For the first time in my life I heard a 1st person story of a release failure.
The story follows: The glider, an ASK-21, was jerked forward by the tug so the front wheel rolled over the rope at the start of an aero tow. The slack was then taken out and the tow was launched without inspecting the hook and release. The working theory is that this somehow cocked the ring set in the hook so it failed to release even with pilot and passenger pulling on the release knobs. The pilot eventually got a successful release by yawing the glider strongly. AFAIK, the hook in question had not reached it's 2000 tow life limit nor is there any history of repair or maintenance in the hook area. There had been cases where a commercial operator had insisted on providing tows using a chain link instead of a Tost ring set. We think it possible this had damaged the hook in some way. Operationally, should a roll-over happen again, we will release the rope and re-attach before proceeding with a launch. The release will get special attention in the annual inspection later this month. No chain links will be allowed for any purpose. |
There are specific notes on my website and on TOST website warning of
possible damages due to the use of non-approved or badly worn Tost Tow rings http://www.wingsandwheels.com/page30.htm tim-- Please visit the Wings & Wheels website at www.wingsandwheels.com "Bill D" wrote in message ... For the first time in my life I heard a 1st person story of a release failure. The story follows: The glider, an ASK-21, was jerked forward by the tug so the front wheel rolled over the rope at the start of an aero tow. The slack was then taken out and the tow was launched without inspecting the hook and release. The working theory is that this somehow cocked the ring set in the hook so it failed to release even with pilot and passenger pulling on the release knobs. The pilot eventually got a successful release by yawing the glider strongly. AFAIK, the hook in question had not reached it's 2000 tow life limit nor is there any history of repair or maintenance in the hook area. There had been cases where a commercial operator had insisted on providing tows using a chain link instead of a Tost ring set. We think it possible this had damaged the hook in some way. Operationally, should a roll-over happen again, we will release the rope and re-attach before proceeding with a launch. The release will get special attention in the annual inspection later this month. No chain links will be allowed for any purpose. |
Not enough information to form an opinion, but I would suspect a worn/
damaged or improper tost ring substitute was used, as opposed to the hook being defective. If you can't see the stamp on the ring, it is no good IMO. |
On Monday, August 20, 2012 7:18:48 AM UTC-7, Bill D wrote:
For the first time in my life I heard a 1st person story of a release failure. The story follows: The glider, an ASK-21, was jerked forward by the tug so the front wheel rolled over the rope at the start of an aero tow. The slack was then taken out and the tow was launched without inspecting the hook and release. The working theory is that this somehow cocked the ring set in the hook so it failed to release even with pilot and passenger pulling on the release knobs.. The pilot eventually got a successful release by yawing the glider strongly. AFAIK, the hook in question had not reached it's 2000 tow life limit nor is there any history of repair or maintenance in the hook area. There had been cases where a commercial operator had insisted on providing tows using a chain link instead of a Tost ring set. We think it possible this had damaged the hook in some way. BTW I'm also aware of a Tost release failing to release due to corrosion within the release, I believe likely a combination of pee-tube spray and lack of proper care and maintenance. Pee tube spray may not be a factor in typicality ASK-21s but I suspect quite a few tow releases get only a cursory look over pre-flight and during the annual inspection. And on chain-links just say no. Tim's web site is a great resource for Tost stuff. Darryl |
On Monday, August 20, 2012 7:42:38 PM UTC-6, Darryl Ramm wrote:
On Monday, August 20, 2012 7:18:48 AM UTC-7, Bill D wrote: For the first time in my life I heard a 1st person story of a release failure. The story follows: The glider, an ASK-21, was jerked forward by the tug so the front wheel rolled over the rope at the start of an aero tow. The slack was then taken out and the tow was launched without inspecting the hook and release. The working theory is that this somehow cocked the ring set in the hook so it failed to release even with pilot and passenger pulling on the release knobs. The pilot eventually got a successful release by yawing the glider strongly. AFAIK, the hook in question had not reached it's 2000 tow life limit nor is there any history of repair or maintenance in the hook area. There had been cases where a commercial operator had insisted on providing tows using a chain link instead of a Tost ring set. We think it possible this had damaged the hook in some way. BTW I'm also aware of a Tost release failing to release due to corrosion within the release, I believe likely a combination of pee-tube spray and lack of proper care and maintenance. Pee tube spray may not be a factor in typicality ASK-21s but I suspect quite a few tow releases get only a cursory look over pre-flight and during the annual inspection. And on chain-links just say no. Tim's web site is a great resource for Tost stuff. Darryl The particular ASK-21 is fairly new (2000)and in excellent condition. It has always been stored in it's trailer when not being flown by highly qualified pilots. There is no evidence of corrosion anywhere. Records are being checked but indications are the release life limit has not been exceeded. I participated in the last annual and while the release was checked, it was not subjected to special scrutiny. (It will be this time.) The ring pair was not checked for authenticity but it will be. |
