Becker 4201 Radio Wiring Diagram - need help
Old October 18th 12, 02:53 PM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default Becker 4201 Radio Wiring Diagram - need help
I am confused with the wiring diagram of the manual. Can anyone help
clear up some confusion on the placement of the PTT wires? Where do
wires 17 & 25 go in conjunction with the two wires that come from the
PTT on the control stick?
Old October 18th 12, 04:06 PM posted to rec.aviation.soaring
RobKol
Scott,
You might find the answer in the similar thread discussed few days ago
https://groups.google.com/forum/?hl=...ng/oaFM5FCLNMc
Robert
Old October 18th 12, 04:03 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Pins 13 and 25 are ground. Pin 17 is PTT, grounding it switches to
tramsmit.
So one wire from the PTT switch (doesn't matter which one) goes to pin 25
(or 13, or ground bus bar or anything else connected to radio ground) and
the other wire to pin 17.
However, I ask, if you can't follow the diagram in the manual, should you
be wiring up your own radio instead of getting somebody who knows what they
are doing to do it for you?
8-) , Peter
Becker AR 4201 Radio For Sale Helmut Bauer Soaring 2 October 2nd 12 07:55 AM
FS: Becker AR 4201 Don[_4_] Soaring 0 September 19th 12 05:16 PM
Wiring diagram for GA radio/mic? Gary G General Aviation 15 November 23rd 05 03:33 PM
Becker 4201 multiple failures Jean Soaring 0 August 9th 04 08:43 AM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
