Old baffles need upkeep in this neck of the woods. I was going to try my
hand at countersinking 3/32 rivets and hereby ask advice what is the best way to press in the dimple, best tool too and where to buy it. Because on the cylinder side of the baffle, like the opposite side of a plate nut, you don't want anything protruding. Also isn't baffling pure aluminum? Or something like 3003 or 5052? I was thinking of using something soft because of the tendency for cracking. Thanks. |
" jls" wrote: Old baffles need upkeep in this neck of the woods. I was going to try my hand at countersinking 3/32 rivets and hereby ask advice what is the best way to press in the dimple, best tool too and where to buy it. Because on the cylinder side of the baffle, like the opposite side of a plate nut, you don't want anything protruding. Also isn't baffling pure aluminum? Or something like 3003 or 5052? I was thinking of using something soft because of the tendency for cracking. Thanks. Theoreticall, you can countersink .032 aluminum, when you use 3/32" rivets. Practically, however, this is bad practice, as there is zero tolerance for error. It is far better to dimple the aluminum, using dimple dies. You can use a hand squeezer or a power squeezer. |
On Fri, 30 Jan 2004 09:31:25 -0500, " jls"
wrote: Old baffles need upkeep in this neck of the woods. I was going to try my hand at countersinking 3/32 rivets and hereby ask advice what is the best way to press in the dimple, best tool too and where to buy it. Because on the cylinder side of the baffle, like the opposite side of a plate nut, you don't want anything protruding. Also isn't baffling pure aluminum? Or something like 3003 or 5052? I was thinking of using something soft because of the tendency for cracking. Thanks. For cooling baffle material, I find that 6061-T4 usually works pretty well. O-ring |
![]() "O-ring Seals" wrote in message ... On Fri, 30 Jan 2004 09:31:25 -0500, " jls" wrote: Old baffles need upkeep in this neck of the woods. I was going to try my hand at countersinking 3/32 rivets and hereby ask advice what is the best way to press in the dimple, best tool too and where to buy it. Because on the cylinder side of the baffle, like the opposite side of a plate nut, you don't want anything protruding. Also isn't baffling pure aluminum? Or something like 3003 or 5052? I was thinking of using something soft because of the tendency for cracking. Thanks. For cooling baffle material, I find that 6061-T4 usually works pretty well. O-ring Thanks. |
