Soaring Avionics Archaeological Finds
Old November 5th 12, 09:18 PM posted to rec.aviation.soaring
JohnDeRosa
Default Soaring Avionics Archaeological Finds
We have been cleaning out our club's hangar's store room and are
finding all sorts of old and odd items, no doubt left over from some
old and odd members.
I was curious about two of the items and wondering if anyone can shed
some light.
- A clear bag containing two smaller clear bags. First bag is marked
"Netto" and contains what appears to be a very small brass valve with
~1/16" aluminum tubing coming out of each end. It might not be a
valve and might not be tubing. Second bag was labeled 0.003 (!)
stainless steel wire (almost thought the bag was empty at first). How
are these used in a Netto system?
- Cambridge Model AU-22 - Cigarette sized black aluminum box with a
speaker, two knobs, circuit board and a cable coming out of it.
Complete with a repair tag labeled Cambridge Aero Instruments, Warren-
Sugarbush Airport. I have never heard of this model number and
Google doesn't turn up any hits. Is this an early audio vario? What
does the connector connect to?
Thanks, John DeRosa
Old November 5th 12, 09:58 PM posted to rec.aviation.soaring
JP Stewart
I believe the AU22 is the audio control on the CVS-50:
http://www.airtalk.org/cambridge-var...l-vt74218.html
http://www.bas.uk.net/docs/AU22.pdf
JP
some light.
Thanks, John DeRosa
Old November 5th 12, 11:22 PM posted to rec.aviation.soaring
JohnDeRosa
On Nov 5, 3:58*pm, Jp Stewart wrote:
I believe the AU22 is the audio control on the CVS-50:http://www.airtalk.org/cambridge-var.../docs/AU22.pdf
JP
The CVS-50 was the hint I needed. Thanks to Tim Mara for keeping this
old information available online.
http://www.wingsandwheels.com/pdf/au20%202.pdf
http://www.wingsandwheels.com/pdf/cvs40%2050%2060.pdf
Still trying to figure what the 0.003" SS wire is for.
Old November 5th 12, 11:33 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
IIRC, the wire is inserted into the tubing to calibrate the netto
device. One end of the netto is "T"d into the line between the vario
and the capacity bottle and the other end is connected to pitot, or--
depending on how the netto leak is calibrate--to static. It was easier
to change the effective resistance of the netto by moving the wire in
and out slightly than by trimming off tubing until, oops, you trimmed
too much.
This was in the days when nearly every vario (except for the Ball
series) had a 1/2 liter flask. And when the really fancy final glide
computers were plastic wheels instead of cardboard. And when real men
navigated with paper maps! And....
Chip Bearden
ASW 24 "JB"
USA
Old November 5th 12, 11:36 PM posted to rec.aviation.soaring
Tony[_5_]
no one had time to look outside while trying to figure out where they were on the map and if they could make it?
Old November 6th 12, 03:46 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
glide
men
It could be very time consuming figuring out where you were on the map,
then measure distances to your waypoint/airport, decide on a wind
component to use, twirl the "prayer wheel" to the right setting, and
finally discover your arrival altitude.
Shoot, just unfolding and folding the map and switching from one
sectional to the other was a big challenge! Electronic flight computers
eliminated almost all this distraction.
email me)
Old November 5th 12, 10:39 PM posted to rec.aviation.soaring
Dave Nadler
some light.
That's not wire, it is tubing, used to create a calibrated leak
for a netto. Perhaps valve turns netto leak on/off.
Its an audio, hooks up to early Cambridge Variometer products.
Uses a unijunction oscillator !
You should see the stuff in my basement !
See ya, Dave "YO electric"
Old November 6th 12, 10:07 PM posted to rec.aviation.soaring
JS
John, et al:
If you install the AU-22 in a glider with a metal instrument panel and have a problem with radio transmissions interfering with the vario, Dave Ellis had a mod:
Cut the -12V trace in the audio box that goes to the chassis.
Believe "That instrument was before my time at Cambridge" was in his explanation.
Also believe mine was an AU-20, the 22 may be sans built in ground loop.
News----Victim Finds New CCTV Images of Suspected securitycamera2000 Home Built 0 May 14th 12 03:08 AM
CNN finds ‘Dark Undercurrent’ Among Tea Party Protesters - Well yeah. They're brain dead.. ZOMBIES ! ! ! LIBERATOR[_2_] Naval Aviation 0 September 15th 09 10:16 AM
OLDER PILOTS PERFORM BETTER, STUDY FINDS Larry Dighera Piloting 16 March 21st 07 02:11 AM
Airman Finds True Calling as Part of 'Best Force' Otis Willie Military Aviation 0 September 10th 04 11:18 PM
Air Force captain finds passion in taking on physical challenges, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 25th 04 12:31 AM
