Ventus bT/cT comparison
Old April 17th 12, 01:46 PM posted to rec.aviation.soaring
Jim Pengelly
Default Ventus bT/cT comparison
Hi everyone,
I fly a Discus bT at the moment and absolutely love it. However, I
am thinking of upgrading to a flapped turbo in the next one or two
seasons and the Ventus bT/cT would seem to be the natural
choice.
I have heard conflicting opinions about the various models:
i) The bT has handling issues and the cT was designed to
overcome these issues, with a bigger rudder and some other
changes. The cT is the model to go for.
ii) The cT has handling issues, can be difficult to bleed approach
energy due to the brake configuration and was not a popular
model, which is why there are so few of them around. The bT is
iii) The bT and cT perform relatively poorly in 15m mode rather
than their 16.6m (bT) and 17.6m (cT) modes, so competing in
15m mode is not recommended.
Any thoughts much appreciated.
Cheers,
Old April 17th 12, 03:26 PM posted to rec.aviation.soaring
Peter F[_2_]
Can't speak for the turbo versions, but for the pure glider option the
problem with the Ventus B in 16.6 mode was that you couldn't carry enough
water to get it going even here in the UK.
(Not sure how much water the Turbo versions can carry - do they have same
reduced all up weight as Discus T)
The long wings on both B & C are great for weak wave and long glides at the
end of the day. The Turbo will let you motor into the stronger wave & get
you home at the end of the day in 15m mode
Winglets improved any handling "issues" with Ventus B
Best option is to fly in 15m mode with winglets
Both Ventus B & C are less forgiving around the stall than your Discus so
you probably need to be more cautious when picking fields / starting the
engine.
The reason there are fewer Ventus Cs around is mainly 'cos the LS6 came
along and then the V2.
All depends on what you're flying against. You're unlikely to outrun an LS6
or V2, in absolute terms & if you're flying handicapped comps then stick
with the Discus!!
PF
At 12:46 17 April 2012, Jim Pengelly wrote:
Hi everyone,
choice.
Cheers,
Old April 17th 12, 07:43 PM posted to rec.aviation.soaring
StaPo
Dne úterý, 17. dubna 2012 16:26:25 UTC+2 Peter F napsal(a):
..... The reason there are fewer Ventus Cs around is mainly 'cos the LS6 came along and then the V2...
Actually, the ratio of manufactured Ventus C's versus B's is about 50/50,
with even slight favor to C's, see http://rcawsey.co.uk/shirth.html
Old April 17th 12, 07:02 PM posted to rec.aviation.soaring
John Ferguson[_2_]
I'd say i) is the most correct of the statements listed. The cT with
landing flap and full brake comes down rather steeply, just point at the
ground ... not recommending that though.
The cT does have the restricted 425 KG max mass when the turbo is
installed, as does the bT. With the engine removed the max weight goes back
up to 500kg, find one with a carbon fuselage if possible, saves 10 kg on
the weight plan.
I'm on my second cT now, great performance in 17.6, probably the best value
L/D you can buy.
In 15m mode with turbo installed the wing loading could be described as
high, but if you live in a country with big thermals that's not a worry.
Somehow it likes landing at 60ish knots rather than the yellow triangle
speed.
Try one if you can get a flight.
Old April 18th 12, 08:43 PM posted to rec.aviation.soaring
Jim Pengelly
at the
turbo is
weight goes back
10 kg on
the weight plan.
the best value
L/D you can buy.
described as
worry.
triangle
speed.
Everyone that has replied seems really happy with the cTs. I
think I'm going to get one if I can find the right one for the right
price. Any ideas on current values?
Old April 18th 12, 09:20 PM posted to rec.aviation.soaring
John Ferguson[_2_]
In the UK Discus bT go for as much as £49k, Ventus cT are less expensive,
probably because of the reputation. UK prices for Ventus cT is £42k to
£45k.
Old April 18th 12, 04:36 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Tue, 17 Apr 2012 12:46:24 +0000, Jim Pengelly
Hi everyone,
choice.
