Hot Starting Fuel Injected Engines
Old October 14th 03, 07:04 PM
Peter Duniho
Default Hot Starting Fuel Injected Engines
"Corky Scott" wrote in message
With my last experience, the engine actually went into hydraulic lock
without me touching the controls or using the auxiliary fuel pump.
The prop barely turn half a turn before it stopped and the starter
couldn't crank it anymore.
I'm not sure what exactly is going on here, but I don't think it's
"hydraulic lock". As a previous post hinted at, "hydraulic lock" is
something that is specific to only certain kinds of engines (like radials)
and not those found in C172's. It happens when oil drains into the
cylinder, putting an incompressible substance into a space that wants to
compress when the engine turns.
If you are having trouble with the starter not being able to turn the engine
on a C172, you've either got a dead battery, or something worse is going on.
When you first wrote "hydraulic lock", I actually assumed you meant "vapor
lock", which is what happens when the fuel in the fuel lines is heated to
the point of vaporization, preventing it from being pumped to the engine.
This is the usual problem when starting hot engines, especially fuel
injected ones (carbureted engines usually have enough fuel in the float bowl
to let things get sorted out during engine start, so even a little vapor in
the fuel lines won't cause a problem with starting).
But now it sounds like you did actually mean something other than "vapor
lock". I'm not sure what it was, but I'm pretty certain that, given that
you're talking about a C172, it wasn't "hydraulic lock". Even if hydraulic
lock were possible on a C172, it wouldn't be related to a hot engine start.
There are actually two fuel pumps, one works with the engine turning,
the other is the electric auxiliary pump. So fuel will be pumped to
the injectors the moment the engine starts turning.
I'm not familiar with the new fuel-injected C172's, but it's entirely
possible that with the electric fuel pump running, fuel will be pumped to
the injectors and even into the engine the moment the fuel pump is turned
on, regardless of whether the engine is turning or not. That's how the
fuel-injection system for the Lycoming 540 engine in my plane works.
Pete
Old October 14th 03, 07:40 PM
Jeremy Lew
engine
on.
I had the same problem hot-starting a PA32-300 recently. Let sit for a
minute or two, starter was able to crank again. It was the only hot start
I've had to do (so far) in that plane, and the only one where cranking was a
problem. I don't think there's anything wrong with the battery or the
starter, it was some transient condition of the engine.
Jeremy
Old October 14th 03, 07:24 PM
Corky Scott
On Tue, 14 Oct 2003 11:04:46 -0700, "Peter Duniho"
Pete
Pete, I'm assuming it's hydraulic lock because the starter cranked the
prop around half a turn and then jerked abruptly to a stop. I
re-engaged the starter and it tried to turn the prop but wouldn't. I
waited a second and tried again and it turned the prop another half to
3/4's of a turn and jerked to a stop again.
I did not get out an look to see if gas was pouring out of the exhaust
stacks. But once I advanced to full throttle, the starter, after a
few more attempts, began to turn the engine over at a normal rate.
After a few seconds of this, one of the plugs fired and I thought we'd
be ok, but it still didn't start.
I waited another several seconds and re-engaged the starter and this
time, as it spun the prop, it actually briefly fired up on all
cylinders. I moved quickly to slap the mixture in, as the engine had
quit again but the prop was still windmilling, and just before the
prop stopped, the engine caught for good.
I was an auto mechanic in a previous life and have seen hydraulic lock
before. I know no other way of describing it.
Corky Scott
Old October 14th 03, 08:26 PM
Peter Duniho
prop around half a turn and then jerked abruptly to a stop. [...]
Well, like I said, I haven't flown the new C172's, so don't have any
personal experience with that particular engine installation. IMHO, if that
engine IS experiencing hydraulic lock, that's a problem though.
Oil should not be draining into the cylinders. On the 540 engine in my
airplane, excess fuel that gets into the cylinders will drain out the intake
manifold, and then out a valve that leads to the outside of the airplane.
I've made plenty of hot starts, including many that were really flooded
starts (per the technique described by Robert Gary ), and never had any
problem with the starter turning over the engine.
I've never experienced anything that could be considered hydraulic lock in
any of the fuel-injected horizontally opposed engines I've ever flown.
