Soaring Cafe has published an article I wrote about the subject:
http://soaringcafe.com/2012/09/whats...r-glider-wrap/ I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian |
Herb - I am betting that you read the same Sunday Chicago Tribune article "And that's a wrap" I did about wrapping a car in vinyl. It never occurred to me to use that on a glider. I now have visions of wrapping my wings in tiger stripes!
http://www.chicagotribune.com/classi...0,314744.story. |
![]() Quote:
My assumption is that the static electricity build up on the vinyl is what keeps the dust particles attached more readily...but I'm no scientist! What that may mean in glider terms is that you may need to spend more time dusting the glider before take-off and, maybe after flying a while, any static build up may attract particles you don't want hanging around attached to the glider. This sounds like a great opportunity for some field experimentation! Brad. |
On the bottom wing surface one could put all kinds of fun stuff, also fuselage.
On a refinish the hard labor to remove the gel coat would still apply? Weight would not be a problem? Dieter On Tuesday, September 11, 2012 12:33:42 PM UTC-6, Herbert kilian wrote: Soaring Cafe has published an article I wrote about the subject: http://soaringcafe.com/2012/09/whats...r-glider-wrap/ I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian |
I suggest wrapping the canopy.
It would reduce all that annoying glare that makes PDAs so hard to read. See ya, Dave |
Maybe wrapping the pilot would lower injury rates...
![]() Paul "Dave Nadler" wrote in message ... I suggest wrapping the canopy. It would reduce all that annoying glare that makes PDAs so hard to read. See ya, Dave |
On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote:
Soaring Cafe has published an article I wrote about the subject: http://soaringcafe.com/2012/09/whats...r-glider-wrap/ I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian I would call Dick Butler he can tell you about that. |
On Sep 12, 8:43*pm, wrote:
On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote: Soaring Cafe has published an article I wrote about the subject: http://soaringcafe.com/2012/09/whats...ey-fajita-or-g... I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian I would call Dick Butler he can tell you about that. Dick Butler's Concordia has - from the reports I've read - some control surfaces wrapped in Monocote, a shrink film used for model airplanes. This was done solely for mass reduction reasons, no gel- coat on those structures. Car wrapping films are quite different. I'm contemplating starting a field study by wrapping the (short) winglets on my LS8-18 in white glossy film and to apply it myself since I have some background. This is a non-structural component and mine are like the rest of the glider in immaculate condition. The material is available on-line and would cost around $50 for the two winglets. That's cheap enough to remove the film after 1-2 years and see what's underneath (if it holds up that long). Herb |
On 9/13/2012 12:41 PM, Herbert kilian wrote:
On Sep 12, 8:43 pm, wrote: On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote: Soaring Cafe has published an article I wrote about the subject: Snip... Herb Kilian I would call Dick Butler he can tell you about that. Dick Butler's Concordia has - from the reports I've read - some control surfaces wrapped in Monocote, a shrink film used for model airplanes. This was done solely for mass reduction reasons, no gel- coat on those structures. Car wrapping films are quite different. I'm contemplating starting a field study by wrapping the (short) winglets on my LS8-18 in white glossy film and to apply it myself since I have some background. This is a non-structural component and mine are like the rest of the glider in immaculate condition. The material is available on-line and would cost around $50 for the two winglets. That's cheap enough to remove the film after 1-2 years and see what's underneath (if it holds up that long). Herb If you ever fly from "gravelly strips" (e.g. WW-II concrete airbases tend to qualify in this neck of the woods) another area to consider wrapping might be (part of) the tailboom aft of the main wheel where - in my experience - rock damage accrues...an easy wrap, no laminar flow there to be disturbed, possible reduction in "gravel damage"... Regards, Bob W. |
Hi Bob
For your particular problem you do not need a full wrap but the following could help http://www.streckenflug.at/shop/prod...roducts_id=800 |
Book on Glider Refinishing | Scott Alexander | Soaring | 2 | September 3rd 08 09:08 PM |
First Glider - No Gelcoat | Waduino | Soaring | 30 | February 12th 06 06:58 AM |
First Glider no gelcoat | Doug Reeve | Soaring | 0 | February 10th 06 10:05 AM |
Glider refinishing | Janusz Kesik | Soaring | 0 | December 9th 03 05:13 PM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
