Minimum bending radius for 0.050" 6061-T6?
Old February 3rd 04, 09:20 PM
Bob Chilcoat
Default Minimum bending radius for 0.050" 6061-T6?
I scored some of the above sheet. I need to fabricate an approach plate
holder for my GPS yoke mount. Any idea if T6 will bend without cracking?
If so, what minimum bending radius should I aim for to avoid cracks?
Bob (Chief Pilot, White Knuckle Airways)
Old February 4th 04, 01:59 AM
frank
Got an Aircraft Sruce catalog? They have minimum bend radii for al and 4130.
Lots of good info in most catalogs.
Old February 4th 04, 03:23 AM
Orval Fairbairn
Any T6 aluminum will crack if you try to bend it. I once had some .020
2024-T6 aluminum that I wanted to make into some rudder skins. The act
of dimpling it cracked it.
Old February 4th 04, 04:35 PM
Gig Giacona
"Orval Fairbairn" wrote in message
news ...
cracking?
Damn.... and I'm building a plane made from a Metric Butload(r) of 6061-T6
Al that has been bent.
Gig
www.peoamerica.net/N601WR
Old February 4th 04, 03:26 AM
Daniel
Bob Chilcoat wrote ...
AC43.13-1B, Table 4-6 doesn't list 0.050, but it straddles it:
6061-T6 0.032 ½t-1½t
6061-T6 0.064 1t-2t
Daniel
Old February 4th 04, 04:07 PM
Bob Chilcoat
Thanks, Daniel,
I presume the "t" in the table is thickness? Someone in the RCM group
suggested heating the bend line to soften the temper. Anyone here try that?
I'll probably experiment a bit before I go to work on the final piece.
"Daniel" wrote in message
om...
cracking?
6061-T6 0.064 1t-2t
Daniel
Old February 4th 04, 06:34 PM
Richard Lamb
Bob Chilcoat wrote:
Thanks, Daniel,
NO!
om...
cracking?
6061-T6 0.064 1t-2t
Daniel
Old February 4th 04, 07:40 PM
O-ring Seals
On Wed, 04 Feb 2004 18:34:25 GMT, Richard Lamb
Bob Chilcoat wrote:
Thanks, Daniel,
NO!
Richard,
Not much of an answer. What does the "NO!" refer to? No, the "t" he
mentions does not relate to thickness of the material. It is the type
of treatemt recieved after production of the material. Heat treated,
work hardened, etc.
As to anealing, 'no' is not necessarily the answer. He is making an
approach plate holder (btw .050 is a bit of overkill for that). To
anneal, I normally smoke up the piece with carbon from a very
acetylene rich flame and slowly increase the heat until the carbon
just burns off.
I hope this helps.
O-ring
Old February 4th 04, 07:54 PM
Richard Lamb
Bob Chilcoat wrote:
Thanks, Daniel,
NO!
Richard,
work hardened, etc.
just burns off.
I hope this helps.
O-ring
Sorry O, et al.
You are right, of course.
I lost the thread for a moment.
Thought we were discussing a structural part.
FWIW, be very careful annealing with oxy acetelene.
Adjust the torch for a rich sooty flame to "mark" the area.
But I use a propane torch to burn it off.
The O-A flame seems to concentrate too much heat in too small
an area and increases the risk of accidentally ruining a part.
(don't ask how I know, just use you imagination)
Old February 5th 04, 02:30 AM
Daniel
Thanks, Daniel,
Hi Bob,
Yes, "t" stands for thickness. FWIW, given the nature of the project,
I'd just make life easy & calculate the setback and bend allowance
based on a 1/8" or greater radius. Wouldn't have to mess with a
torch, less risk to the workpiece & a less sharp (safer) corner in the
cockpit.
Daniel