On Monday, August 20, 2012 8:08:47 PM UTC-7, Bill D wrote:
On Monday, August 20, 2012 7:42:38 PM UTC-6, Darryl Ramm wrote: On Monday, August 20, 2012 7:18:48 AM UTC-7, Bill D wrote: For the first time in my life I heard a 1st person story of a release failure. The story follows: The glider, an ASK-21, was jerked forward by the tug so the front wheel rolled over the rope at the start of an aero tow. The slack was then taken out and the tow was launched without inspecting the hook and release. The working theory is that this somehow cocked the ring set in the hook so it failed to release even with pilot and passenger pulling on the release knobs. The pilot eventually got a successful release by yawing the glider strongly. AFAIK, the hook in question had not reached it's 2000 tow life limit nor is there any history of repair or maintenance in the hook area. There had been cases where a commercial operator had insisted on providing tows using a chain link instead of a Tost ring set. We think it possible this had damaged the hook in some way. BTW I'm also aware of a Tost release failing to release due to corrosion within the release, I believe likely a combination of pee-tube spray and lack of proper care and maintenance. Pee tube spray may not be a factor in typicality ASK-21s but I suspect quite a few tow releases get only a cursory look over pre-flight and during the annual inspection. And on chain-links just say no. Tim's web site is a great resource for Tost stuff. Darryl The particular ASK-21 is fairly new (2000)and in excellent condition. It has always been stored in it's trailer when not being flown by highly qualified pilots. There is no evidence of corrosion anywhere. Records are being checked but indications are the release life limit has not been exceeded.. I participated in the last annual and while the release was checked, it was not subjected to special scrutiny. (It will be this time.) The ring pair was not checked for authenticity but it will be. Bill, I did not specifically expect corrosion in this case, I'm much more worried by corrosion where pee tubes are involved with higher performance/XC gliders, including in cases where there may be pee-tube vents into the gear well/on the U/C legs or gear doors and stuff spray around in in unpredictable ways (I don't like some style pee tubes that vent near the gear well) or where the pee tube exit is in front of the (CG) release and just does not poke out far enough. Darryl |
Hi
The initial message mentiones a rollover - problem there is that the tow rope can wind itself around the main wheel axle and tightens up severly when towed in this way. Nothing to do with Tost or other releases. Any Rollover - rope should be released immediatly and checked that above did not occur. Simple |
I've seen a few fail to release. All of them were either the result of
using incorrect (homemade, worn, deformed, etc.) rings (see Tost's website, which has considerable documentation on this), lack of maintenance (corrosion related to pee tubes, extremely wet fields, and dirt jamming the moving parts) and even illegal maintenance (involving readjusting the overcenter to compensate for beak wear, the owner won't be doing that again!). Also seen a few broken springs under 2000 launches, but these were due to operators having a different checklist, using the release 6 times per flight, and only 10.000 actuations are allowed. Tost failures other than these are pretty rare, and should be brought to the attention of the manufacturer. At 14:18 20 August 2012, Bill D wrote: For the first time in my life I heard a 1st person story of a release failu= re. =20 The story follows: =20 The glider, an ASK-21, was jerked forward by the tug so the front wheel rol= led over the rope at the start of an aero tow. The slack was then taken ou= t and the tow was launched without inspecting the hook and release. The wo= rking theory is that this somehow cocked the ring set in the hook so it fai= led to release even with pilot and passenger pulling on the release knobs. = The pilot eventually got a successful release by yawing the glider strongl= y. =20 AFAIK, the hook in question had not reached it's 2000 tow life limit nor is= there any history of repair or maintenance in the hook area. There had be= en cases where a commercial operator had insisted on providing tows using a= chain link instead of a Tost ring set. We think it possible this had dama= ged the hook in some way. Operationally, should a roll-over happen again, we will release the rope an= d re-attach before proceeding with a launch. The release will get special = attention in the annual inspection later this month. No chain links will b= e allowed for any purpose. |
Good post.
