Is there a way to ACCURATELY measure the available fuel in the tanks of a
general single-engine piston aircraft??? I know there are fuel flow computers available (such as JPI?). But these typically need to be "set" with a starting fuel quantity, and then it accurately measures the fuel flow rate (consumption rate) to calculate the remaining fuel. However, if you do not start with full tanks, or a [accurate] known given amount of fuel in the tanks, this method does not seem that reliable/accurate... Is there a way to accurately measure the fuel in the tanks while the aircraft is on the ground (using some "mechanical" measuring tool/gauge)? Is there a way to accurately measure the amount of fuel in the tanks while in flight? A friend of mine has bought some digital fuel gauges (a combination a several digital engine instruments -- but I forgot the manufacturer's name). Using these fuel gauges, you "calibrate" the instrument/gauges by leveling the aircraft (both "wings level" and "pitch/flying attitude level") and starting with 0 gals of fuel in the tank, then adding one gallon at a time, wait a while for the fuel to settle, then take an electronic reading, add 1 gal of fuel and repeat the process until the tanks are full. How accurate is this method? (personally I do not know how accurate this is, but would like to know from someone with experience using these instruments...) Thank you. Cameron ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
You could make a very accurate fuel stick by draining the tanks, filling
them a few gallons at a time, and marking the line on the stick each time. Trouble is, a lot of these fuel sticks end up inside the fuel tank. :-) Making a little cross bar at the handle end should prevent that. |
You bet. It's called a sight guage. A transparent panel or tube in the root
end of the tank so that you can see the gas. You have to keep the plane in the attitude you used to calibrate the guage, but it will never suffer an electrical or mechanical failure. Fancy ones will have a stripe behind the tube. The gas will act like a magnifying glass and make the stripe look real wide. Helps with the nearly transparent gas. Add a little light on the subject and you can see it in the dark, too. In article , "NoSpam" wrote: Is there a way to ACCURATELY measure the available fuel in the tanks of a general single-engine piston aircraft??? I know there are fuel flow computers available (such as JPI?). But these typically need to be "set" with a starting fuel quantity, and then it accurately measures the fuel flow rate (consumption rate) to calculate the remaining fuel. However, if you do not start with full tanks, or a [accurate] known given amount of fuel in the tanks, this method does not seem that reliable/accurate... Is there a way to accurately measure the fuel in the tanks while the aircraft is on the ground (using some "mechanical" measuring tool/gauge)? Is there a way to accurately measure the amount of fuel in the tanks while in flight? A friend of mine has bought some digital fuel gauges (a combination a several digital engine instruments -- but I forgot the manufacturer's name). Using these fuel gauges, you "calibrate" the instrument/gauges by leveling the aircraft (both "wings level" and "pitch/flying attitude level") and starting with 0 gals of fuel in the tank, then adding one gallon at a time, wait a while for the fuel to settle, then take an electronic reading, add 1 gal of fuel and repeat the process until the tanks are full. How accurate is this method? (personally I do not know how accurate this is, but would like to know from someone with experience using these instruments...) Thank you. Cameron ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
*****but it will never suffer an electrical or mechanical failure.*****
Never say never. I've personally seen the failure of just the type of gauge you are talking about. In a Super Cub. Showed 3/4 actual zero. Karl |
Doesn't it have a float on a wire? Not the same. The sight guage I
described has nothing in it except gas. I suppose you could put some chewing gum in the tube to plug it and it might stay full. Can't really call that a mechanical failure. In article , "karl" wrote: *****but it will never suffer an electrical or mechanical failure.***** Never say never. I've personally seen the failure of just the type of gauge you are talking about. In a Super Cub. Showed 3/4 actual zero. Karl |
******Doesn't it have a float on a wire? Not the same******
Exactly the same.You really should go have a look. No wire. Just a sight gauge with a red colored cork floating. I spent my pilot youth ferrying these fine airplanes from Lock Haven to Washington. Oregon, Alaska. The float on a wire is on a J3, Taylorcraft, Aeronca, usually on a forward fuselage tank. Super Cub tanks are in the wings. Karl |
Ok. I give up. How did it fail? The cork stick to the tube or what kept the gas from draining through the bottom of the guage? In article , "karl" wrote: ******Doesn't it have a float on a wire? Not the same****** Exactly the same.You really should go have a look. No wire. Just a sight gauge with a red colored cork floating. I spent my pilot youth ferrying these fine airplanes from Lock Haven to Washington. Oregon, Alaska. The float on a wire is on a J3, Taylorcraft, Aeronca, usually on a forward fuselage tank. Super Cub tanks are in the wings. Karl |
"karl" wrote in message ... | *****but it will never suffer an electrical or mechanical failure.***** | | Never say never. I've personally seen the failure of just the type of gauge | you are talking about. In a Super Cub. Showed 3/4 actual zero. John Denver's LongEZ also had a sight gauge. What he did not know was that with the nose wheel retracted on the ground the gauge would always look more full than it really was, even when the tank was almost empty. The problem with sight gauges is that they are not linear, meaning that when the gauge is 1/4 full it does not necessarily indicate that the tank is 1/4 full. This is true of fuel sticks, too. Fuel tanks tend to be rounded at the top and bottom, so an inch of fuel in the bottom is less gas than an inch of fuel in the middle. The gauge should be calibrated and marked with the fuel quantity at several different levels, but no one had done this on Denver's plane. NTSB report he http://www.ntsb.gov/ntsb/brief.asp?e...08X09045&key=1 |
John, who had more ratings than I ever will, approached a homebuilt with the
mindset that he was dealing with a certified aircraft - that don't have such 'gotchas'... Denny "C J Campbell" wrote The gauge should be calibrated and marked with the fuel quantity at several different levels, but no one had done this on Denver's plane. |
Two questions:
What is "accurate"? Why do you need "accuracy"? Jim "NoSpam" shared these priceless pearls of wisdom: -Is there a way to ACCURATELY measure the available fuel in the tanks of a -general single-engine piston aircraft??? Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Is taking off on single mag bad for engine | flyer | Home Built | 10 | September 21st 03 10:43 PM |
| WANTED: partnership, rental or club with fast single or light twin in San Diego | Jim McGarvie | Aviation Marketplace | 0 | September 13th 03 04:55 PM |
