Our gliding club has just taken delivery of a new-to-us Bellanca Scout 8GCBC however it did not have a towhook installed.
Is there any info out there in the way of drawings, blueprints, photos or just good old advice which might be shared with us. Or is there an old towhook just sitting around that someone wishes to sell? Thanks in advance Mike Maskell Winnipeg GLiding Club |
On Sep 1, 5:48*pm, wrote:
Our gliding club has just taken delivery of a new-to-us Bellanca Scout 8GCBC however it did not have a towhook installed. Is there any info out there in the way of drawings, blueprints, photos or just good old advice which might be shared with us. *Or is there an old towhook just sitting around that someone wishes to sell? Thanks in advance Mike Maskell Winnipeg GLiding Club The Sandhill Soaring Club in Gregory, Michigan used to have a tow- hooked Scout and might still. Find their contact info via ssa.org. |
Simplest way, but perhaps not the cheapest, is call American Champion and order a factory tow hook for it. Then you are simply installing an original equipment option and should require only and A&P entry in the logbook for the paper work.
Brian |
On Monday, September 3, 2012 10:32:55 PM UTC-4, Brian wrote:
Simplest way, but perhaps not the cheapest, is call American Champion and order a factory tow hook for it. Then you are simply installing an original equipment option and should require only and A&P entry in the logbook for the paper work. Brian Still will need a 337 using factory installation information as required approved data. UH |
On Tuesday, September 4, 2012 9:40:20 AM UTC-5, (unknown) wrote:
Still will need a 337 using factory installation information as required approved data. UH Maybe not, Hank. I know on some of the Cessna Singles, it is in the Illustarted Parts Catalog, and only requires a log book entry that the tow hook has been installed. The approved data is taken care of by virtue of it being an approved part to be installed on the airplane. And, I think Canada has different forms you would submit. Note, the OP is in Winnipeg. |
Pawnee towhook for a tie down? | [email protected] | Soaring | 0 | September 27th 07 02:34 AM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
Tampico TB-9 Information required | [email protected] | Piloting | 7 | February 25th 05 06:37 PM |
Cessna towhook | Bob C | Soaring | 0 | January 23rd 04 02:34 AM |
Aircraft crash - Arizona - Information required | John | Piloting | 0 | November 16th 03 09:37 AM |