Cheers,
I'll offer a few comments. My Ventus cT is a 1987 model and I've got
about 1500 hrs on the ship over the past 13 years.
-- One possible reason for the apparently small number of C models in
the US is that at least the early C's were brought into the US as B
models, and then re-placarded as a C model. My '87 cT has the original
B placard still in place, but X'd out with the new C placard mounted
below it. I notice that a number of Ventus B models in the FAA
database are in fact C models whose owners never updated the FAA
records.
-- I've got no complaints regarding the handling of the Ventus C,
thought I fly almost exclusively with the 17.6m tips. I've noticed no
issues with handling with the 15m winglets, however.
-- Unfortunately I have never had to opportunity to fly a Ventus B.
The only unbiased comment I can quote is from Derek Piggott in the Dec
1992 / Jan 1993 Sailplane & Gliding issue.
"Whereas the earlier model has rather a reputation for stalling and
spinning if flown carelessly. the C model seemed a model of docility.
I frequently pulled into steep thermalling turns, getting down to well
below 40kt with only an obvious buffeting and sinking feeling clearly
indicating that this was far too slow. It did not once drop a wing
requiring any proper stall recovery. In spite of the extra wing span,
the rate of roll is excellent at all speeds and it is easy to fly
accurately rolling into and out of turns"
-- Max gross with or without the engine is 500kg. The issue with the
engine in place is the 255kg non-lifting limit. With the engine in
place, the pilot weight determines whether the max gross of 500kg or
the non-lifting limit of 255kg kicks in first. For my weight and 28
gal of water, I hit max gross just before I hit the non-lifting limit.
Bottom line, with the engine in place and ballasted to max gross, you
are at the same loading as without the engine, but you cannot dump
down to the same low loading as without the engine. With the engine
in, I can go from 10.1 lbs/ft2 max down to 7.9 lbs/ft2 min. Without
the engine, W/L ranges from the same 10.1 lbs/ft2 down to 7.2 lbs/ft2
(all with 17.6m span). The B model has the same issue and limitations.
-- For what its worth, only the C models were factory certified with
the 17.6m tips.
-- Regarding the air brakes, I have never found a situation where
landing flap and full dive brakes were inadaqute. That said, they
probably are not the equal of a PIK 20B or any other ship with full
90deg flaps (I've got about 2500 hrs in a 20B, before the Ventus).
Hope this helps your decision.
Bob
Old April 18th 12, 08:40 PM posted to rec.aviation.soaring
Jim Pengelly
Hi everyone,
However, I
two
choice.
approach
is
Cheers,
got
models in
B
original
mounted
FAA
records.
no
B.
Old April 20th 12, 03:59 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Hi everyone,
choice.
Cheers,
records.
the 17.6m tips.
Bob
Every Ventus cT manual that I have looked at says the max weight with the engine in is 430 kg regardless of the span. With the engine out, 500kg at 16.6. and 17.6m respectively
Cheers
Colin
Click image for larger version
Name:	Ventus cT data.jpg
Old April 21st 12, 01:26 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Fri, 20 Apr 2012 02:59:15 +0000, Ventus_a
'Bob Gibbons[_2_ Wrote:
.... text deleted
Cheers
Colin
Colin, you are correct in quoting the handbook. Several of us actually
discussed this apparent contradiction with Klaus Holighaus on a visit
a number of years ago.
He agreed that it so long as the non-lifting limit is followed, it
makes no difference whether the engine is in or out.
The engine represents a fuselage (non-lifting) load on the airframe,
the cause of this non-lifting load should not be a factor in the
overall gross weight, so long as the non-lifting limit is observed.
Bob
Yak-38 vs Yak-141 Size Comparison Rob[_6_] Naval Aviation 0 October 8th 10 01:49 AM
Aircraft comparison Jkgoblue Owning 1 November 23rd 05 10:18 PM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
Comparison of IFR simulators Chris Kurz Simulators 0 October 27th 03 10:35 AM
EMW A6 Comparison to X-15 robert arndt Military Aviation 8 October 2nd 03 02:26 AM
