SGS1-26 cable guide dimensions?
Old August 23rd 12, 05:26 PM posted to rec.aviation.soaring
JohnDeRosa
Default SGS1-26 cable guide dimensions?
Does anyone have the dimensions for the hard wood cable guides that are used in 1-26's?
The club needs to replace ours and I don't want to take the glider out of service to remove and measure the existing guides - then wait for the new ones to be made. And I don't want to buy new ones either.
Dimensions needed
- Overall length
- Inner diameter
- Outer diameter - small (inside steel tube)
- Outer diameter - large (against steel tube front)
The guide kind of looks like this (round oak dowel material).
Thanks in Advance, John
Old August 23rd 12, 09:53 PM posted to rec.aviation.soaring
aerodyne
I believe they are Phenolic. Also, might be a std part, if so,
cheaper to buy than make. Ask K&L for a p/n or a dwg if they are out
of stock.
Old August 24th 12, 12:18 AM posted to rec.aviation.soaring
Bart[_4_]
On Aug 23, 12:53*pm, aerodyne wrote:
I believe they are Phenolic. *Also, might be a std part, if so,
cheaper to buy than make. *Ask K&L for a p/n or a dwg if they are out
of stock.
Not long ago (month? two?) I was told that K&L "just had a bunch of
them made."
Bart
Old August 24th 12, 01:56 AM posted to rec.aviation.soaring
K&L has them in stock. Just recently bought some from them. Give them a call.
Their number is (607) 594-3329
Kevin
192
Dimensions student Home Built 2 December 6th 10 09:52 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 09:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 06:11 PM
FS SGS1-26E Quietpilot Soaring 1 October 8th 04 07:42 AM
B-17 dimensions... particulars... Ali-Reza Anghaie Military Aviation 1 December 29th 03 06:05 PM
