Open Class Super-Ship from Windward Performance
Old August 3rd 12, 09:04 AM posted to rec.aviation.soaring
Magnus Johansson
Default Open Class Super-Ship from Windward Performance
http://windward-performance.com/open...ed-super-ship/
I like it!
Old August 3rd 12, 02:58 PM posted to rec.aviation.soaring
Bill D
I like it!
OK, I think I'll buy a lottery ticket.
However...while super ships are neat, what we really need is 400 affordable 2-seat trainers.
Old August 3rd 12, 03:31 PM posted to rec.aviation.soaring
Something like this?
http://windward-performance.com/twin...nce-sailplane/
Old August 3rd 12, 03:57 PM posted to rec.aviation.soaring
Bob Kuykendall
Something like this?http://windward-performance.com/twin...nce-sailplane/
That's a pretty neat looking two-seater, but at the price points
Windward has typically been working to, I rather doubt it will fall
within the bounds of "affordable." Also, it has a lot of features that
make it somewhat inappropriate for the ab-initio audience that Bill
needs trainers for.
Here's what I would propose for an affordable two-seat trainer:
http://www.hpaircraft.com/two-seater/cover_shot-1.jpg
http://www.hpaircraft.com/two-seater...y_2_public.pdf
More info available as the situation develops.
Thanks, Bob K.
Old August 3rd 12, 04:22 PM posted to rec.aviation.soaring
Bill D
needs trainers for.
Thanks, Bob K.
As any airplane instructor can tell you, a trainer with side-by-side seating has a lot of advantages since the student can see the instructors hand gestures and hear the instructor better.
Some will worry about students transitioning from side-by-side to center line seating but way back when we flew the Pratt-Read's, no one had a problem with the transition.
One real consideration is everyone has to remember to add ballast to replace the instructor's weight when he steps out to solo the student.
Bill D
Old August 3rd 12, 04:28 PM posted to rec.aviation.soaring
christine anderson
needs trainers for.
Thanks, Bob K.
Hi Bob:
Looks very nice. The side by side configuration is much more conducive
to teaching than tandem, and for an acceptable performance trade-off.
However, I would recommend making it wider based upon experience in my
side by side which is a little wider than what you show in your
drawing. At least another 6 inches might be worth considering.
Best Regards,
Gary Osoba
Old August 3rd 12, 05:06 PM posted to rec.aviation.soaring
Best Regards,
Gary Osoba
And, move one seat back a few inches so those of us with wider shoulders will have room to work. When can I put in my order? 8^)
Marc
Old August 3rd 12, 04:48 PM posted to rec.aviation.soaring
Tony[_5_]
On Friday, August 3, 2012 9:57:41 AM UTC-5, Bob Kuykendall wrote:
On Aug 3, 7:31*am, wrote: OK, I think I'll buy a lottery ticket. However...while super ships are neat, what we really need is 400 affordable 2-seat trainers. Something like this?http://windward-performance.com/twin...nce-sailplane/ That's a pretty neat looking two-seater, but at the price points Windward has typically been working to, I rather doubt it will fall within the bounds of "affordable." Also, it has a lot of features that make it somewhat inappropriate for the ab-initio audience that Bill needs trainers for. Here's what I would propose for an affordable two-seat trainer: http://www.hpaircraft.com/two-seater/cover_shot-1.jpg http://www.hpaircraft.com/two-seater...y_2_public.pdf More info available as the situation develops. Thanks, Bob K.
how affordable is affordable? type certified or kit built? going to be opening an engineering office in Wichita???
Old August 3rd 12, 05:29 PM posted to rec.aviation.soaring
Bob Kuykendall
It's designed to hit $100,000 in 2010 dollars. That includes
convertible gear (nose roller and tail dragger), basic instruments,
removable nose and tail ballast, and open trailer.
Type certificated and built in series production. An experimental
glider of this size and shape would be economically and socially
unviable. This is a workhorse designed for operationality and
transposition rate, and engineered for ease of repair using common
composite materials.
There is also the ethical concern of carrying people who have not
necessarily made an informed decision to ride in a non-type-
certificated aircraft. I think that they deserve an aircraft that has
been tested to a higher standard than the typical kit aircraft.
I hadn't thought of that. Didn't they used to make airplanes there?
Thanks, Bob K.
Old August 3rd 12, 04:29 PM posted to rec.aviation.soaring
Bill D
I like it!
Neat design.
However, I suspect a larger tail volume will be required for winch launch. Winch launch will be a necessity to keep training costs reasonable as tow plane operating costs continue to increase. The ASK-21 has superlative winch behavior partly because of its large horizontal tail.
Should SSA Regional contests allow water in FAI class...15, 18, 20,Open class? Sean Fidler Soaring 25 December 16th 11 02:14 PM
52/1 Performance in a 15M ship at half the weight. SF Soaring 48 March 1st 09 06:24 PM
Intersted in Std Class Ship for Nationals in Uvalde Bill Elliott Soaring 0 April 10th 06 03:16 PM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
Super Cub towplane performance Marc Arsenault Soaring 1 July 11th 03 01:42 PM
