Hi,
I ran into a pilot who was eagerly describing his 185 amphibian and remember seeing several wheeled versions and float versions in Fort Simpson a few years ago. I vaguely recall the (wheeled) 185 being a trike. How do the 182 and 185 differ? Marc |
185 on wheels is tail wheel configuration;182 is nosewheel
185 usually has 300hp & three bladed prop;182 is 230hp&two blades 185 has a straight tail; 182 since about 1962 models have wider fuselage, and swept tail there are other differences too. my 182L is worth about $75k; similarly well-equipped 185 would be $150K. 180 is the narrow fuselage, straight-tail 182 on conventional gear. MikeM Skylane 182L '1MM Pacer '00Z Marc Lattoni wrote: Hi, I ran into a pilot who was eagerly describing his 185 amphibian and remember seeing several wheeled versions and float versions in Fort Simpson a few years ago. I vaguely recall the (wheeled) 185 being a trike. How do the 182 and 185 differ? Marc |
![]() "Marc Lattoni" wrote in message news:OheOb.25646$Eq.7142@clgrps12... Hi, I ran into a pilot who was eagerly describing his 185 amphibian and remember seeing several wheeled versions and float versions in Fort Simpson a few years ago. I vaguely recall the (wheeled) 185 being a trike. You don't remember to pretty good. 185 is a 180 on significant steroids. Neither have a training wheel. 185 will do things a 182 can't even dream about. How do the 182 and 185 differ? Marc |
![]() Marc Lattoni wrote: How do the 182 and 185 differ? The 185 has conventional gear, has either 260 or 300 hp, depending on the year, seats 6, can haul over 1600 pounds, and cruises at a bit over 165 mph. The 182 is a trike, has 230 hp, seats 4, can haul about 1300 pounds, and cruises at a bit over 155 mph. Fill the tanks, and the 185 still hauls over a quarter ton. Great bush plane. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
"G.R. Patterson III" wrote in message
... Marc Lattoni wrote: How do the 182 and 185 differ? The 185 has conventional gear, has either 260 or 300 hp, depending on the year, seats 6, can haul over 1600 pounds, and cruises at a bit over 165 mph. The 182 is a trike, has 230 hp, seats 4, can haul about 1300 pounds, and cruises at a bit over 155 mph. Isn't the 185 the predecessor of the 206? Just done a search... http://www.skydivestandrews.co.uk/ht...s/facility.htm says "The Cessna 185 aircraft is effectively the 'tail dragger' equivalent of a Cessna 206, and should not be confused with the entirely different Cessna 182." Paul |
![]() Paul Sengupta wrote: Isn't the 185 the predecessor of the 206? The 180 came first. Narrow body, 230 HP, tail wheel. Then in '56 came the 182. It was just the 180 with a nosewheel. In '61 the 185 was born. It was the same as the 180 with a 260 HP IO-470 engine. Some structural beef up was included. In '62 the 182 was widened 4 inches. In '63 the 205 was introduced, it was the 210 with fixed gear, although at the time it was called the Super Skylane. In '64 Cessna beefed up the 205 and created the 206. In '65 the 205 was dropped. In '66 the 185 got the 520 for 285 HP as an option, standard in '67. |
![]() "Newps" wrote in message news:wAUOb.100295$I06.444117@attbi_s01... Paul Sengupta wrote: Isn't the 185 the predecessor of the 206? The 180 came first. Narrow body, 230 HP, tail wheel. Then in '56 came the 182. It was just the 180 with a nosewheel. In '61 the 185 was born. It was the same as the 180 with a 260 HP IO-470 engine. Some structural beef up was included. In '62 the 182 was widened 4 inches. In '63 the 205 was introduced, it was the 210 with fixed gear, although at the time it was called the Super Skylane. In '64 Cessna beefed up the 205 and created the 206. In '65 the 205 was dropped. In '66 the 185 got the 520 for 285 HP as an option, standard in '67. Bleargh! So was the 185 ever widened? When did it get 6 seats, or did it always have 6 seats in certain guises? In the same size plane as a 180? Or as a later 182? 'eck! Paul |
![]() Paul Sengupta wrote: So was the 185 ever widened? No. When did it get 6 seats, or did it always have 6 seats in certain guises? It always had 6. The 180 had 6 after 1963. In the same size plane as a 180? Yep. Or as a later 182? The 182 is longer and taller, but has the same wingspan. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
![]() Paul Sengupta wrote: "Newps" wrote in message news:wAUOb.100295$I06.444117@attbi_s01... Paul Sengupta wrote: Isn't the 185 the predecessor of the 206? The 180 came first. Narrow body, 230 HP, tail wheel. Then in '56 came the 182. It was just the 180 with a nosewheel. In '61 the 185 was born. It was the same as the 180 with a 260 HP IO-470 engine. Some structural beef up was included. In '62 the 182 was widened 4 inches. In '63 the 205 was introduced, it was the 210 with fixed gear, although at the time it was called the Super Skylane. In '64 Cessna beefed up the 205 and created the 206. In '65 the 205 was dropped. In '66 the 185 got the 520 for 285 HP as an option, standard in '67. Bleargh! So was the 185 ever widened? No. When did it get 6 seats, Never. or did it always have 6 seats in certain guises? Well, like the 182 it had an option for those jokes they call childs seats. In the same size plane as a 180? Or as a later 182? 'eck! The 180 and the 185 always were and are the same size. Now, they do have some pretty nice extended baggage areas that can be installed. As a matter of fact Selkirk Aviation just got an extended baggage for the wide body 182's STC'd. I'll be doing that to mine, it goes back from the current rear bulkhead 34 inches. |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Piloting | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
