Well heck. A typo crept into my "Battery Test" article in the
February issue Soaring. So for those checking my math in footnote #1, this is how it should have read; "1A is the nominal current draw at 12Vdc (12W). When the battery voltage drops below 12Vdc, the current draw is lower. Above 12Vdc, the current draw is higher. For example, at 11Vdc a 12ohm load draws 0.92A (10.1W) and at 13Vdc a 12ohm load draws 1.1A (14.1W)." And if someone rechecks this math they will find that P = E x I = 13 x 1.1 = 14.3W. So how did I come up with 14.1W? Because I = E/R = 13/12 = 1.08333 which I rounded to 1.1 which would give 14.3W. But actually P = 13 x 1.08333 = 14.1W. Watch those significant digits! Sigh. - John DeRosa |
Thanks for an excellent article John - I plan to check my batteries using your system before the Spring "start up" . Ron. |
Thanks for the kudo. I have gotten nice feedback from others that are
planning on also using this simple method. Sure wish the typo wasn't in there but it doesn't really impact the important stuff. Thanks, John |
John, also enjoyed your article and will try your technique on a couple of batteries I am unsure of. Also, since we have an EE on the line I wanted to ask about battery setups. My partner and I have installed some new toys in our ASW20 (transponder,etc) and are wondering what is the best way add more power. We are currently running a single !2v 9amp battery. Would it be better to add another 9amp battery or to go to a single higher capacity battery. If using two batteries, what is the best way to tie them together.
-karl |
On Feb 2, 10:11*am, Karl Kunz wrote:
John, also enjoyed your article and will try your technique on a couple of batteries I am unsure of. *Also, since we have an EE *on the line I wanted to ask about battery setups. My partner and I have installed some new toys in our ASW20 (transponder,etc) and are wondering what is the best way add more power. We are currently running a single 12v 9amp battery. Would it be better to add another 9amp battery or to go to a single higher capacity battery. If using two batteries, what is the best way to tie them together. -karl Glad you enjoyed the article. I am going to split off your questions into a different thread. |
| new Soaring article | John Cochrane[_2_] | Soaring | 34 | May 18th 11 04:04 PM |
| Another new Soaring Article | John Cochrane[_2_] | Soaring | 11 | May 13th 11 11:34 PM |
| NYT Soaring Article | C Koenig | Soaring | 0 | September 21st 07 03:11 PM |
| Soaring Article | Mike | Soaring | 1 | June 30th 05 01:58 AM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