That's not a huge number of different airplane/engine combinations (perhaps
a dozen or two over the years), but it's enough that I'd think I'd have
noticed the problem you're describing if it were common and normal.
I can't think of any mechanism by which you'd experience hydraulic lock on
the fuel-injected horizontally opposed engine that's in the new C172, and I
would think that if you DID experience that, it would be worth discussing
with the mechanic who maintains the airplane.
Pete
Old October 14th 03, 10:19 PM
I think he's considering the fact that the starter can't turn the engine
over makes it a hydralic lock. Similar to a hot car engine with the timing
too far advanced. In that case, the spark happens so early that the crank
stops or backs up before it reaches TDC. I wouldn't call that a hydralic
lock though, but I think that's what he is referring to.
The air in the cylinder gets hot and starts expanding as the piston is
trying to compress it as well, and with enough heat, you can get a
preignition from just the air fuel mixture too. Dieseling kind of. Another
example is too much ether in a diesel, a ether lock. Either way, the starter
is unable to overcome the compression of the engine while it is hot.
Quickest way I know around it is to have an assistant, hand-prop-assist the
starter. Safer overall though to just wait for it to cool.
that
intake
(perhaps
I
Pete
Old October 14th 03, 08:30 PM
Ron Natalie
"Corky Scott" wrote in message ...
When you get hydraulic lock in a radial, it's not that the prop starts turning,
it's that the incompressable fluid tries (and succeeds) to expand the cylinder.
You can break a cylinder even pushing the prop through bu hand when oil is present.
Old October 14th 03, 09:15 PM
Corky Scott
On Tue, 14 Oct 2003 15:30:32 -0400, "Ron Natalie"
I just called the mechanic on duty for the FBO that maintains the
airplane and described the situation to him. He too thought that it
was probably not hydraulic lock. The time I experienced hydraulic
lock as an auto mechanic was when I pulled a dead Subaru out of a
snowbank where it had been abandoned for a while and dragged it back
to the shop. I was a mechanic and needed a car and thought I could
get the thing running so I pulled it inside and let it warm up. The
starter spun a tiny bit and stopped like the pistons had hit a rock.
I removed the four spark plugs and tried again. This time, geysers of
water shot out of the spark plug holes. One squirt must have traveled
15 feet before it hit the shop wall ten feet up.
I put the spark plugs back in and tried starting it. It did actually
start, but ran so rough, with water spraying out of the radiator that
I immediately shut it off. Busted head gasket, pretty common with the
73 through 76 Subaru's: They had floating cylinder liners.
Anyway, the guy I was talking with claimed no one else had mentioned
this. I ventured that perhaps they just hadn't written it up, since
they always seem to get it running, as I did.
I've never studied the Lycoming starters, but it's possible the
bendix, if it has one, may be popping out prematurely, stopping the
crank sequence. Engine compression would stop the prop spinning very
quickly, since it's a 180 hp model.
But that doesn't adaquately explain why, when I tried to re-engage the
starter, it appeared to have trouble turning the prop. I had to
repeatedly turn the key to "start", again and again and the prop would
turn just a bit and stop. Sometimes it appeared to get over a hump
and turn for one complete revolution, but would then stop again.
I doubt that it's the battery, because when the starter finally
managed to get going, it spun the prop as fast as I've ever seen it
go.
This happened the very first time I tried starting it, when the
airplane had only around 38 hours on it.
The older (but same model 172) has never done this.
Corky Scott
Old October 15th 03, 02:35 AM
Rick Durden
Corky,
You did describe what sounds like hydraulic lock. It can happen on
horizontally opposed piston engines if the engine is overprimed. You
may have bent a connecting rod.
All the best,
Rick
(Corky Scott) wrote in message ...
Pete
Corky Scott
Old October 15th 03, 02:57 AM
G.R. Patterson III
Rick Durden wrote:
You may have bent a connecting rod.
I think that unlikely considering the quality of the flight after he did get it
started.
George Patterson
A woman's perfect breakfast occurs when she's sitting at the table sipping
gourmet coffee while looking at pictures of her son on the cover of Sports
Illustrated, her daughter on the cover of Business Week, her boyfriend on
the cover of Playgirl, and her husband on the back of the milk carton.
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Jet A / JP-4 ?? CVBreard General Aviation 7 December 8th 03 03:44 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
