I just downloaded version 4.31 (Sept 5, 2012 build). It defaults to a
-17 hour UTC offset, and the time setting adjustment (Tools/Options/General/UTC Offset) does not work. Anyone else having this problem? |
Użytkownik Greg Arnold napisał:
I just downloaded version 4.31 (Sept 5, 2012 build). It defaults to a -17 hour UTC offset, and the time setting adjustment (Tools/Options/General/UTC Offset) does not work. Anyone else having this problem? Maybe it's the wrong value set in your logger? It gets stored in the IGC file. To correct UTC offset for an open file, you should change it in flight properties dialog. -- WojtuÅ› |
On 9/9/2012 1:11 PM, Wojciech Scigala wrote:
Użytkownik Greg Arnold napisał: I just downloaded version 4.31 (Sept 5, 2012 build). It defaults to a -17 hour UTC offset, and the time setting adjustment (Tools/Options/General/UTC Offset) does not work. Anyone else having this problem? Maybe it's the wrong value set in your logger? It gets stored in the IGC file. The time in the file is correct. To correct UTC offset for an open file, you should change it in flight properties dialog. Thanks, the setting in Flight Properties fixes the problem. But then what is the purpose of the non-working setting in Tools/Options/General/UTC Offset? |
Thanks, the setting in Flight Properties fixes the problem. But then what is the purpose of the non-working setting in Tools/Options/General/UTC Offset? It should work if there no other setting in the file. Could you check with a another fresh original file? -- WojtuÅ› |
On 9/9/2012 2:33 PM, Wojciech Scigala wrote:
Użytkownik Greg Arnold napisał: Thanks, the setting in Flight Properties fixes the problem. But then what is the purpose of the non-working setting in Tools/Options/General/UTC Offset? It should work if there no other setting in the file. Could you check with a another fresh original file? I opened an OLC file, then SeeYou said he it wanted to update the software to the latest version. After that the problem occurred. Everything seems to be working fine now. Maybe the software update caused the problem. I still don't understand, however, why SeeYou has two different places where you can change the UTC offset. A change in one place appears to have no effect upon the other, so you can end up with two different UTC offsets? |
I still don't understand, however, why SeeYou has two different places where you can change the UTC offset. A change in one place appears to have no effect upon the other, so you can end up with two different UTC offsets? "Flight properties" affects only the file you have opened - and it shall be stored in that file if you click save button. Tools/Options sets the default UTC offset to be used if there is none in an opened file. -- WojtuÅ› |
GNS430W: Parallel offset course feature | Peter R. | Instrument Flight Rules | 34 | September 29th 07 02:25 AM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
Honda outboards offset crankshaft design - vertical shaft | [email protected] | Home Built | 1 | May 29th 06 07:00 AM |
Engine Mount Tilt and Offset | Barrie Gittens | Home Built | 7 | April 21st 04 01:22 AM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
