ClearNav Instruments is pleased to announce a software solution for
validation and scoring of OLC flights recorded on Cambridge GPSNav model 10, 20 and 25 flight recorders. Instructions and necessary files are located on the ClearNav Instruments site here http://www.clearnav.net/main/cn-CAI-OLC.html You will find a downloadable utility and a dll that should work on (almost) any windows PC you are likely to be using, which will convert your CAI files to OLC valid IGC files. Users please note that this is an OLC specific solution and should not be used for badge and record flights. Special thanks to Guy Byars, Paul Seifried and David Hoppe. -Evan Ludeman for ClearNav Instruments |
On Tuesday, September 18, 2012 12:01:57 PM UTC-5, Evan Ludeman wrote:
ClearNav Instruments is pleased to announce a software solution for validation and scoring of OLC flights recorded on Cambridge GPSNav model 10, 20 and 25 flight recorders. Instructions and necessary files are located on the ClearNav Instruments site here http://www.clearnav.net/main/cn-CAI-OLC.html You will find a downloadable utility and a dll that should work on (almost) any windows PC you are likely to be using, which will convert your CAI files to OLC valid IGC files. Users please note that this is an OLC specific solution and should not be used for badge and record flights. Special thanks to Guy Byars, Paul Seifried and David Hoppe. -Evan Ludeman for ClearNav Instruments Evan, I know this is probably a stretch, but has anyone talked to the OLC regarding submitting logs that did not make the cutoff date? Maybe a temporary time window for folks to get there logs submitted. I'll bet there's lots of pilots with log files that are invalid because this solution was just now become available. Any Thoughts? Dave |
Well done! Awesome! Thank you!
Paul Remde _____________ "Evan Ludeman" wrote in message ... ClearNav Instruments is pleased to announce a software solution for validation and scoring of OLC flights recorded on Cambridge GPSNav model 10, 20 and 25 flight recorders. Instructions and necessary files are located on the ClearNav Instruments site here http://www.clearnav.net/main/cn-CAI-OLC.html You will find a downloadable utility and a dll that should work on (almost) any windows PC you are likely to be using, which will convert your CAI files to OLC valid IGC files. Users please note that this is an OLC specific solution and should not be used for badge and record flights. Special thanks to Guy Byars, Paul Seifried and David Hoppe. -Evan Ludeman for ClearNav Instruments |
3 Cheers for making this happen. It's quite a service to the OLC pilots of the world using older Cambridge devices. Nice to know my CAI files are valid backups if needed, like this last weekend.
On Tuesday, September 18, 2012 2:54:56 PM UTC-7, Paul Remde wrote: Well done! Awesome! Thank you! Paul Remde _____________ "Evan Ludeman" wrote in message ClearNav Instruments is pleased to announce a software solution for validation and scoring of OLC flights recorded on Cambridge GPSNav model 10, 20 and 25 flight recorders. Instructions and necessary files are located on the ClearNav Instruments site here http://www.clearnav.net/main/cn-CAI-OLC.html You will find a downloadable utility and a dll that should work on (almost) any windows PC you are likely to be using, which will convert your CAI files to OLC valid IGC files. Users please note that this is an OLC specific solution and should not be used for badge and record flights. Special thanks to Guy Byars, Paul Seifried and David Hoppe. -Evan Ludeman for ClearNav Instruments |
Works great! .. (2) Greens on OLC from my Model 20
Thank you, Evan. Today's flight made it to 17,000' msl, and the OLC called it green. Thanks to your conversion file, no more blue balls.
| Thread Tools | |
| Display Modes | |
| OLC Solution for Cambridge GPS-Nav | Evan Ludeman[_4_] | Soaring | 5 | September 18th 12 09:21 PM |
| US Team Announces Winner of ClearNav Raffle | John Godfrey (QT)[_2_] | Soaring | 2 | September 27th 10 09:21 PM |
| Why so expensive (flight recorders) | Jim Beckman | Soaring | 64 | March 4th 08 03:18 PM |
| Revised IGC-approval documents for Cambridge and EW recorders | Ian Strachan | Soaring | 3 | April 13th 05 01:04 PM |
| Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 06:28 PM |
