Can anyone comment of why Power FLARM transmit power appears to be
much less than the transmit power allowed by FCC for this class of FHSS device? (ref test report on file with FCC) Is this a limitation of the RF module that was selected? Was it to increase battery life? Was it expected that adequate range would be achieved with a very low power level? Does the brick have the same transmit power as the portable? Andy |
On Jun 5, 1:24*pm, Andy wrote:
Can anyone comment of why Power FLARM transmit power appears to be much less than the transmit power allowed by FCC for this class of FHSS device? (ref test report on file with FCC) Is this a limitation of the RF module that was selected? *Was it to increase battery life? *Was it expected that adequate range would be achieved with a very low power level? Does the brick have the same transmit power as the portable? Andy Link, please? |
On Jun 5, 10:59*am, Evan Ludeman wrote:
Link, please? The direct link to the doc doesn't seem to work but you can find it by going he https://apps.fcc.gov/oetcf/eas/repor...ericSearch.cfm Searching for grantee code ZKU selecting DETAIL, then Test report. Test data are included in appendix B Andy |
On Jun 5, 4:02*pm, Andy wrote:
On Jun 5, 10:59*am, Evan Ludeman wrote: Link, please? The direct link to the doc doesn't seem to work but you can find it by going he https://apps.fcc.gov/oetcf/eas/repor...ericSearch.cfm Searching for grantee code ZKU selecting DETAIL, then Test report. Test data are included in appendix B Andy This would explain a lot of the issues with PowerFlarm. |
Did I read that correctly?
Frequency Hopping Devices with 50 or more channels are allowed a 1watt output, devices with 49 or less are allowed a .25 watt output? And Powerflarm's output during the certification was: At 902.2 MHz- .010 watt At 915 MHz- .006 watt At 927.8 MHz- .003 watt Does seem well under the max allowed, but I guess what matters is it good enough? Interesting, thanks for the link to the data. |
On Wednesday, June 6, 2012 6:56:32 AM UTC+9, RAS56 wrote:
Did I read that correctly? Frequency Hopping Devices with 50 or more channels are allowed a 1watt output, devices with 49 or less are allowed a .25 watt output? And Powerflarm's output during the certification was: At 902.2 MHz- .010 watt At 915 MHz- .006 watt At 927.8 MHz- .003 watt Does seem well under the max allowed, but I guess what matters is it good enough? Interesting, thanks for the link to the data. Forgot to add...PF has 65 channels, according to the test report. |
On Tuesday, June 5, 2012 3:11:14 PM UTC-6, Andrzej Kobus wrote:
On Jun 5, 4:02*pm, Andy wrote: On Jun 5, 10:59*am, Evan Ludeman wrote: Link, please? The direct link to the doc doesn't seem to work but you can find it by going he https://apps.fcc.gov/oetcf/eas/repor...ericSearch.cfm Searching for grantee code ZKU selecting DETAIL, then Test report. Test data are included in appendix B Andy This would explain a lot of the issues with PowerFlarm. Why? This is the same transmit power used by classic euro FLARMs. More than enough for advertised range. -Dave -Dave |
On Jun 5, 3:37*pm, Dave wrote:
This would explain a lot of the issues with PowerFlarm. Why? This is the same transmit power used by classic euro FLARMs. More than enough for advertised range. -Dave Maybe you should take a look at this link to see what it was we thought we were buying! http://www.gliderpilot.org/FLARM-Comparisons Note the following - "More powerful radio transmitter as needed for USA operation" and "Radio transmitter is not powerful enough for proper operation in parts of the USA" and also the comparison of "Double range dual antenna" with "Standard range" Also included in the text (What does it do) "The operating range is very dependent upon the antenna installation in the aircraft. The range of 'Classic' FLARM is about 2 km, but up to 5 km may be achieved in individual cases. PowerFLARM will have twice the range. " Andy |
Can anyone comment of why Power FLARM transmit power appears to be much less than the transmit power allowed by FCC for this class of FHSS device? (ref test report on file with FCC) Is this a limitation of the RF module that was selected? *Was it to increase battery life? *Was it expected that adequate range would be achieved with a very low power level? Does the brick have the same transmit power as the portable? Andy I see what you mean.... 10mW could not possibly have been the intended result. Experience at 15s showed many targets out to 6 nm in all directions except my 6:00, where range was 1.5 - 2 nm. The range problem noted previously appears to have been solved. -Evan Ludeman / T8 |
On Jun 5, 6:11*pm, Evan Ludeman wrote:
On Jun 5, 1:24*pm, Andy wrote: Can anyone comment of why Power FLARM transmit power appears to be much less than the transmit power allowed by FCC for this class of FHSS device? (ref test report on file with FCC) Is this a limitation of the RF module that was selected? *Was it to increase battery life? *Was it expected that adequate range would be achieved with a very low power level? Does the brick have the same transmit power as the portable? Andy I see what you mean.... 10mW could not possibly have been the intended result. Experience at 15s showed many targets out to 6 nm in all directions except my 6:00, where range was 1.5 - 2 nm. The range problem noted previously appears to have been solved. -Evan Ludeman / T8 Reading other info at that site indicates that 10mW was the design power output. Hmmmm. -T8 |
| Thread Tools | |
| Display Modes | |
| Power FLARM deliveries? | Andy[_1_] | Soaring | 1 | June 5th 12 02:33 PM |
| Portable Power Flarm for sale | [email protected] | Soaring | 1 | June 2nd 12 02:14 AM |
| Power FLARM question | Kimmo Hytoenen | Soaring | 26 | March 23rd 12 05:28 AM |
| Power FLARM portable reports? | Andy[_1_] | Soaring | 2 | December 9th 11 04:58 PM |
| Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 03:44 AM |
