in message
(Sorry to reply here your post was cancelled).
Yes i do mean the magnetic heading.
Sorry I was not clear.
Where can i get a table to compute my magnetic heading?
Thanks
Sims.
Old October 8th 03, 03:30 PM
Dale DePriest
Try here for a start.
http://www.ngdc.noaa.gov/seg/WMM/DoDWMM.shtml
Dale
Thanks
Sims.
_ _ Dale DePriest
