Engine overhaul/replacemtn in Europe
Old January 19th 04, 11:37 AM
Frode Berg
Default Engine overhaul/replacemtn in Europe
Hi all!
I am in a co ownership of a 1968 Arrow, and our engine is currently
operating on overtime (allowed extra time before complete overhaul)
I have been given the priviledge of findig out our options on a replacement
engine.
Can someone provide a web page with links to different European shops that
would do this?
What would our options be? A new engine? Refurbished one? What would be the
pro's and con's of those two, and the price difference.
We are discussing the possiblilties of upgraing to a Garmin 430, as well as
an S_TEC two axi AP. Possibly also a stormscope.
Is there any sense in finding a shop that would do all this in one go? Would
there be any price savings?
Oh and one more thing. Since we are in JAR territory now, what would the
regulations be if I for instance fly to Belgium and get it all done. Would
it require a bunch of paper work once back in Norway?
All the best,
Frode Berg
LN-LMR
P28R-180
Old January 19th 04, 08:48 PM
Julian Scarfe
"Frode Berg" wrote in message
Hi all!
replacement
engine.
would do this?
Air Power supply factory engines if you want to go down that road.
http://www.factoryengines.com/
If you can persuade your local maintenance shop to do the swap, that may be
the most cost effective route.
Here's a typical set of numbers from the site above:
New $33,100
Remanufactured $21,900
Overhauled $19,600
The difference between a reman and a factory overhaul is mainly in terms of
formally zeroing the time rather than making it SMOH. In principle the
tolerances are tighter for the reuse of parts. In practice it might not
make much difference.
Julian Scarfe
Old January 19th 04, 09:13 PM
Paul Sengupta
"Julian Scarfe" wrote in message
I get two different prices for the engine for my Bulldog. If I enter it
as an IO-360-A1B6, I get
New $32,618, Remanufactured $21,331, Overhauled $18,692
As an AEIO-360-A1B6, I get
New $35,716, Remanufactured $23,407, Overhauled $20,759
Not sure what else you get in the "AE" bit. The RAF converted the
engine into an AE by adding a Christen inverted oil system I believe.
The engine (outside this add-on) I would guess is the same as it was
before. Why the price difference? Do they overhaul/supply a new
inverted oil system?
Paul
Old January 19th 04, 10:57 PM
Kjell Aanvik
The AE is for AErobatic, hence the Christen inverted oil system
Kjell Aa
Oslo, Norway
"Paul Sengupta" skrev i melding
Paul
Old January 20th 04, 10:27 AM
B S D Chapman
On Mon, 19 Jan 2004 23:57:25 +0100, Kjell Aanvik
Kjell Aa
Oslo, Norway
That's a bit of a laugh though, isn't it?
8 seconds was the book figure, but you'd be bloody lucky to last that long!
Old February 8th 04, 09:36 PM
Paul Sengupta
"B S D Chapman" mail-at-benchapman-dot-co-dot-uk wrote in message
news
long!
That's because there's so much dihedral on the wings
all the fuel runs downhill to the upper tanks when you're
inverted, so you only have what's in the fuel lines!
Paul
Old January 20th 04, 09:40 AM
David Cartwright
I was chatting to an aircraft-owning friend who's also an engineer (and
who's also trying to sell me a share in a PA28-161) about this the other
day. In his opinion and experience, he reckons that if you can afford it,
you should always go for the new engine instead of a "zero timed"
refurbishment. Apparently he's found over the years that although components
may look okay during the refurb, it's generally the bits that weren't
replaced that start to give trouble, and that there's a noticeable trend
that refurb engines need attention long before new ones.
D.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Engine overhaul/replacemtn in Europe Frode Berg Owning 6 February 8th 04 09:36 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
