I had a chance to load a new config file and was able to fly today.
There was no "flarm range" in my original config file. With the file I used today the "flarm range" config was set to maximum with the statement below. I had several flarm detections that occured around 4 miles. This is between 2x and 3x what I experienced before so this is a noticable improvement. Still not 6 or 8 miles, but a nice improvement. I re-set the PCAS ranges and the ADSB ranges and the PCAS function improved only a very small amount. I am still flying with my Zaon pcas and it reported many aircraft that the PowerFlarm did not show at all. A 172 that passed nearby was under 1 mile horizontal and if I remember the Flarm showed it around 1 mile. However it lost the contact only a few moments after it first reported the contact. I did see the towplane on PowerFlarm PCAS but a no more than 1 mile range. After I put the glider back in the hanger I received one ADSB signal from an aircraft that was 8,000 feet higher and over 10 miles away. Since ADSB comes in on the same antenna that the PCAS receives on I think it's likely that the radio circuit and antenna are working fine and that there is real potential to improve the PCAS via the software. I didn't see the message about the additional lines in the config file until tonight, but if I fly again this weekend I'll try to test those too. The one pilot in our group who did not update his config file did not see the 4 mile Flarm performance so it appears that the "as shipped" settings in the brick may be limiting the performance. The key elements in the config file that I used today are as follows: # PCAS (transponder) range (meters) $PFLAC,S,PCASRANGE,10000 # PCAS (transponder) vertical range (meters) $PFLAC,S,PCASVRANGE,1000 # ADSB range (meters) $PFLAC,S,ADSBRANGE,65535 # ADSB vertical range (meters) $PFLAC,S,ADSBVRANGE,65535 # FLARM range (meters) $PFLAC,S,RANGE,65535 I don't know what settings Flarm intended to have in the units as "as shipped" but I will encourage them to ship units with maximums. Far better to start off with more info and warnings and then pull back than fly around 1/2 blind. More testing and reports as weather and opportunity present. One side note, the data dump file that appeared on my USB stick after flying appears to be corrupted. When I got early dump files when I had just received the unit the files appeared neatly arranged with no extra characters. Currently there is tons of gibberish in the file. Not knowing how that file is created or appended, is there a way to reset or clear the file within the brick and hope for less gibberish? Might also just be my USB stick too. Mark |
Mark and others -
Its been said many times in a few forums and websites (and I'm annoyed they do not include it on a big red or yellow piece of paper in the box): YOU MUST NOT USE THE PowerFLARM UNITS (Brick or Portable) RIGHT "OUT OF THE BOX". You *MUST* apply a configuration file, with your aircraft's ID value in the config file. This is CRITICAL!!! The reason is this: ADS-B (and thus FLARM) tracks your glider based on your airplane's unique ICAO value. There are instructions on how to find this and apply it to your config file. If you do not do this, your FLARM will use a "default" (dummy) identifier. FLARM ignores every signal with the same identifier as your own, to keep from alerting you about your own position (for example, if you have a transponder or install ADS-B out). That means every other FLARM that is still set to the "default" identifier will be ignored (because they all match) and you will never see them on your FLARM display!! And the "other guy" will never see you on his/her display!! Very, very bad. [And yes, this is one area where I think the PowerFLARM folks could do a better job with documentation and warning the purchaser. On the one hand, its a complicated device that's doing a lot and its not a simple install - so people should read instructions carefully. But on the other hand you have to expect in this day and age that people are going to assume something is "Plug and Play" unless you warn them off - strongly.] --Noel |
P.S. Should clarify that I was typing in all-caps to try to catch
people's eye; not to yell at you, Mark. |
Noel, are you sure about that? If I recall correct, this parameter is optional for mode S users, and Flarm defaults to Flarm ID if you don't supply one, which is different for each unit. This is the first time I hear this explanation.
