"Tanks on both" checklist item
Old December 4th 03, 10:57 AM
Koopas Ly
Default "Tanks on both" checklist item
Good day all,
With regards to fuel tanks in a C172, why does the takeoff and landing
checklists both call for the fuel selector handle to be in the "both
tanks" position?
The only time that fuel is set to one particular tank is on the
ground. I've never used fuel from only one tank in flight. Why would
someone do that?
Also, why is the fuel selector set to one tank during refueling? Is
it to minimize crossfeeding?
Thanks,
Alex
Old December 4th 03, 11:34 AM
Craig Prouse
tanks" position?
The geometry of the fuel tanks and the locations of the fuel ports in the
tanks cause the actual amount of usable fuel in each tank to vary depending
on aircraft attitude.
By way of example, let's say that you've only got 5 gallons in the right
tank, and the wind conditions on landing require a pronounced slip with a
bank to the right. If the fuel port is inboard and all the fuel goes
sloshing outboard, and only the right tank is selected, you've just starved
your engine of fuel. But as long as you have some fuel in both tanks and
Both selected, you ought to be fine even in a prolonged uncoordinated
condition.
someone do that?
Cessnas have the notorious characteristic of not drawing fuel evenly from
both tanks in the Both position. This can result in fuel imbalance. In a
Cessna 172 you might never notice any difference in the flight
characteristics, but in a 182 which has more fuel capacity in each wing than
the 172 has in total, you can develop an imbalance which becomes fairly
uncomfortable. By selecting one tank or the other, you can burn fuel
(mostly) from the full tank in order to reestablish lateral balance.
Read your autopilot limitations carefully as well. My POH prohibits
operation of the autopilot when fuel imbalance exceeds 90 lbs. That's only
a 15 gallon difference between left and right, so I try to stay ahead of the
situation.
If you're parked not quite level, and start refueling with the fuel selector
in the Both postion, if you start by topping off the high wing, some of that
fuel may crossfeed into the low wing while you switch sides and go about
filling the low wing. If you don't recheck the high wing, you might not
notice that the first tank is no longer full, and that you are a few gallons
short of the fuel load you planned for your trip.
Old December 4th 03, 01:53 PM
john
tanks" position?
On longer XC flights in my 172N, my SOP is to depart with selector on
both & remain there 1/2 hour. Next 1/2 is on right only. Then, back to
both for next 1/2 hr, continuing that sequence with prelanding
checklist calling for both. The drawdown of fuel is much faster from
the left tank than the right when using both.
I leave the selector on both when refueling. After topping the tanks,
I rock the wings before I go pay & pee. During the following
preflight, when I confirm the placement of the filler caps, the fuel
level is always topped off.
YMMV
John
Old December 4th 03, 01:05 PM
Jaap Berkhout
someone do that?
than
I rent the aircraft I fly. Several times the previous renter wrote a squawk
stating: "Fuel gets used only from left/right tank.". Thus far it turned
out that they could not fly coordinated...
Nevertheless, whenever I see this kind of squawk, I select left tank to
taxi, right tank for runup, both tanks for takeoff. After having reached
sufficient altitude, I fly for several minutes first on the left tank, then
on the right. If this works oke, there is nothing amiss with the fuel feed.
Of course, if it turns out there IS a problem, I can select the other tank
(or both) and return with sufficient fuel. Beter to find out early than
discovering later in the flight one of the tanks does not feed at a moment I
do not expect it and possibly at a point which is a bit awkward.
Old December 5th 03, 09:17 AM
Koopas Ly
Craig,
condition.
1. Is the fuel port inboard on the C172?
2. Does selecting "both" draw fuel from both tanks, even if one is empty?
someone do that?
situation.
Why does is operation of the A/P prohibited when there is a fuel imbalance?
Thanks,
Alex
Old December 5th 03, 04:29 PM
Teacherjh
I have an oblique answer to this question. I'm building an airplane
that seats four and is a high wing monoplane. The fuel tanks are in
the wing root, just like most high wing Cessnas. The plans show that
the fuel outlets should be placed near the wingroot but in different
locations fore and aft from each other. One tank has an outlet near
the wingroot by the trailing edge, the other tank has the outlet near
the wingroot but towards the leading edge.
Since it's a homebuilt, you have some flexibility in how you do things. Why
not put in two ports for each tank - one fore one aft. That way you can slip
and nose down and get fuel no matter which tank is selected? Try talking with
the designer of the plane about this - it might be worth considering.
Jose
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 08:40 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 05:31 PM
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 12:06 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
Tanks for nothing (repost from Bearhawk list) Del Rawlins Home Built 0 August 6th 03 03:06 AM
