Tow Pilot Rand/Question
Old May 10th 12, 03:34 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow Pilot Rand/Question
This is prompted by someone's description of a flight involving high sink
from tow release to landing. The pilot stated that he released from tow in
800 fpm sink at 3,000' AGL.
It's so common when I'm towing to have the glider pilot tell me, "I'll take
a tow to 3,000 feet." Then, during the tow, I hit super lift and the pilot
will hang on to the rope. He'll hang on until I'm struggling through sink
and hit the magic 3,000' and release!
I shouldn't complain since the higher tow means more income for the
operation, but I'd think pilot judgment would include releasing in lift -
even if it's below some preconceived release altitude.
Now, the instructors will say, "We need the altitude to accomplish the
objectives of the flight." I ask, "Wouldn't it better to demonstrate
judgment by releasing in strong lift and climbing to altitude to practice
maueuvers?"
Rant over...
Old May 11th 12, 01:20 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
maueuvers?"
Rant over...
Feel free to rant away. I made the observation of encountering 800 fpm of sink upon release. My point was that these things occur on occasion and if not handled quickly and appropriately it might result in being low in the pattern resulting in the crash that occurred. I was relatively inexperienced at the time (and by some standards may well still be) but recognized that the circumstances might well preclude my ability to return to the airport and land safely if I didn't get ahead of the situation. Fortunately I received my glider training from two old buzzards with thousands of hours of experience and benefited from listening to their advice. I usually take a tow to 3000 feet but on occasion will release if I encounter exceptional lift. Too often though one flys thru lift, turns and can't find said lift again. Often times it's a 50/50 chance of turning in the right direction and when wrong it requires some searching to find adequate lift to climb. The bottom line is that with an extra 1000 feet prior to release one has that extra opportunity. I learned to fly gliders in November and December in Florida and don't once remember encountering lift while flying with an instructor. Most days were cold, wet and dreary with heavy overcast. I'm sure that most instructors will release in lift to give their student the opportunity to thermal to altitude. I'm just glad that it was drilled into me to err on the side of caution and insure that I had sufficient altitude to fly a reasonable pattern, maintain adequate airspeed and land safely. That's what it's all about.
Walt Connelly
Commercial Pilot/Airplanes and Gliders
and still learning
Old May 12th 12, 01:42 AM posted to rec.aviation.soaring
Dan Marotta
No disrespect meant, Walt.
My point was that you should get off in lift, not in sink. If there was
sink at your planned release altitude, you should stay on until you get into
lift. Of course, if there's no lift, you have to do what you have to do.
By convention, you have to turn right when you release (in the USA, at
least). If you know the lift is to your left, you can make your right turn
to clear the rope and then immediately turn left into the lift.
Alternatively, you can make a right 270 and you should hit the lift.
"Walt Connelly" wrote in message
sink
in
take
pilot
sink
practice
maueuvers?"
Rant over...
Walt Connelly
and still learning
Walt Connelly
Old May 11th 12, 10:59 AM posted to rec.aviation.soaring
Jonathon May[_2_]
in
take
pilot
maueuvers?"
Rant over...
ahh the barametric release system, works well for the accounts department
when all the release hights are the same.In reallity if its a trial
flight you give them what they have paid for if you are paying you you
release as soon as your confidence exceeds your lack of same.
Old May 12th 12, 01:56 PM posted to rec.aviation.soaring
John[_30_]
I thought this maybe had something to do with RAND Baldwin.
J4
Old May 13th 12, 03:52 AM posted to rec.aviation.soaring
Dan Marotta
Nah... It's my typing (and lack of proof reading).
RANT, RANT, RANT...
"John" wrote in message
J4
Old May 11th 12, 12:40 AM posted to rec.aviation.soaring
T[_2_]
from tow release to landing. *The pilot stated that he released from tow in
a tow to 3,000 feet." *Then, during the tow, I hit super lift and the pilot
will hang on to the rope. *He'll hang on until I'm struggling through sink
objectives of the flight." *I ask, "Wouldn't it better to demonstrate
maueuvers?"
Rant over...
Hopefully if you were in sink, you were attempting to turn back to the
lift when the glider released?
Many times the instructor will want straight tows with shallow turns
to accomplish training, slack line, box wake etc. and then the tow
pilot should be free to return to a known lift area.
You did not say if this was an instructional flight, solo student or
rated pilot.
I've had pilots tell me.. straight out.. into the wind. They get off
when they are ready. It is a currency flight for them, not interested
in soaring.
At the end of the day... it's still the customers dollars..
T
Old May 16th 12, 03:57 AM posted to rec.aviation.soaring
Dan Marotta
What started me ranting are low time glider pilots (licensed) who tell me
they will release at a particular altitude, generally 3,000 feet, and then
do exactly that. I try to keep them in lift but they don't have the
experience to stay with me if I turn too tightly. The problem is that, I
may be going up like gang busters at 2,800 ft and they'll hang on and, at
3,000 ft, when I'm in sink and turning back towards the lift, they release
in the sink rather than wait another minute.
I was hoping to spark a discussion and it appears that I've done just that.
"T" wrote in message
take
maueuvers?"
Rant over...
rated pilot.
in soaring.
T
Old May 11th 12, 03:54 PM posted to rec.aviation.soaring
maueuvers?"
Rant over...
I learned to release in lift early in my training (probably first page in
the logbook). I'd try releasing and going back to the thermal we'd hit
earlier, but could never find it. The instructor told me to release in lift
instead.
Last year I was climbing nicely in our house thermal. One of our rated (ATP!)
pilots was on tow going by me. The tow pilot pointed me out. He stayed on
for a couple more minutes, released, and tried to go back to my thermal.
I took pity on him, pulled spoilers, and tried to show him the lift. Twice.
I climbed up from 1100 AGL finally, and he had a 15 minute flight.
It did make for a good ground lesson afterwards...
-- Matt
Old May 11th 12, 08:18 PM posted to rec.aviation.soaring
rlovinggood
At contests that I attend, we have pre-paid for 2,000' agl tows. Why get off any lower? There's a chance of getting off lower and missing the thermal, then having to work like crazy to get back up to release height, all before the gate has opened. I don't want to have to work before the gate opens; I just want to relax a little and save my concentration to spot the other gliders that are out there. They are marking thermals, so there isn't a need to pull the release below the 2,000' agl mark.
Ray Lovinggood
Carrboro, North Carolina, USA
UK2 KN418 Douglas DakotaMkIV 1998-11-13 ex US 44-76512 to 5Y-AAE Rand DaveBeckerPhoto.jpg Joseph Testagrose Aviation Photos 0 November 26th 11 11:53 AM
UK2 EX583 NA HarvardMkIIA 1998-10-15 ex US 41-33556 to SAAF 7246 Rand DaveBeckerPhoto.jpg Joseph Testagrose Aviation Photos 0 September 14th 11 08:38 PM
a pilot question [email protected] Simulators 19 April 30th 08 05:37 PM
RAND report raps Raptor program estimates Mike Naval Aviation 1 October 19th 05 08:37 PM
Rand Robinson KR-2 opinions... Ralph Snart Home Built 9 November 15th 03 11:31 PM
