Optimum thermalling speed display
Old September 26th 12, 05:29 AM posted to rec.aviation.soaring
kirk.stant
Default Optimum thermalling speed display
With all the new (and some of the older - SN10 for example) vario-computers having accelerometers and settings for ballast and polars, would it be possible to compute and display the optimum thermalling speed adjusted for wingloading and bank angle (as a function of instantaneous G-loading)?
Since we don't (yet) have AOA gauges (which would do a better job of indicating the correct speed to fly in a thermal), I'm curious if a simple "speed to fly" indication would work.
Obviously, filtering a constantly varying G-load would have to be employed, but I'm thinking of a 2-3 knot speed band display - using the same fast-slow indicator used for cruise speed control - preferably also with a deadbeat digital readout of the optimum speed to thermal for an average of the past 3 seconds or so of turn/averaged G.
Would this work? Probably only once established in a steady, smooth turn - but that would give a good starting point for the next thermal.
Kirk
66
Old September 26th 12, 05:49 PM posted to rec.aviation.soaring
soartech[_2_]
Since we don't (yet) have AOA gauges...
Kirk
66
If you want to buy one they are available. Check out www.safeflight.com
There are more listed on page 16 and 17 of the Feb 2008 issue of
Soaring.
Trying to thermal effectively while keeping your speed within a 2-3
knot range sounds
like trying to balance on a ball. I suspect the slight difference in
efficiency is not significant.
Old September 26th 12, 07:08 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Kirk
66
Soaring.
knot range sounds
What many pilots need is a G meter that nags them to use a steeper bank
than the 20-30 degrees I often see. That would improve the their
climbing effectiveness a lot more than the optimum AOA.
email me)
Old September 27th 12, 07:58 AM posted to rec.aviation.soaring
Tim Taylor
How about a bank angle read out on the new Butterfly vario so the guys that think they are flying a 45 degree bank can see they are really only banked 20 degrees? Not sure I need a speed to fly, usually it is as slow as the glider will fly well. Any slower it will mush or be slow on the controls, any faster and I am flying too big of circles. Too many different types of thermals for one number.
Old September 27th 12, 12:26 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Every glider in the fleet has a handy 45 degree bank angle reference. Use your instrument screws. Kilobuck solutions not required.
T8
Old September 27th 12, 04:39 PM posted to rec.aviation.soaring
T8
Not sure how accurate this is, but an interesting experiment regardless...
http://www.stolaf.edu/people/hansonr/soaring/spd2fly/
Old September 27th 12, 06:17 PM posted to rec.aviation.soaring
T8
Evan, I think Tim's comment was tongue in cheek...
I agree with him, why the hell do you need a thermaling speed director, what happened to good-old hand flying the glider and taking pride in the results?
Old September 27th 12, 01:11 AM posted to rec.aviation.soaring
John Cochrane[_3_]
Kirk
66
I think it would work very nicely. Quick, if you normally thermal your
ASW27 empty at 44 knots in a 30 degree bank, what's the right speed
for 12 gals of water ballast each side? What's the right speed for 50
degrees? Accurate speed control makes a big difference. It's been on
my (rather long) punch list of requests to the clearnav team for a
while, if anyone else were asking they'd probably do it.
John Cochrane
Old September 27th 12, 04:18 AM posted to rec.aviation.soaring
JS
I have a ClearNav, love it but don't want to look at it that much.
Using "normally" and "30 degree bank" in the same sentence is a typo?
Old September 28th 12, 12:15 AM posted to rec.aviation.soaring
On Wednesday, September 26, 2012 8:11:07 PM UTC-4, John Cochrane wrote:
On Sep 25, 11:29*pm, "kirk.stant" wrote: With all the new (and some of the older - SN10 for example) vario-computers having accelerometers and settings for ballast and polars, would it be possible to compute and display the optimum thermalling speed adjusted for wingloading and bank angle (as a function of instantaneous G-loading)? Since we don't (yet) have AOA gauges (which would do a better job of indicating the correct speed to fly in a thermal), I'm curious if a simple "speed to fly" indication would work. Obviously, filtering a constantly varying G-load would have to be employed, but I'm thinking of a 2-3 knot speed band display - using the same fast-slow indicator used for cruise speed control - preferably also with a deadbeat digital readout of the optimum speed to thermal for an average of the past 3 seconds or so of turn/averaged G. Would this work? Probably only once established in a steady, smooth turn - but that would give a good starting point for the next thermal. Kirk 66 I think it would work very nicely. Quick, if you normally thermal your ASW27 empty at 44 knots in a 30 degree bank, what's the right speed for 12 gals of water ballast each side? What's the right speed for 50 degrees? Accurate speed control makes a big difference. It's been on my (rather long) punch list of requests to the clearnav team for a while, if anyone else were asking they'd probably do it. John Cochrane
I would expect, for such a device to be effective, there would need to be quite a complex set of inputs, both from sailplane data, and sensory input.
Some examples:
1- Glider performance information for all likely flap settings used in thermalling.
2- Current mass
3- Knowledge of and the ability to quantify and input a variable for how the glider responds to horizontal and vertical gusts
4- Airspeed input, gust input- via asi , 3 axis accelerometers.
5- A harder one- what is the next gust going to be?
6- Others I'm not bright enough to think of now.
THEN- all the programmers need to do is whiz up an algorithym that takes all these into account and pops out "the number".
The vario folks are just now, 20 years after "the Dave Ellis dream", beginning to master the next level of variometry.
I'm not surprised that the ClearNav guys haven't bitten on this. It would be really hard to do in a meaningful way and maddenly difficult to try to explain to us glider jocks how to use it.
UH
Optimum CG Range jcarlyle Soaring 38 December 17th 09 05:50 PM
Thermalling the D2 Fox Two Soaring 9 November 2nd 06 10:01 PM
The new art of thermalling - with a kite... [email protected] Soaring 3 July 30th 06 04:06 AM
Uncoordinated thermalling David Norinsky Soaring 2 July 12th 05 05:07 AM
Hands off thermalling John Jones Soaring 24 April 26th 04 03:07 PM
