Integrating Flarm with Clearnav
Old September 4th 12, 10:33 PM posted to rec.aviation.soaring
Default Integrating Flarm with Clearnav
I have so far been unable to get Flarm traffic to show up on my Clearnav display.
I have experimented with different Clearnav zoom settings without success.
Within the Clearnav Main Menu/Settings/Tools tab I find the Flarm tab. Opening this tab shows a list of Flarm information which seems to give a positive indication that the Clearnav is receiving Flarm data. (Number of Objects:2 Transmission Status: True etc.)
I dont however find a setting to enable or show flarm traffic on the Clearnav screen.
Any help would be appreciated
Thanks!
Old September 4th 12, 11:13 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
I have experimented with different Clearnav zoom settings without success..
Thanks!
Do you have the latest software?
It's here http://www.clearnav.net/main/cn-downloads.html
The flarm display options are under pilot preferences (iirc).
Other gliders show up on the nav display as other gliders, with relative altitude displayed. You'll need the zoom adjusted appropriately close to see them. The collision warning display is split screen with audio. Can't miss it.
-Evan Ludeman / T8
Old September 4th 12, 11:54 PM posted to rec.aviation.soaring
On Tuesday, September 4, 2012 5:13:00 PM UTC-5, Evan Ludeman wrote:
On Tuesday, September 4, 2012 5:33:19 PM UTC-4, wrote: I have so far been unable to get Flarm traffic to show up on my Clearnav display. I have experimented with different Clearnav zoom settings without success. Within the Clearnav Main Menu/Settings/Tools tab I find the Flarm tab. Opening this tab shows a list of Flarm information which seems to give a positive indication that the Clearnav is receiving Flarm data. (Number of Objects:2 Transmission Status: True etc.) I dont however find a setting to enable or show flarm traffic on the Clearnav screen. Any help would be appreciated Thanks! Do you have the latest software? It's here http://www.clearnav.net/main/cn-downloads.html The flarm display options are under pilot preferences (iirc). Other gliders show up on the nav display as other gliders, with relative altitude displayed. You'll need the zoom adjusted appropriately close to see them. The collision warning display is split screen with audio. Can't miss it. -Evan Ludeman / T8
That might be the issue. I've now downloaded the latest software to my USB and will upload to the Clearnav this weekend. Thanks very much.
Old September 5th 12, 06:15 PM posted to rec.aviation.soaring
Kimmo Hytoenen
Hope you get it work, FLARM traffic on map screen improves situation
awareness. If you have swiss FLARM, it has two ports. The
"smaller" port only sends GPS data, the traffic info is not included.
Also I think that traffic info is not included if com speed is not 19200
bauds or higher.
Old September 6th 12, 08:18 AM posted to rec.aviation.soaring
Tobias Bieniek
Hi Kimmo, you mixed it up there. The smaller port does output only _traffic_ data, but not GPS data and it is fixed to 4800 Baud afaik. The larger port can be configured in various ways but it will only output the traffic data if the baudrate is 19200 or more.
Old September 6th 12, 01:33 PM posted to rec.aviation.soaring
Kimmo Hytoenen
only
_traffic=
larger
por=
traffic
dat=
My bad, Tobias is right. Mixed it with this baudrate thing. Sorry.
Kimmo Hytoenen
only
_traffic=
larger
por=
traffic
dat=
Kimmo Hytoenen
only
_traffic=
larger
por=
traffic
dat=
Old September 4th 12, 11:49 PM posted to rec.aviation.soaring
Andy[_1_]
Did you command the FLARM to turn on the port you are attempting to
drive ClearNav with?
Andy (GY)
$1500 ClearNav... sisu1a Soaring 1 January 8th 11 04:01 AM
NK ClearNav now available in VGA Resolution Paul Remde Soaring 0 July 28th 09 05:26 PM
ClearNav too big? brianDG303 Soaring 9 June 13th 08 07:15 PM
NK ClearNav Update Paul Remde Soaring 4 February 4th 08 01:31 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
