http://www.tecmate.com/u_optimate_5.php
They are used by the 2-meter radio folks and lots of motorcycle people. Aircraft Spruce sells them to airplane people. Seems like a highly versatile compact, durable charger/maintainer/diagnostic tool at a decent price. Perhaps overkill for our needs? They also manufacture a nice universal USP power cord that you can use to charge/operate your cell phone directly from the ship's batteries should you ever find yourself landed out with a dying cell phone. |
On Sunday, September 16, 2012 12:25:00 AM UTC-6, (unknown) wrote:
http://www.tecmate.com/u_optimate_5.php They are used by the 2-meter radio folks and lots of motorcycle people. Aircraft Spruce sells them to airplane people. Seems like a highly versatile compact, durable charger/maintainer/diagnostic tool at a decent price. Perhaps overkill for our needs? They also manufacture a nice universal USP power cord that you can use to charge/operate your cell phone directly from the ship's batteries should you ever find yourself landed out with a dying cell phone. Use caution with these. Ive found the best chargers for the AGM batteries like Power-Sonic which most of us use are the chargers sold by Power-Sonic. The Power-Sonic charger for the 12V 9AH battery (Commonly used for gliders) shows a charge rate of 800MA and this thing is 2.5A. Further, Ive tried several different chargers and the PS chargers determine peak and switch to float CONSISTENTLY (Emphasis) better than most of the chargers Ive tried. The higher the charge rate or the continuous charge past peak, The hotter the internal battery temp during charging the shorter the battery life. |
At 11:55 16 September 2012, K wrote:
Use caution with these. Ive found the best chargers for the AGM batteries l= ike Power-Sonic which most of us use are the chargers sold by Power-Sonic. = The Power-Sonic charger for the 12V 9AH battery (Commonly used for gliders)= shows a charge rate of 800MA and this thing is 2.5A. Further, Ive tried se= veral different chargers and the PS chargers determine peak and switch to f= loat CONSISTENTLY (Emphasis) better than most of the chargers Ive tried. Th= e higher the charge rate or the continuous charge past peak, The hotter the= internal battery temp during charging the shorter the battery life. The heading on the original post was about the Optimate series, unfortunately the web page showed the Optimate 5. As I said, I use a bank of Optimate 4's which is the right model for glider batteries. The maximum charge rate is 800MA. The manual sounds complicated, but all you need to do is plug it in and leave it on - all winter in particular: http://www.optimate.co.uk/Optimate%2...structions.pdf I test the capacity of my batteries regularly, worth changing after 3 or 4 seasons and I think that goes for whatever charger you use. Mike |
Which Optimate you choose is indeed dependent on battery size as a function of the C/10 formula. I use a 12 volt 14 ah battery and am contemplating a 12 volt 18 ah. The Optimate-5 is correctly sized for these batteries I believe.
The web site indicates a wide range of amp-hour sizes for each chargers. Does the charger detect the battery size and adjust the current accordingly? |
Handheld trickle battery chargers | [email protected] | Soaring | 1 | May 16th 08 11:18 PM |
For Sale: 12-volt Battery Chargers and Winter Vario | 59 | Soaring | 1 | May 23rd 06 07:27 PM |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Solar Battery Chargers | Jay Honeck | Piloting | 32 | February 22nd 04 11:17 PM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
