I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). Suppose this CG-hook-newbie were to take winch tow training (with CG hook). Would the winch training reduce the initial difficulty of a CG hook aerotow?
Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? What sorts of misadventures are reasonably attributed to aerotow on CG hook? I understand why CG hook is superior for winch tow. No need to rehash that explanation. |
On Thursday, May 24, 2012 7:54:00 PM UTC-7, son_of_flubber wrote:
I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). Suppose this CG-hook-newbie were to take winch tow training (with CG hook). Would the winch training reduce the initial difficulty of a CG hook aerotow? Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? What sorts of misadventures are reasonably attributed to aerotow on CG hook? I understand why CG hook is superior for winch tow. No need to rehash that explanation. There is increased risk that come from the directional squirliness. Can you reduce this with training. Sure. Can you eliminate any risk, no. Can you reduce it enough to feel comfortable. Maybe, but that is a personal risk decision, not something somebody else can tell you. But I've seen a few departures to the weeds with folks aerotowing with a CG hook. The attention getting ones involve crosswinds and narrow strips and/or tall grass... ending in ground loops. That cross wind handling, need to be ready to quick release etc. should be things to look at with an instructor. Its not clear what you are flying or where, but some flight manuals do prohibit aerotowing with a CG hook (e.g. my ASH-26E does). Darryl |
On May 24, 8:54*pm, son_of_flubber wrote:
I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). *Suppose this CG-hook-newbie were to take winch tow training (with CG hook). *Would the winch training reduce the initial difficulty of a CG hook aerotow? Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? What sorts of misadventures are reasonably attributed to aerotow on CG hook? I understand why CG hook is superior for winch tow. *No need to rehash that explanation. Most glass two seat trainers (Grob, ASK-21, etc.) have both nose and CG hooks so you can arrange to get some flight instruction in one aero towing with the CG hook. Some countries prohibit aero tow with CG hooks or require special training to do so. I can't say that 100% of the dangers go away with training and experience but very nearly so. I think winch training will improve any pilot - sometimes substantially and not just with a CG hook. For pilots trained on aero tow, the main danger with a CG hook is a ground loop on the takeoff roll - a nose hook tends to keep the glider rolling straight if a wing drops but the effect is small. If seen many if not more ground loops with nose hooks. A glider aero towing with a CG hook can easily climb above the tug creating a very dangerous situation for the tug pilot but these upsets happened primarily to pilots who had mostly winch experience and little aero tow experience. It's as easy to stay in position behind the tug but you have to be aware of the need to do so - you have to really fly formation on the tug. The rope will not pull you back into position. |
On 5/24/2012 7:54 PM, son_of_flubber wrote:
I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). Suppose this CG-hook-newbie were to take winch tow training (with CG hook). Would the winch training reduce the initial difficulty of a CG hook aerotow? No, and I suggest it may make you worse at aerotowing, because you learn to put the glider in a steep climb. "Kiting" on tow is a bad problem; "kiting" during a winch launch is normal operation. Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? No, but you can significantly reduce the risks with training and experience. What sorts of misadventures are reasonably attributed to aerotow on CG hook? The worst is the increased potential for the aforementioned kiting; the rest tend to happen on the ground with a chance for damage, but not less risk to people. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On May 24, 10:18*pm, Eric Greenwell wrote:
On 5/24/2012 7:54 PM, son_of_flubber wrote: No, and I suggest it may make you worse at aerotowing, because you learn to put the glider in a steep climb. "Kiting" on tow is a bad problem; "kiting" during a winch launch is normal operation. A pilot would have to be pretty stupid to let that happen. (Learning is where you ADD knowledge - not replace what was already there.) Learn winch launch - you WILL become a better pilot. |
On 5/25/2012 7:31 AM, Bill D wrote:
