Does anyone know where to get an extra heavy tail wheel to move the
Cof G rearwards? |
John Murray also stocks them.
On Sep 1, 7:06*am, joesimmers wrote:
John Murray also stocks them. I filled my tailwheel with foam. Added 2.4 lbs. Cost about $20 as I recall. |
On Sep 3, 9:13*pm, "John Godfrey (QT)" wrote:
On Sep 1, 7:06*am, joesimmers wrote: John Murray also stocks them. I filled my tailwheel with foam. *Added 2.4 lbs. Cost about $20 as I recall. Lead foam? I don't get it. Foam seems pretty light. What kind of foam? John Cochrane |
John,
I've filled a tail wheel with foam. It was done at a local truck tire shop. The foam is rubber which is quite heavy. The 2 to 2.5 lb. weight increase is correct for a standard glider wheel. The increase on the little Matco WHLTW35 wheel I installed on my HP-14 was only 0.5 lbs. http://www.soaridaho.com/Schreder/Co.../DSCN2618.html Wayne "John Cochrane" wrote in message ... On Sep 3, 9:13 pm, "John Godfrey (QT)" wrote: On Sep 1, 7:06 am, joesimmers wrote: John Murray also stocks them. I filled my tailwheel with foam. Added 2.4 lbs. Cost about $20 as I recall. Lead foam? I don't get it. Foam seems pretty light. What kind of foam? John Cochrane |
On Saturday, September 1, 2012 12:29:33 AM UTC-4, pat wrote:
Does anyone know where to get an extra heavy tail wheel to move the Cof G rearwards? I'm interested in a swap. I have a brass tail wheel and need a standard one. Send me the details on yours if you're interested. I'll look up the axle size on mine. Juan juanman at mac dot com |
ASW tail wheel | Dan Mockler | Soaring | 8 | July 31st 12 05:26 PM |
ASW tail wheel | Dan Mockler | Soaring | 0 | July 28th 12 09:53 PM |
Blanik Tail Wheel | Roy Bourgeois | Soaring | 2 | August 21st 07 12:56 PM |
Brass tail wheel | Solo | Soaring | 9 | July 6th 07 04:18 PM |
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly | Tim Hanke | Soaring | 0 | February 8th 05 01:34 PM |
