Alignment tool for spar pins
Old September 5th 12, 04:32 PM posted to rec.aviation.soaring
soartech[_2_]
Default Alignment tool for spar pins
I have heard of but not seen such a tool. It would have 2 sections
that rotate independently and are crescent shaped.
Two handles would protrude. Insert into the spar pin holes that have
been placed roughly into correct position so that you can see through
both, turn handles to 180 degrees apart aligning the holes, remove and
install your spar pin.
This would be a great help for one-man rigging. Does anyone know who
sells these or does anyone have a drawing of one? My pins are 30mm
diameter and 100mm long but a drawing could be changed for any size.
Old September 5th 12, 07:31 PM posted to rec.aviation.soaring
Dave Nadler
No, they would be circular.
Check your tech...
Old September 5th 12, 08:52 PM posted to rec.aviation.soaring
Dave Nadler
No, they would be circular, and rotate together.
Check your tech...
Old September 6th 12, 04:23 AM posted to rec.aviation.soaring
http://www.z5mfg.com/
Old September 6th 12, 05:39 PM posted to rec.aviation.soaring
soartech[_2_]
Thanks to all responders.
I knew there had to be something like that out there. My description
was based on imagination
as I have never seen one.
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
Control surface alignment [email protected] Home Built 10 July 4th 05 10:06 PM
INS Alignment at Sea Gary Watson Naval Aviation 5 November 9th 03 05:14 PM
INS Alignment at Sea Larry Naval Aviation 28 November 5th 03 12:58 PM
Seneca De-Ice Brush Alignment Tool John Owning 0 September 9th 03 11:03 PM