I always get funny looks when the line crew says, "Open, close... Check release", and I say, "No, I just checked it when I opened it for hookup. It may have only one more operation left and I want it to work when I release the rope in flight." It should have occured to me that there's a manufacturer specified life limit (number of tows) and, while a ground release is not as stressful as an in-flight release, you're still wearing springs and mating surfaces, cables, etc. Why wear it out with ridiculous, extra operations? Maybe I should pull my rip cord before getting into the glider to be sure my parachute will open when I need it... ;- "Eric Munk" wrote in message .com... I've seen a few fail to release. All of them were either the result of using incorrect (homemade, worn, deformed, etc.) rings (see Tost's website, which has considerable documentation on this), lack of maintenance (corrosion related to pee tubes, extremely wet fields, and dirt jamming the moving parts) and even illegal maintenance (involving readjusting the overcenter to compensate for beak wear, the owner won't be doing that again!). Also seen a few broken springs under 2000 launches, but these were due to operators having a different checklist, using the release 6 times per flight, and only 10.000 actuations are allowed. Tost failures other than these are pretty rare, and should be brought to the attention of the manufacturer. At 14:18 20 August 2012, Bill D wrote: For the first time in my life I heard a 1st person story of a release failu= re. =20 The story follows: =20 The glider, an ASK-21, was jerked forward by the tug so the front wheel rol= led over the rope at the start of an aero tow. The slack was then taken ou= t and the tow was launched without inspecting the hook and release. The wo= rking theory is that this somehow cocked the ring set in the hook so it fai= led to release even with pilot and passenger pulling on the release knobs. = The pilot eventually got a successful release by yawing the glider strongl= y. =20 AFAIK, the hook in question had not reached it's 2000 tow life limit nor is= there any history of repair or maintenance in the hook area. There had be= en cases where a commercial operator had insisted on providing tows using a= chain link instead of a Tost ring set. We think it possible this had dama= ged the hook in some way. Operationally, should a roll-over happen again, we will release the rope an= d re-attach before proceeding with a launch. The release will get special = attention in the annual inspection later this month. No chain links will b= e allowed for any purpose. |
Finally! I've been refusing to do release checks for years and get the stink-eye everytime. I've tried explaining that if you can hook up, then you have checked as much as you can, but still get people saying "but what if it fails?".
Maybe one of you smart guys out there can explain the logic of a separate release check? Kirk 66 |
Anyone have a Tost release? | noel.wade | Soaring | 5 | June 10th 10 04:36 AM |
Tost E85 release on Birddog | Doug[_4_] | Soaring | 0 | February 18th 10 06:08 PM |
FS Tost E85 Release | scooter | Soaring | 0 | March 7th 06 02:31 AM |
FS Tost E85 Release | scooter | Soaring | 0 | November 22nd 05 01:11 AM |
Tost release on L-19? | Roy Bourgeois | Soaring | 2 | November 29th 04 10:24 PM |
