Driving sheet-metal screws into 4130
Old January 23rd 04, 01:59 PM
Grandpa B.
Default Driving sheet-metal screws into 4130
Greetings, all.
I'm restoring a Champ, and have a question about driving screws into a
drilled 4130 tube.
If I drill the proper sized hole, the screws refuse to 'take'; they simply
give up their threads to the harder metal of the tube. If I over-size the
hole, then the screw won't hold diddley (that's a technical term).
Do I just keep driving fresh screws until one finally makes it in? I've
tried both stainless and cad-plated 'pk' types.
Another related question: These screws are going into a structural tube -
the windshield pillar, in this case. The original design from Champion
appears to have been thus. Is there a danger here, other than opening the
tube to moisture and corrosion? I am making an 'extra' hole, by the way.
And, unfortunately, I can't weld it up, since the fabric and interior are
done, and the hole is through the fabric, and right next to the headliner.
Jon B.
Old January 23rd 04, 05:05 PM
Jim Carriere
"Grandpa B." never.mind wrote in message
Greetings, all.
drilled 4130 tube.
Are you tapping the holes? As in, with a tap and die set (preferably that
is made for working on 4130).
Old January 23rd 04, 06:46 PM
Tarver Engineering
"Jim Carriere" wrote in message
Greetings, all.
drilled 4130 tube.
simply
Where did he get the screws and what kind are they?
Old February 1st 04, 07:39 PM
O-ring Seals
On Fri, 23 Jan 2004 12:05:08 -0500, "Jim Carriere"
Greetings, all.
drilled 4130 tube.
He did say "sheet metal screws". You would use machine screws in a
tapped hole of course. The problem is that the tubes he refers to are
pretty thin walled and would not accept much of a real thread. Might
it easier to run PK screws in though.
O-ring
Old February 1st 04, 10:07 PM
Rich S.
"O-ring Seals" wrote in message
Greetings, all.
drilled 4130 tube.
simply
that
Bob...........
The tube frame for the Emeraude canopy uses rivnuts (metric thread of course
)) which work well. Harbor Freight has a nut rivet kit for $13.00 which
might work for occasional use.
Rich S.
O-ring
Old February 2nd 04, 10:29 PM
O-ring Seals
On Sun, 1 Feb 2004 14:07:40 -0800, "Rich S."
Bob...........
Rich S.
O-ring
Rich,
The area where he is placing the screws is in structural fuselage
tubing. I feel that the hole size required for rivnuts might
compromise the integrity of the tubing. He is adding a new set of
holes as it is. Best to get some number sized drill bits ( 1/64" one
way or the other may not work ) and practice on some scrap tubing to
find the one that works.
O-ring
Old February 2nd 04, 11:00 PM
Henry Bibb
Just a caution on the Harbor Freight rivnut tool. I found the #6 mandrel
included with mine was undersized, and would not engage the threads of
the #6 rivnuts well enough to crimp them. The #8 worked fine*; I haven't
tried the other sizes. Just something to look out for if you're planning on
using #6s.
*By working fine, I mean it pulled some righteous brand-name RivNuts.
The #6 didn't work with either the HF or brand-name ones. A dial
caliper vs a screw checker revealed the undersizing issue. It just pulled
the thread out of the rivnut. Actually, just pulled the crest of the
thread,
since the mandrel didn't reach all the way to full thread depth.
Henry Bibb
course
Rich S.
Old February 3rd 04, 01:14 AM
Rich S.
Gotcha, Bob. Mebbe he just needs one those rare "sheet metal screw" taps???
Rich S.
Sheet metal "Nibbler" Nolaminar Home Built 3 January 24th 04 06:05 AM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
