Our club has a Delcom Air 960 panel mounted in a Schweizer 2-33. Currently
we are using a speaker-mike which jacks into the front of the radio. We would like to wire the radio with a speaker and two microphones. Does anyone know if this configuration is possible with this radio? If so, could you provide a wiring diagram. Any help will be greatly appreciated. Bob Walker |
On Jan 17, 3:06*pm, "Bob Walker" wrote:
Our club has a Delcom Air 960 panel mounted in *a Schweizer 2-33. Currently we are using a speaker-mike which jacks into the front of the radio. We would like to wire the radio with a speaker and two microphones. Does anyone know if this configuration is possible with this radio? If so, could you provide a wiring diagram. Any help will be greatly appreciated. Bob Walker The only real trick to wiring as you outlined is the fact that these mikes are electret. This means that an aircraft mike (carbon equivalent) might not work. However the standard Radio Shack electret will work. You have to figure out the PTT and install PTTs and mike wiring to each stick to both turn on the ptt and connect the proper mike. I had made this very setup in my 2-22 and I used gaming headsets with out the speaker although you could use a speaker in the glider. I think that you will find the small mike jack has a ring tip and sleeve arrangement like a standard mike jack. the ring would normally be the mike ant the PTT would be the tip. The sleeve would be ground. The speaker is the larger plug and just goes to the speaker leads. You can buy a manual from Delcom for $25.00. At least a while ago they sold an adapter for standard headsets. This may well mean that you can use a standard aircraft mike setup as the radio provides the exicitation for the electret mike. JDB |
Was just about to do the same! haven't tried these but seen similar on
other sites: http://www.delcom.com.hk/externalmicjack.html Mike At 21:06 17 January 2012, Bob Walker wrote: Our club has a Delcom Air 960 panel mounted in a Schweizer 2-33. Currently we are using a speaker-mike which jacks into the front of the radio. We would like to wire the radio with a speaker and two microphones. Does anyone know if this configuration is possible with this radio? If so, could you provide a wiring diagram. Any help will be greatly appreciated. Bob Walker |
On Jan 18, 12:27*pm, Mike Gatfield wrote:
Was just about to do the same! haven't tried these but seen similar on other sites:http://www.delcom.com.hk/externalmicjack.html Mike At 21:06 17 January 2012, Bob Walker wrote: Our club has a Delcom Air 960 panel mounted in *a Schweizer 2-33. Currently we are using a speaker-mike which jacks into the front of the radio. We would like to wire the radio with a speaker and two microphones. Does anyone know if this configuration is possible with this radio? If so, could you provide a wiring diagram. Any help will be greatly appreciated. Bob Walker- Hide quoted text - - Show quoted text - Use the quoted diagram and wire the two mikes parallel at the jack. The PTTs and individual miles should be separate circuits and come together at the jack. when you key the mike that mike is "hot" and the transmitter is turned on. I had something like this for my old 2-22 radio. I couldn't remember if the PTT was separate and went to the tip or like shown. I bet for the drawing above. JDB |
On Tuesday, January 17, 2012 at 4:06:49 PM UTC-5, Bob Walker wrote:
Our club has a Delcom Air 960 panel mounted in a Schweizer 2-33. Currently we are using a speaker-mike which jacks into the front of the radio. We would like to wire the radio with a speaker and two microphones. Does anyone know if this configuration is possible with this radio? If so, could you provide a wiring diagram. Any help will be greatly appreciated. Bob Walker can i here the opp with this and what frequencu is it i live in elliot lake ontario canada please and thank you |
Delcom 960 Panel Mount....... | [email protected] | Aviation Marketplace | 0 | June 27th 06 03:17 AM |
Delcom-960 headset adaptor needed | Ron | Aviation Marketplace | 3 | April 18th 06 01:13 AM |
Delcom Battery | Mike | Soaring | 5 | April 7th 06 03:11 AM |
Delcom Battery | Mike | Soaring | 1 | July 25th 05 05:22 PM |
Need panel mount for Delcom Radio | Mark Lenox | Soaring | 3 | June 24th 05 03:31 AM |