But I agree that one must configure the unit first. A friend flew without configuring his unit and we could only detect each other when circling together, I am not completely sure why. Also his display showed constant transponder alert from his own transponder. Ramy |
On Oct 5, 10:14*pm, Ramy wrote:
Noel, are you sure about that? If I recall correct, this parameter is optional for mode S users, and Flarm defaults to Flarm ID if you don't supply one, which is different for each unit. This is the first time I hear this explanation. But I agree that one must configure the unit first. A friend flew without configuring his unit and we could only detect each other when circling together, I am not completely sure why. Also his display showed constant transponder alert from his own transponder. Ramy Ramy - Maybe they fixed this in newer deliveries... I was warned about this (along with many others) by a west-coast FLARM dealer; and was able to confirm that two PFs in close proximity with default settings didn't see each other; but that was back in June. I haven't had to touch the config on my PF since Nationals so perhaps my info on the defaults is out of date (would be a good thing if it is, I suppose)! --Noel |
If your PowerFlarm can use the Flarmnet database, then you are granted that
it is based on unique ID, embedded in each single delivered unit. This is how it works in Europe, at least. "noel.wade" wrote in message ... On Oct 5, 10:14 pm, Ramy wrote: Noel, are you sure about that? If I recall correct, this parameter is optional for mode S users, and Flarm defaults to Flarm ID if you don't supply one, which is different for each unit. This is the first time I hear this explanation. But I agree that one must configure the unit first. A friend flew without configuring his unit and we could only detect each other when circling together, I am not completely sure why. Also his display showed constant transponder alert from his own transponder. Ramy Ramy - Maybe they fixed this in newer deliveries... I was warned about this (along with many others) by a west-coast FLARM dealer; and was able to confirm that two PFs in close proximity with default settings didn't see each other; but that was back in June. I haven't had to touch the config on my PF since Nationals so perhaps my info on the defaults is out of date (would be a good thing if it is, I suppose)! --Noel |
Noel,
We did read and follow the instructions and DID load the config file. The point is that in the config file they include with the instructions they do NOT include all the available parameters which can be set. So if you don't know that the "secret" parameters can be set then my point is the manufacturer should set those to a maximum number and not to some smaller number. This very issue led to us following their "instuctions" and getting 25% of the range we could have gotten. Might have saved a lot of hassle. Mark |
You do NOT need to set the ICAO ID, unless you carry a Mode S transponder (where it helps to suppress your own transponder signal).
So yes, PowerFLARM WILL work 'straight out of the box'. Do not set the *wrong* ICAO ID.... for obvious reasons. Setting aircraft type ('Glider' for you guys and gals) correctly will ensure that the alarm algorithms treat you properly. If you configure as 'helicopter' and circle in a gaggle of gliders you and all others will get many annoying warnings. It's a feature, not a bug... ;-) PowerFLARM.us has sample configuration files which are easy to adapt for your taste. As for setting the range to maximum as factory default: We have many users who fly in very dense airspace. The default ranges ensure that they are only warned about aircraft that may become dangerous and there is no unnecessary distraction. |
For those of us who don't relish the "opportunity" to dive in and experiment with config files and such . . . Butterfly has a free config file builder that does it for you using a multiple choice format that even I can figure out.
http://www.butterfly-avionics.com/in...core-config-en bumper |
On Saturday, October 6, 2012 11:11:32 AM UTC-5, bumper wrote:
For those of us who don't relish the "opportunity" to dive in and experiment with config files and such . . . Butterfly has a free config file builder that does it for you using a multiple choice format that even I can figure out. http://www.butterfly-avionics.com/in...core-config-en bumper As a side note, and perhaps Gerhard can comment on the correctness of my statement. The link above creates a file, but if you select the dump file option it puts in a command that I suspect resulted in my receiving gibberish in the output file. When I replaced the "dump" command with the statement below I got clear info again. $debug_out,fat,scheduler|config|baro|rf|gps|pffsm, all Mark |
PowerFlarm BRICK range issues - are we alone???? | Mark | Soaring | 79 | October 17th 12 12:17 PM |
PowerFLarm expected range | [email protected] | Soaring | 6 | August 30th 12 03:43 PM |
PowerFLARM deployment issues | SoaringXCellence | Soaring | 6 | December 6th 10 12:23 AM |
Places for good info on US-Canada flights? | Colin W Kingsbury | Piloting | 9 | January 27th 05 12:03 AM |
FAA to End part 91 Sightseeing flights? | Vaughn | Rotorcraft | 7 | November 2nd 03 01:20 AM |