On May 24, 10:18 pm, Eric wrote: On 5/24/2012 7:54 PM, son_of_flubber wrote: No, and I suggest it may make you worse at aerotowing, because you learn to put the glider in a steep climb. "Kiting" on tow is a bad problem; "kiting" during a winch launch is normal operation. A pilot would have to be pretty stupid to let that happen. (Learning is where you ADD knowledge - not replace what was already there.) Learn winch launch - you WILL become a better pilot. Stupid, or poorly trained, or confused in an emergency. Still, I'm not aware that learning winch launching in any way prepares you for aero tow. The attitude and sight picture is entirely different, and you aren't flying formation. I've done mostly aerotows and some auto tows, and my experience was handling the glider took a different set of skills. A notable difference is the auto launch was easier as long as every thing went right - it took far less corrections compared to the aero tow. Learning to do winch launches so you are capable of doing winch launches is an excellent reason, but I think it's a waste of time if your goal is learning to do aerotow with a CG hook. The winch launch simply doesn't challenge the pilot in the same way a CG hook aero tow does. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
![]() Quote:
With that small caveat I don't think that anything you learn from winch launching can prepare you for learning aerotow (tethered formation flying) from either a belly or a nose hook Cheers Colin Last edited by Ventus_a : June 1st 12 at 10:23 PM. |
On Friday, 25 May 2012 03:54:00 UTC+1, son_of_flubber wrote:
I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). Suppose this CG-hook-newbie were to take winch tow training (with CG hook). Would the winch training reduce the initial difficulty of a CG hook aerotow? Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? What sorts of misadventures are reasonably attributed to aerotow on CG hook? I understand why CG hook is superior for winch tow. No need to rehash that explanation. Also, CG hooks can back release if you get a lot of slack in the rope. The manual may suggest a method for blocking the back release - make sure you remove it before winching. |
On May 24, 11:05*pm, b4soaring wrote:
On Friday, 25 May 2012 03:54:00 UTC+1, son_of_flubber *wrote: Also, CG hooks can back release if you get a lot of slack in the rope. The manual may suggest a method for blocking the back release - make sure you remove it before winching. If the CG hook is functioning properly (i.e. no weak springs), it would take a LOT of slack to get a back release. So much so that you'd be in front of the tug and probably want to release anyway. Don't mess with the hook or you might make it malfunction completely. Uncommanded releases are not a problem. |
On Friday, May 25, 2012 9:36:16 AM UTC-5, Bill D wrote:
On May 24, 11:05*pm, b4soaring wrote: On Friday, 25 May 2012 03:54:00 UTC+1, son_of_flubber *wrote: Also, CG hooks can back release if you get a lot of slack in the rope. The manual may suggest a method for blocking the back release - make sure you remove it before winching. If the CG hook is functioning properly (i.e. no weak springs), it would take a LOT of slack to get a back release. So much so that you'd be in front of the tug and probably want to release anyway. Don't mess with the hook or you might make it malfunction completely. Uncommanded releases are not a problem. Actually they very well can be. I was piloting an IS-28B2 Twin Lark a couple of years ago behind a Super Cub during a 175 km transfer aerotow to another airport. We had to go over a pass and coming over the pass flew straight into serious rotor off a sharp mountain ridge bordering the valley we were entering. Keeping the glider in position behind the super cub was a handful (a Twin Lark flies a bit like tank depending on what you are used to), I did end up getting some serious slack at one point while perfectly pointed at the cub. The cable bow reached back (the bow being to the left and almost level with the glider) to about where I was sitting in the front seat of the glider when I heard the "clonk" of the back release, the very moment I was starting to get worried it might just do that while remembering that the back release was not blocked... The Twin Lark has a non-structural nose cone and the aerotow hook mounted just in front of the front rudder pedals. It is the same Tost hook as the CG hook installed and hence back releases unless you do something about it... I could have grabbed the released cable if it hadn't been for the canopy, it was right next to me before I banked away to avoid potential damage. The bow was never a danger to the glider and never went anywhere near the wing tip or something else it could have caught onto, so the back release was completely unwarranted in this scenario. An uneventful outlanding in unfamiliar terrain followed since we had plenty of altitude and I had a variety of fields to choose from but it was an all-nighter to get the trailer and crew there, load up the glider in the dark and get it to the destination airport through some serious mountain roads. I made sure with a metal angle blocking any backwards movement of the hook rim that this would not happen again... Markus Graeber |
CG Hook for 1-26? | [email protected] | Soaring | 1 | October 29th 06 01:21 AM |
Tow hook | [email protected] | Soaring | 2 | September 27th 06 02:16 AM |
Elfe S4 Winch hook | Derek Wilson | Soaring | 0 | July 21st 05 11:07 AM |
Tow Hook 337 for a 150-150 | 1JH | Soaring | 3 | July 19th 05 06:35 PM |
CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 06:20 AM |
