Question for Pressurised Baron pilots
Old December 3rd 03, 07:46 PM
DeltaDeltaDelta
Default Question for Pressurised Baron pilots
I've been trying to find some info on this thing for quite a while now. I've
been to Raytheon's site and found specs for the normal Baron only. If some
of you do own the P version, could you please tell me what engines do they
have? Are they the regular IO-550s or are they turbocharged? And what are
their pressurisation abilities and optimal cruise altitude?
Triple Delta
Old December 3rd 03, 08:43 PM
Mike Rapoport
If the engines aren't turbocharged how would they preasurize the cabin?
Mike
MU-2
"DeltaDeltaDelta" wrote in message
I've
Triple Delta
Old December 3rd 03, 08:55 PM
Peter Duniho
"Mike Rapoport" wrote in message
link.net...
It would theoretically be possible to use any other form of air pump. I've
never heard of such a thing, but I see no reason a turbocharger (or turbine
engine) would be *required* for successful pressurization. For that matter,
any kind of supercharger is probably useful for the purpose of pressurizing
an aircraft.
Of course, then there's the question of "why bother", since without a
turbocharger, there's not a lot of incentive to fly really high where the
pressurization would be useful, nor would the plane likely be able to climb
very far into those altitudes anyway.
In other words, yes it's almost guaranteed that a pressurized airplane will
have turbocharged engines, but for someone that doesn't know how
pressurization systems normally work, it's a reasonable question to ask
whether the engines are pressurized or not. IMHO, of course.
Pete
Old December 3rd 03, 09:39 PM
Mike Rapoport
You are right of course but every preasurized airplane that I am familiar
with uses air compressed by a turbocharger or turbine engine compressor
(pretty much the same thing.)
Mike
MU-2
link.net...
I've
turbine
matter,
pressurizing
an aircraft.
climb
will
Pete
Old December 4th 03, 12:58 AM
karl gruber
Mike,
******You are right of course but every pressurized airplane that I am
familiar
(pretty much the same thing.)******
I'm sure you are vaguely familiar with the King Air 90, A90, and B90. None
of these use bleed air for pressurization. They have a Roots supercharger on
the left engine that supplies pressure for the cabin. Weird! Supposedly the
FAA was concerned about bleed air into the cabin in early turboprops.
Best
Old December 4th 03, 01:13 AM
Mike Rapoport
I'll take your work for it! Bizzare.
Mike
MU-2
"karl gruber" wrote in message
Mike,
familiar
on
Best
Old December 4th 03, 12:06 AM
On Wed, 03 Dec 2003 20:43:39 GMT, "Mike Rapoport"
flux capacitor
Old December 3rd 03, 08:49 PM
Peter Duniho
I've
Does Raytheon still sell the 58P? There may be a good reason there's no
current specs on their web site.
As for the questions, I don't know what previous 58P's had, but a quick
Google search seems to indicate that they were available at least with the
520 cu.in. engines; not sure about the 550 cu.in. ones. I've never heard of
a pressurized airplane that wasn't turbocharged, but for sure if there's an
exception, the Baron wouldn't be it.
Keep in mind that even if you were looking at the unpressurized Barons, the
Raytheon web site is likely to only give you info on the current models.
Earlier models may or may not have similar equipment, including the engines.
If the information on earlier models is there, it would be harder to find,
probably under the customer support areas.
Pete
Old December 3rd 03, 09:16 PM
Craig Prouse
If they were regular IO-550s, where would the pressurization come from?
Old December 3rd 03, 10:42 PM
JerryK
The P Baron has not been made since the mid 80s. Check the Aviation
Consumer web site or buying guides for reviews.
jerry
I've
Triple Delta
Dover short pilots since vaccine order Roman Bystrianyk Naval Aviation 0 December 29th 04 12:47 AM
[OT] USA - TSA Obstructing Armed Pilots? No Spam! Military Aviation 120 January 27th 04 10:19 AM
[OT] USA - TSA Obstructing Armed Pilots? No Spam! General Aviation 3 December 23rd 03 08:53 PM
